Why does u² ∉ ℚ imply [ℚ(u²) : ℚ] ≠ 1?
5 replies · 2K views · last reply
Math Amateur
MHB
I am reading Nicholson: Introduction to Abstract Algebra, Section 6.2 Algebraic Extensions.
Example 13 on page 282 (see attachment) reads as follows:
"If [tex]u = \sqrt[3]{2}[/tex] show that [tex]\mathbb{Q}(u) = \mathbb{Q}(u^2)[/tex]"
In the third line of the explanation - see page 282 of attachment - we read:
"But [tex][\mathbb{Q}(u^2) \ : \ \mathbb{Q}] \ne 1[/tex] because [tex]u^2 \notin \mathbb{Q}[/tex] ... ... "
Can someone explain why it follows that [tex]u^2 \notin \mathbb{Q} \Longrightarrow [\mathbb{Q}(u^2) \ : \ \mathbb{Q}] \ne 1[/tex]
Peter
[This has also been posted on MHF]
Peter
We prove the following general fact.
Let $E$ be an extension of a field $F$.
Let $a\in E$ be such that $[F(a):F]=1$.
Then $a\in F$.
What is the minimal polynomial of $a$ over $F$? It's degree is $1$. So say $x-b\in F[x]$ is the minimal polynomial of $a$ over $F$.
Now we show that $f(a)\in F$ for any polynomial $f(x)\in F[x]$. Note that $f(x)=(x-a)g(x)+r(x)$ for some $r(x)\in F[x]$ with $\deg r(x)=1$. Thus $f(a)=r(a)$. Since $\deg r(x)=1$, $r(a)\in F$ and hence $f(a)\in F$.
We also knew that $F(a)=\{f(a):f(x)\in F[x]\}$ since $a$ is algebraic over $F$.
So we conclude $F(a)=F$ and hence $a\in F$.
Using the above discussion you can easily solve your original problem.
Then $a\in F$.
Thanks caffeinemachine, most helpful of you. Your post enables me to progress on with Field Theory.
Peter
Then $a\in F$.
Hi caffeinemachine,
I was just revising and reflecting on your post and have a couple of points needing clarification.
You write:
"So say $$ x-b\in F[x] $$ is the minimal polynomial of a over F."
Do you mean:
"So say $$ x-a \in F[x] $$ is the minimal polynomial of a over F."?
Further, later in the post you write:
"Note that $$ f(x)=(x-a)g(x)+r(x) $$ for some $$ r(x)\in F[x] $$ with deg r(x)=1."
Given that the divisor (x - a) is of degree 1 does not this mean that the remainder is of degree less than 1, that is deg r(x) = 0?
Can you please clarify these two points?
Peter
Peter said:
Hi caffeinemachine,
You write:
Do you mean:
Peter
Thank you Peter. I see that my solution is messed up. I can't believe I made those mistakes.
Here.
We know that the minimal polynomial of $a$ over $F$ has degree $1$. So say $x-b\in F[x]$ is the minimal polynomial of $a$ over $F$.
(Note: Here I don't mean that $x-a\in F[x]$ is the minimal polynomial of $a$ over $F$. We cannot say this because we don't know yet that $a\in F$. Saying $x-a\in F[x]$ would automatically imply that $a\in F$, but that is what we have to prove!)
Now, since $x-b\in F[x]$ is the minimal polynomial of $a$ over $F$, we know that $a$ satisfies $x-b$. Thus $a-b=0$. thus giving $a=b$. Since $b\in F$ (Why? Simply because $x-b\in F[x]$), we have $a\in F$.
Forget about my previous solution. It is an embarrassment.
Tell me if you have any further doubts.
Here.
Thanks caffeinemachine! as always, I appreciate your help
Peter
