High School Why does the Andromeda galaxy appear so tiny from our perspective?
The Andromeda Galaxy, located 2.5 million light-years away with a diameter of approximately 220,000 light-years, appears as a small fuzzy patch rather than a distinct object due to its vast distance and the limitations of human vision. The galaxy subtends an angle of about 5 degrees, but only the denser central regions are visible to the naked eye, reducing the apparent angle to less than 2 degrees. Observers using telescopes, such as a 6" reflector, often report seeing a fuzzy patch rather than detailed structure, as higher magnifications diminish brightness and field of view. Effective observation requires understanding the limitations of both human eyesight and telescope optics.
  • Understanding of astronomical distances (light-years and parsecs)
  • Familiarity with angular measurement in astronomy (degrees)
  • Basic knowledge of telescope optics and magnification effects
  • Awareness of the limitations of human vision in low-light conditions
  • Research the effects of distance on the visibility of celestial objects
  • Learn about telescope specifications and optimal magnification techniques
  • Explore astrophotography techniques for capturing images of large galaxies
  • Investigate the differences between visual observation and photographic imaging in astronomy
Astronomy enthusiasts, amateur astronomers, and anyone interested in understanding the visibility of distant celestial objects like the Andromeda Galaxy.
  • #61
So what does the eyepiece of a proper 150x20 scope have to be like? TeleVue offers eyepieces with 100 and 110 degree field of view. Eye does have more than 110 , but peripheral vision is limited resolution. What does te focal length need to be?
Astronomy news on Phys.org
  • #62
Dnj23 said:
Ok. Where does your picture fall in this top 10?
I don't understand your question. First, do you understand that the moon in the image @Zeke137 posted is there to give you a sense of scale, not brightness? The actual moon would be far, far brighter. Having said that, everything in his image is much dimmer than your "top 10" list.
  • #63
Dnj23 said:
Also, you guys have amazing eyesight...Seeing Venus in phases?
I think, as with distinguishing between a star and a planet, a 'half Venus' looks different and someone with experience can interpret what's actually going on from a very poor image.
No Elves on PF mate.
  • #64
Oh really?
"So, here's another picture which shows the Andromeda galaxy as it would appear to the naked eye in a not very dark sky "
  • #65
Ok.
You can detect differences in light, but you can't actually see the phases.
  • #66
What else can you guys see? Neptune white briefs of clouds?
  • #67
Zeke137 said:
So, here's another picture which shows the Andromeda galaxy as it would appear to the naked eye in a not very dark sky...
Hope this helps in visualizing the sizes and appearances on the sky.
Zeke137 said:
Ummm, in what way "no way", dude?
The way that is worded, it sounds like you are saying that in a not very dark sky you should see Andromeda looking like that. I agree with the "no way". Perhaps in an exceptionally dark sky you might.
Likes davenn
  • #68
Well, actually I'm not saying it as such. The background photo comes from Flickr - https://live.staticflickr.com/7016/6467038861_01b1efebf9_b.jpg - so maybe we should all take this up with the person who took the photograph. I do note that neither the image of the tree nor the stars appear to be smeared, so I'd assume this was basically a snapshot of a scene as he/she had seen it.
My own personal experience, however, has always been that Andromeda is a naked eye object only on very dark nights.
Let's just say that the image I posted above shows rather well the relative sizes of Andromeda and the Moon on the sky, and has a nice tree in the foreground as a further aid to visualizing relative sizes. And that the central portion of Andromeda as viewed with the naked eye is just about the size on the sky as portrayed in the picture.
Likes russ_watters and Dnj23
  • #69
Andromeda would be synonymous with the Moon, Venus, Jupiter, Sirius, etc.
  • #70
Nice list of point-like or disk objects with no indistinct or fuzzy regions extending well beyond them.
Comparing apples with smoke will get us nowhere.
Likes Dnj23
  • #71
Synonomous in what way?
Likes Dnj23
  • #72
In terms of significant brightness to make it noticeable.
  • #73
I'm done with this thread.
  • Sad
Likes weirdoguy
  • #74
It's your thread! You've had some great stuff/images/explanations!
