Why does superconductors don't radiate?
  • Context: Graduate
  • Thread starter Thread starter Demystifier
    Superconductors
35 replies · 13K views
Demystifier said:
Or let me be more quantitative. According to an equation in http://en.wikipedia.org/wiki/Multipole_radiation ,
the intensity of multipole radiation is suppressed by a factor
1/(2l+1)!
For a macroscopic current, l is of the order of 10^23, so the factor above is ridiculously small. This smallness has nothing to do with superconductivity.
This argument also carries over to the quantum description of a normal conductor.
In scattering an electron has to get scattered from one side of the fermi surface with momentum k_F to the other side with -k_F. The corresponding angular momentum change is ##L=2r\hbar k_F=\hbar l## with r being the radius of the ring.
DrDu said:
The article by Greiter is dead wrong as I already laid out in another thread.
I thought you changed your mind?
DrDu said:
I had a look at the old thread
https://www.physicsforums.com/showthread.php?t=622398&highlight=Greiter
I still stand to my point that as ##|\phi\rangle=|\phi^\Lambda\rangle ## also ##\phi(x)=\langle x|\phi \rangle=\langle x|\phi^\Lambda \rangle=\phi^\Lambda ## in contrast to the assumed behaviour in first quantisation.
Well, let's discuss that some other time - I can't remember what it was about except that I thought you had changed your mind. Anyway, it doesn't seem controversial that the London equation is derived using a quasistatic assumption, which fits with the idea that it's a very good approximation to simply ignore any radiation - does it?
I also think that the original question has been clarified:
1. For a constant macroscopic current - whether superconducting or not - we expect practically no radiation due to the homogeneity of the charge and current distributions.
2. Radiation in superconductors is supressed further by a similar mechanism as scattering, i.e.
a Cooper pair can't make an energetically favourable radiative transition to a condensate with lower velocity as this condensate is not present.
As far as I am concerned, 1. is now sufficient to me.
