Why does lim x→∞ (x - ln x) equal ∞, not -∞?
  • Thread starter Thread starter r_swayze
    Ln
10 replies · 52K views
r_swayze
Can somebody show a step by step process of how to get this answer?
I keep getting -∞ when it should be ∞
heres my work:
lim x→∞ (x - ln x) = lim x→∞ ((1 - 1/x ln x) / (1/x)
then apply l'hospitals rule
lim x→∞ (x^(-2) ln x - x^(-2)) / (-x^(-2))
then I cancel all the x^(-2) and I am left with -ln x which would equal to -∞
You can apply L'Hopital's rule only when you have an indeterminate form of [0/0] or [+/-infinity/infinity].
In this expression -- ((1 - 1/x ln x) / (1/x) -- 1/x approaches zero, but ln x approaches infinity, which makes it another indeterminate form.
I don't think that there's anything you can do with L'Hopital's rule on this one. You might try an approach that looks at the derivative of f(x) = x - ln x. It's easy to show that the derivative approaches 1 as x gets large, which suggests that x - ln x gets larger and larger.
Why don't you apply l'Hopital to the ln(x)/x part of your expression and use the result to simplify it?
(At the risk of confusing things) or take the first x into the ln(x).
Remember that [tex]ln(x) = \int_1^x \frac{1}{u} du[/tex] and use the MVT
where does the ln(x)/x come from?
This is what I would do:
[tex]\stackrel{lim}{x\rightarrow\infty}(x-ln(x))\times\frac{(x+ln(x))}{(x+ln(x))}[/tex]
This would give:[tex]\stackrel{lim}{x\rightarrow\infty}\frac{(x^{2}-ln^{2}(x))}{(x+ln(x))}[/tex]
You could work it out from there, split the limit up by [tex]x^{2}[/tex] and [tex]ln^{2}x[/tex]
Hope this helped, and sorry about the poor formatting, this is probably the first time I am doing latex.
By the way, I'm sure the value is infinity.
You could do lim x→∞ (ln e^x - ln x) = lim x→∞ ln (e^x /x) and apply l'hopital's rule inside; the domain change of x to ln e^x is irrelevant because your limit exists within the domain of log.
I think I see it, but just to make sure, does ln e equal 1? so that can be plugged into any equation?
Write it (as you basically did) as x*(1-ln(x)/x).
