Why does t-distribution standard deviation decrease with sample size?
OpheliaM
I don't understand why does the standard deviation of a t-Distribution decreases as the degree of freedom (and, thus, also the sample size) increases when the sample standard deviation underestimates the population standard deviation?
More data tends to give a more accurate estimate of the true population standard deviation.
The sample standard deviation underestimates the population standard deviation if you use the sample mean and divide by n. If you use the true population mean and divide by n or use the sample mean and divide by (n-1) that is not true.(CORRECTION: it is still under-estimated. See @Number Nine 's post below) For the degree of the t-distribution, you should use the n or (n-1) that you divided by.
PS. Just to be more clear. The sample mean should always be the sum of the sample divided by n. When I say "use the sample mean and divide by (n-1)", I mean that the sum of squares of deviations from the sample mean are divided by (n-1). That is Bessel's correction. (see https://en.wikipedia.org/wiki/Bessel's_correction )
FactChecker said:
More data tends to give a more accurate estimate of the true population standard deviation.The sample standard deviation underestimates the population standard deviation if you use the sample mean and divide by n. If you use the true population mean and divide by n or use the sample mean and divide by (n-1) that is not true. For the degree of the t-distribution, you should use the n or (n-1) that you divided by.
A minor point: the "population standard deviation" (i.e. the square root of the sum of squared deviations from the mean, divided by n-1) is actually a biased estimate of the standard deviation. This follows from Jensen's inequality, since the square root is a concave function. It's fairly difficult to find an unbiased estimator of a normal standard deviation, and the corrections have no closed form -- see https://en.wikipedia.org/wiki/Unbia...deviation#Results_for_the_normal_distribution
I stand corrected. Thanks. I will correct my prior post.
