Why does Mathematica 6.0 claim 100-digit precision for an approximate result?
4 replies · 3K views · last reply
ehrenfest
[SOLVED] mathematica issue
This is from Mathematica 6.0. Is this a bug in Mathematica? Supposedly the second output is precise to 100 digits!
In[46]:= x = 0.00004
Out[46]= 0.00004
In[45]:= N[(1 + x)^(1/3) - 1 - x/3 + (x^2)/9 - 5 (x^3)/81, 100]
Out[45]= 1.18826*10^-16
In[44]:= FullSimplify[(1 + y)^(1/3) - 1 - y/3 + y^2/9 < 5 y^3/81,
Assumptions -> y > 0]
Out[44]= True
I think you are running into a machine precision issue with the way your equation is entered. Take a look in the help files in 3.1.6.
When you do calculations with arbitrary‐precision numbers, as discussed in the previous section, Mathematica always keeps track of the precision of your results, and gives only those digits which are known to be correct, given the precision of your input. When you do calculations with machine‐precision numbers, however, Mathematica always gives you a machine‐precision result, whether or not all the digits in the result can, in fact, be determined to be correct on the basis of your input.
Hmmm...I thought the N[ ] function caused the expression to be evaluated in arbitrary precision mode. How can I get that expression in arbitrary precision mode?
Hi ehrenfest,
I believe the problem occurs when you give the value to x; at that point machine precision is used for x which carries over to the rest of the calculation. If you want 100 digits in arbitrary precision, you could use:
x=0.00004`100
and then calculate
alphysicist said:
Hi ehrenfest,
x=0.00004`100
and then calculate
problem solved!
