Why Does This Program Cause a Segmentation Fault?
11 replies · 3K views
gruba
Write a program that reads strings(words) from a text file and copy the inverted words to another file (use the command line arguments). Form a new array of words b from original array a using the function
void formNewArray(char **a, char **b, int n, char* (*t)(char *));
where n is the number of words in array, and (*t) is the pointer to function for inverting a string.
-File handling
-Pointers
The following program gives SIGSEGV segmentation fault in function formNewArray():
Code:
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
void form_temp_array(char **a,char **b,int n,char* (*t)(char *))
  int i;
  for(i=0 ;i<n; i++)
  b[i]=(*t)(a[i]);
char* reverseWord(char *word)
  char *new_word;
  new_word=(char*)malloc(sizeof(strlen(word+1)));
  new_word=strrev(word);
  return new_word;
void print(char **arr,int n)
  int i;
  for(i=0; i<n; i++)
  printf("%s\n",arr[i]);
int main()
  char* a[]={"PROGRAMMING","CODING"};
  int n=sizeof(a)/sizeof(char**);
  char* b[n];
  printf("original words:\n");
  print(a,n);
  printf("reversed words:\n");
  form_temp_array(a,b,n,&reverseWord);
  print(b,n);
  free(reverseWord);
  return 0;
rcgldr said:
In reverseWord(), allocate memory for new word
Code:
    char *new_word = malloc(strlen(word)+1);
In form_temp_array, just assign to b:
Code:
    b[i] =(*t)(a[i]));
Code:
Code:
    b[i] =(*t)(a[i]));
Trying to edit my answer had problems so I deleted it. You can delete your prior post also if you want. The issue is in main: char *a[] points to literal strings, so they can't be reversed, as they could be in write-protected memory. Rather than allocate memory, copy, and reverse in reverseWord(), I thought it would be better to change main(), and allocate memory for each pointer in a and make copies of the literal strings. I used w[] as an array of pointers to the literal strings.
Code:
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
    int i;
    for(i=0 ;i<n; i++)
        b[i] = (*t)(a[i]);
    return strrev(word);         /* or _strrev, depending on compiler */
    int i;
    for(i=0; i<n; i++)
int main()
    int i;
    char* w[]={"PROGRAMMING","CODING"};
    int n = sizeof(w)/sizeof(char**);
    char* a[n];          /* or    char** a = _alloca(n*sizeof(char*)); */
    char* b[n];          /* or    char** b = _alloca(n*sizeof(char*)); */
    for(i = 0; i < n; i++){
        a[i] = malloc(strlen(w[i])+1);
        strcpy(a[i], w[i]);
    print(a,n);
    form_temp_array(a,b,n,reverseWord);
    print(b,n);
        free(a[i]);
    return 0;
I have updated the code, and there is still an error.
Also, I don't think that you can use operator = for string manipulation.
I updated my previous answer to show working code. The issue was that a pointed to literals, so I used an array called w, then in a, I allocated memory and copied the literal strings.
Several problems, the main being:
  • char *new_word = _strrev(word);
    return new_word;
The new_word pointer is a local variable in reverseWord and is not available outside that function (it is allocated on the stack and deallocated when the function returns).
    return new_word;
It doesn't matter, since what is being returned is the pointer to the string from strrev(), not a reference to new_word. Since strrev reverses in place, there's no point in using the returned value, but since it does return the pointer to word, the code can be simplfied to:
Code:
    return new_word;
That would be a problem if the function were returning a pointer to new_word. But it is returning the value. That value will be copied somewhere so it doesn't matter that new_word is lost.
Code:
It can be simplified further by having no reverseWord at all and simply passing a pointer to strrev as an argument.
True, that would be better still. I wasn't sure if it would be OK to use a pointer to a library function for this class assignment. So in main(), it would be:
Code:
    form_temp_array(a,b,n,strrev);
Assume that file1 contains original words, and is the first argument of a command line.
How to read the content of file1 and put the inverses to file2, which is the second argument of a command line?
Thanks for all your help, I have figured out how to do file manipulation.
