Why does ln|(y-2)/(y+2)| = 4x + c_2 give ±e^(4x+c_2)?
  • Thread starter Thread starter Rijad Hadzic
    Property
12 replies · 2K views
Rijad Hadzic
Going from
[itex]ln|\frac {y-2} {y+2}| = 4x + c_2[/itex]
to
[itex]\frac {y-2} {y+2} = \pm e^{4x+c_2}[/itex]
Meaning, why is is [itex]\pm[/itex] e^{4x+c_2}?
I know that for log, you take the absolute value because ln(x) has restriction x>0
but I'm failing to see why its +- for e?
I think this has to do with the fact that the exponent is not restricted to the positive range; you can view this as the function within the log() only applies when it is positive, but without the log(), it can take up both positive and negative values.
Rijad Hadzic said:
Going from
to
Should we assume that you know that
##\ln(A)=B##​
is equivalent to
##A=e^B##​
##\ln(A)=B##​
is equivalent to
##A=e^B##​
Yes I think I understand that part...
This means that e^B > 0, am I right?
Yes, If we take A to be a function, the range of A valid for log(A) is only positive, but in fact the full range of A is both positive and negative. So as a function itself, A can take both positive and negative values. Hence the exponent is valid in both positive and negative values.
Ohhh I see. Well I already assumed that. I guess my problem here was with the authors notation. That makes sense, as later on he ended up dropping the +- and just opted for + instead..
The fact that B > 0 has little to do with your question.
If you change ##\displaystyle \ \ln \left| \frac {y-2} {y+2} \right| = 4x + c_2 \ ## to an exponential equation, you get:
##\displaystyle \ \left| \frac {y-2} {y+2} \right| = e^{4x + c_2} \ ##​
I see. So because [itex]|\frac {y-2} {y+2} |[/itex] = [itex]\frac {y-2}{y+2}[/itex] for [itex]\frac {y-2} {y+2} >= 0[/itex]
you get
[itex]\frac {y-2} {y+2} = e^{4x+c_2}[/itex]
and because
[itex]|\frac {y-2} {y+2} |[/itex] = [itex]- \frac {y-2}{y+2}[/itex] for [itex]\frac {y-2} {y+2} < 0[/itex]
you get
[itex]\frac {y-2} {y+2} = -e^{4x+c_2}[/itex]
so it ends up being two equations?
Rijad Hadzic said:
Going from
to
Because
$$\ln \left| \frac{y-2}{y+2} \right| = 4x + c \; \Rightarrow \: \left| \frac{y-2}{y+2} \right| = e^{4x+c}$$
and ##A = \pm |A|##.
Ray Vickson said:
Because
Was my reasoning above your post correct?? As to why the equation e is +- and that its really two equatiosn not one
Yes, it is correct, and makes my post redundant. However, your post did not appear on my screen until after I posted mine!
Haha its all good. My insight is small right now. Even a rewording of something that I'm having trouble with is valuable to me.
Anytime you have an equation |x|=y, there are two solutions, namely y=x and y=-x. Maybe you already knew that. So, yes there are two equations.
