Why does Mathematica's Fourier command omit phase information?
9 replies · 9K views
Niles
Hi all
I have a function F, which depends on a discrete variable x, and I need to Fourier Transform it. I have put all the values of F in a table.
Then I have used the command "Fourier" on the table, which - according to http://reference.wolfram.com/mathematica/ref/Fourier.html - results in the discrete Fourier Transform. But the new table only contains pure numbers, no phase factor. Why is that, and is there a way to include the phase?
Niles.
Does anybody know this? I feel bad "bumping" the thread, but I am in real trouble if I can't work this out.
Here you go (the values of F are in the table)
Code:
four = Fourier[{0.5,1.0,3.0,5.0}]
Mathematica {4.75+0 i,-1.25-2. i,-1.25+0 i,-1.25+2. i}
Why not {9.50 + 0 i, -2.50 + 4. i, -2.50 + 0.i, -2.50 - 4.i} ?
But I really don't know what it is that Mathematica is calculating? The amplitudes or what?
Hi Niles. It's easy to see what Mathematica is computing. Just do a help on Fourier and hit the more info button. For a list {u_n}, Mathematica creates a list {v_n} such that:
[itex]v_s=\frac{1}{\sqrt{n}}\sum_{r=1}^n u_r e^{2\pi i(r-1)(s-1)/n}[/itex]
so for your list {0.5, 1.0, 3.0, 5.0},
the first value computed by Mathematica is:
[itex]v_1=\frac{1}{\sqrt{n}}\sum_{r=1}^n u_r e^{2\pi i(r-1)(1-1)/n}=4.75[/itex]
Don't know what you mean by phase factor or amplitude though. Try reading through all the various options in the More info. Maybe you'll spot something that can help you.
If x(n) represents the time-domain data, the formula for an N-point discrete Fourier transform is given by
[tex] X(m) = \sum_{n=0}^{N-1} x(n) e^{-2\pi imn/N}, \qquad m=0\ldots N-1.[/tex]
You'll often be interested in the magnitude and power contained in each X(m). If you represent an arbitrary DFT output value, X(m), by its real and imaginary parts:
[tex] X(m) = X_\textrm{real}(m) + iX_\textrm{imag}(m) = X_\textrm{mag}(m) \textrm{ at an angle of }X_\theta(m)[/tex]
the magnitude of X(m) is simply
[tex] X_\textrm{mag}(m) = |X(m)| = \sqrt{X_\textrm{real}(m)^2 + X_\textrm{imag}(m)^2}.[/tex]
The phase angle of X(m) is then defined by
[tex] X_\theta(m) = \tan^{-1} \left(\frac{X_\textrm{imag}(m)}{X_\textrm{real}(m)}\right).[/tex]
Therefore, if you calculate the DFT of your data as
Code:
 In[1]:= four = Fourier[{0.5,1.0,3.0,5.0}]
Out[1]:= {4.75 + 0. I, -1.25 - 2. I, -1.25 + 0. I, -1.25 + 2. I}
the phase is obtained simply as
Code:
 In[2]:= phases = ArcTan[Im[four]/Re[four]]
Out[2]:= {0., 1.0122, 0., -1.0122}
Is that what you're looking for?
I will try and experiment with it; I'll keep you posted. Thanks so far.
