Why is √3 degree 2 over ℚ in ℚ(√2, √3)?
3 replies · 2K views
Math Amateur
MHB
I am reading Dummit and Foote on algebraic extensions. I am having some issues understanding Example 2 on page 526 - see attachment.
Example 2 on page 526 reads as follows:
(2) Consider the field [tex]\mathbb{Q} ( \sqrt{2}, \sqrt{3} )[/tex] generated over [tex]\mathbb{Q}[/tex] by [tex]\sqrt{2}[/tex] and [tex]\sqrt{3}[/tex].
Since [tex]\sqrt{3}[/tex] is of degree 2 over [tex]\mathbb{Q}[/tex] the degree of the extension [tex]\mathbb{Q} ( \sqrt{2}, \sqrt{3} )[/tex] is at most 2 and is precisely 2 if and only if [tex]x^2 - 3[/tex] is irreducible over [tex]\mathbb{Q} ( \sqrt{2} )[/tex]. ... ... etc etc
My question is: why exactly does it follow that the degree of the extension [tex]\mathbb{Q} ( \sqrt{2}, \sqrt{3} )[/tex] is at most 2 and is precisely 2 if and only if [tex]x^2 - 3[/tex] is irreducible over [tex]\mathbb{Q} ( \sqrt{2} )[/tex]?
Although I may be being pedantic I also have a concern about why exactly [tex]\sqrt{3}[/tex] is of degree 2 over [tex]\mathbb{Q}[/tex]. I know it is intuitively the case or it seems the case that the minimal polynomial is in this case [tex]x^2 - 3[/tex] but how do we demonstrate this for sure - or is it obvious? (I may be overthinking this??)
Can someone help with the above issues/problems?
Peter
[Note: This has also been posted on MHF]
Her Peter. This is related to your previous post http://mathhelpboards.com/linear-abstract-algebra-14/field-theory-algebrais-extensions-dummit-foote-section-13-2-a-6694.html
One thing you should always make sure is that whenever you talk about degree of the extension field $K$, you should also mention the field over which you are viewing $K$ as an extension. Here you say that the degree if the extension $\mathbb Q(\sqrt 2,\sqrt 3)$ is is at most two... You didn't mention over which field are you viewing $\mathbb Q(\sqrt 2,\sqrt 3)$ as an extension field.
What we can show is that the degree of $\mathbb Q(\sqrt 2,\sqrt 3)$ as an extension of $\mathbb Q(\sqrt 2)$ is at most $2$. Say $F=\mathbb Q(\sqrt 2)$ and $\alpha =\sqrt 3$. It is easy to see that $\alpha$ is algebraic over $F$ simply because $\alpha$ satisfies $x^2-3$ which is a polynomial over $F$. This also shows that $\deg m_\alpha$, where $m_\alpha$ is the minimal polynomial of $\alpha$ over $F$, is at most $2$. Thus $F(\alpha)\cong F[x]/\langle m_\alpha(x)\rangle$ is a vector space over $F$ with dimension $\deg m_\alpha$. This is same as saying that $[F(\alpha):F]=\deg m_\alpha$. But $\deg m_\alpha\leq 2$ and hence $[F(\alpha):F]\leq 2$. This is same as $[\mathbb Q(\sqrt 2, \sqrt 3):\mathbb Q(\sqrt 2)]\leq 2$.
caffeinemachine said:
Her Peter. This is related to your previous post http://mathhelpboards.com/linear-abstract-algebra-14/field-theory-algebrais-extensions-dummit-foote-section-13-2-a-6694.htmlOne thing you should always make sure is that whenever you talk about degree of the extension field $K$, you should also mention the field over which you are viewing $K$ as an extension. Here you say that the degree if the extension $\mathbb Q(\sqrt 2,\sqrt 3)$ is is at most two... You didn't mention over which field are you viewing $\mathbb Q(\sqrt 2,\sqrt 3)$ as an extension field.
Thanks Caffeinemachine.
So (to repeat your post a bit to emphasize a couple of points) to show that the degree of $$ \mathbb Q(\sqrt 2,\sqrt 3) $$ as an extension of $$ \mathbb Q(\sqrt 2) $$ is at most 2, we take $$ F = \mathbb Q(\sqrt 2) $$ and $$ \alpha =\sqrt 3 $$.Then we argue that $$ \alpha =\sqrt 3 $$ is algebraic over $$ F = \mathbb Q(\sqrt 2) $$ because it satisfies the polynomial $$ x^2 - 3 $$.
$$ x^2 - 3 $$ is a polynomial over $$ F = \mathbb Q(\sqrt 2) $$ because its coefficients (i.e. 1 and 3) are both in $$ \mathbb Q(\sqrt 2) $$
that is $$ \ 1 = 1 + 0 \star \sqrt 2$$
and $$ 3 = 3 + 0 \star \sqrt 2 $$
Then, given the above we have $$ [ \mathbb Q(\sqrt 2,\sqrt 3) \ : \ \mathbb Q(\sqrt 2)] \le 2 $$ ... ... ... ... ... (1)
Now, similarly we can show that $$ [ \mathbb Q(\sqrt 2) \ : \ \mathbb Q] \le 2 $$ ... ... ... ... ... (2)
and the equality is actually the case in both (1) and (2) above because the polynomials concerned are irreducible (is that correct?)
So we have the following
$$ [ \mathbb Q(\sqrt 2,\sqrt 3) \ : \ \mathbb Q(\sqrt 2)] = 2 $$
and
$$ [ \mathbb Q(\sqrt 2) \ : \ \mathbb Q] = 2 $$
So
$$ [\mathbb Q(\sqrt 2,\sqrt 3) \ : \ \mathbb Q] = [ \mathbb Q(\sqrt 2,\sqrt 3) \ : \ \mathbb Q(\sqrt 2)] \ [ \mathbb Q(\sqrt 2) \ : \ \mathbb Q] = 4 $$
Can someone confirm that the above reasoning is correct ... or not?
Peter
and
So
Peter
Yes. This is correct. Only thing, I think you need to fill in some details as to why the polynomials in question were irreducibles. Otherwise it's fantastic.
