Why Does the Ball Leave the Tray at a Different Time Than Expected?
  • Thread starter Punkyc7
    Ball Spring
17 replies · 5K views · last reply
Punkyc7
A 1.2 kg horizontaal uniform tray is attached to a vertical ideal spring of force constant 195N/m and a 275 g metal ball is in the tray. The spring is below the tray, so it can oscillate up and down. The tray is then pushed down 13 cm below its equilibrium point called point A and released from rest.
how long does it take the ball to leave the tray from point A?
So the time it took should equal T/4+ the time it takes to get to the spot it leaves at
T=.5464
x=Acos([itex]\omega[/itex]t)
x is .07420
A is .13
[itex]\omega[/itex]=sqrt(k/m)=11.4979
solving for t at dsiplacement 0 I get t=.0837
so my total time is .22. Some reason that is not the right answer and i can't figure out where i went wrong
How did you decide that x is .07420 ? The period, T= .5464 seconds looks okay for the tray+ball on the spring.
Where do you suppose the "launch" point is?
the launch point is at point A so -.13m
for x I did -kx=mg
x=mg/k
1.475*9.81/195
=.0742m
for x I did -kx=mg
x=mg/k
1.475*9.81/195
=.0742m
Okay, so your x is the distance above point A where the spring+tray alone are at equilibrium (spring force balances gravitational force on tray). Let's call this point B.
When the tray+ball just pass point B (on the way upwards) the tray is just beginning to experience a deceleration due to the sum of spring and gravitational forces on the tray being zero at point B. This deceleration is still much less than g , so the ball will remain in contact with the tray. It's not until the downward acceleration of the tray begins to exceed g that the ball and tray will part.
So, where will the downward acceleration of the tray be g? Hint: acceleration at g sounds like free-fall...
Punkyc7 said:
but if you use x as .20 you can't take arccos
Why would you be taking the arccos of a distance? Can't have (net) units in the arccos function argument...
Where did your 0.20 (meters?) come from?
because
im solving for t to add it to 1/4 the period.
is that not the right way to go about this.
In this case x must be less than the magnitude of the harmonic motion, A. So x/A is less than one.
Yes and I did that, but my answer is wrong,so I am wondering were I went wrong.
I'm wondering, too. Perhaps you should share your methodology and calculations so that we can puzzle it out.
(arccos(.0742/.13))/sqrt(k/m)=t=.08378
.0837+ .1366=.22sec
.0837+ .1366=.22sec
The question asks for the time from point A to the launch of the ball. You shouldn't have to include the time it takes to go from the spring-compressed position to point A.
Also, if you take the point A to be the zero reference for the motion, and if you set t=0 at that point, the displacement will correspond to a sine function rather than a cosine function.
A*sin(ω*0) = 0
A*cos(ω*0) = A
Punkyc7 said:
So the answer should be .189430 secs
Thank you!
That value looks a bit large to me. What was the calculation?
.1366+
arcsin(.0742/.13)/sqrt(195/1.75)=.05754489
if you round its .19secs
Your total mass value looks high; 1.2kg + 0.275kg = 1.475kg
Why are you adding 0.1366? You only want the time from point A to the launch.
because point A is at 13cm below the equilibrium spot and that is 1/4 of the period
and isn't 1.2+.275=1.475
You had written: arcsin(.0742/.13)/sqrt(195/1.75)=.05754489
So the mass you used was 1.75(kg). Presumably this was a typo?
Point A is the equilibrium level:
...The tray is then pushed down 13 cm below its equilibrium point called point A...