  • #75
I think it might be helpful at this stage to point out how telescopes actually make the beautiful bright images of deep-sky objects like the Andromeda Galaxy, or the Orion Nebula, or the Crab Nebula, to name but a few:
These objects are pretty faint (they're a long way away), so the amount of light received by a telescope from such an object in anyone instant is simply not sufficient to capture a decent image. The same goes for the naked eye, which can only see the brightest parts (relatively speaking) of such objects and hence why it's so difficult to see them with the naked eye.
Even looking through a large telescope with the naked eye, the objects still appear pretty faint. I myself have vivid memories of viewing Halley's Comet on several occasions over a period of few weeks back in 1986 through a 1-meter Cassegrain reflector and being disappointed at how very faint it appeared through the eyepiece.
So, a quick snapshot of such an object as taken by a telescope, or even by a simple camera pointed at the sky, will only register a faint image of the object, and almost none of the fine filigree detail and colors as seen in pictures like those above would appear in the snapshot. It usually takes at least a few minutes, and as much as several hours of the telescope being pointed at the object, and following it precisely as it moves across the sky, in order to gather enough light in the photographic plate or CCD sensor to arrive at the splendid and colourful images we are lucky to see these days.
Let's imagine that we have at our disposal a particular telescope, which will take six minutes to capture enough light to produce a good image of the Andromeda Galaxy. The sensor would register something very like each of the following images at the end of each 1-minute interval during the exposure:
after 1 minute
after 2 minutes
after 3 minutes
after 4 minutes
after 5 minutes
at the end of the full exposure​
It's only after the full period of the exposure (six minutes in our example here) that the full extent of the galaxy is visible. It takes that long for our telescope to gather enough light to be able to discern the finest details of the galaxy at its' furthest extents.
Again, I hope this helps to explain why images taken by powerful telescopes of extended objects in the sky like galaxies and nebulae look nothing like how they would appear to the naked eye.
(Image: By Adam Evans - M31, the Andromeda Galaxy (now with h-alpha)Uploaded by NotFromUtrecht, CC BY 2.0, https://commons.wikimedia.org/w/index.php?curid=12654493)
Likes Dragrath, Vanadium 50, OmCheeto and 3 others
  • #76
So, a quick snapshot of such an object as taken by a telescope, or even by a simple camera pointed at the sky, will only register a faint image of the object, and almost none of the fine filigree detail and colors as seen in pictures like those above would appear in the snapshot. It usually takes at least a few minutes, and as much as several hours of the telescope being pointed at the object, and following it precisely as it moves across the sky, in order to gather enough light in the photographic plate or CCD sensor to arrive at the splendid and clourful images we are lucky to see these days.
after 1 minute
after 2 minutes
after 3 minutes
after 4 minutes
after 5 minutes
at the end of the full six-minute exposure​
It's only after the full period of the exposure (six minutes in our example here) that the full extent of the galaxy is visible. It takes that long for our telescope to gather enough light to be able to discern the finest details of the galaxy.
Again, I hope this helps to explain why images of extended objects in the sky like galaxies and nebulae look nothing like how they would appear to the naked eye.
Amazing set of images.
Likes Dnj23
  • #77
Too many facts and too little fake news for your taste?
  • Haha
Likes Vanadium 50, OmCheeto, davenn and 1 other person
  • #78
Let's just say.
  • #79
Let's just say.
You started this thread, and people came into try and help out. Plenty of people here, some of whom are practising scientists, and others who have university degrees in relevant scientific areas, have tried to help you out here.
But it would appear that you are not at all prepared to accept the help that you have been given. That's OK, that's your call, but I'm wondering why on Earth you bothered to ask the question "Where am I going wrong with this?" in the first place, and why you've persisted in rejecting help.
Well, you'll get no more help from me. Good luck with your obstinately dismissive attitude.
Likes Dragrath, weirdoguy, Vanadium 50 and 1 other person
  • #80
I don't understand your response.
"So, here's another picture which shows the Andromeda galaxy as it would appear to the naked eye in a not very dark sky -"
  • #81
If anyone had a nice tree in the foreground near sunset, they aren't looking at anything what I'm mentioning.
  • #82
Before we end up with the birds and the bees, and since the question has been answered in all detail, it's time to close the discussion.
Thank you for participating.
Likes weirdoguy, pinball1970 and davenn
  • · Replies 30 ·
  • · Replies 17 ·
9K
  • · Replies 0 ·
  • · Replies 98 ·
  • · Replies 0 ·
