Why Does Using an Uninitialized Pointer Cause a Segmentation Fault in Recursion?
  • Context: Comp Sci
  • Thread starter Thread starter anonim
    Function Recursion
4 replies · 2K views
anonim
Calculate the Math Formula
C:
double foo(int arr[], double *ave, int index){
  double *s;
  *s=*ave;
    // calculation//
    return(foo (arr,ave,index));
// other calculation//
I want to keep the ave value during the recursion, because after ave is calculated, I will do another calculation is recursively in this function. But I write like this, I am getting segmentation fault.
on Phys.org
anorlunda said:
Hint: How many levels deep will the recursive calls go in your code?
I did not understand what you say. the function will call itself about 560 times
Based on what you posted, the function will run until there is no more stack memory for it.
anonym said:
C:
  double *s;
  *s=*ave;
    // calculation//
Right, and @anorlunda's hint might have something to do with why you're getting this fault.
Are there any conditions in which the function returns without calling itself? You don't show any in this code snippet. In particular, how does the part you have commented as "other calculation" actually get executed?
anonim said:
Homework Statement:: Calculate the Math Formula
Relevant Equations:: -
C:
  double *s;
  *s=*ave;
    // calculation//
You're assigning to the address of an uninitialised pointer:
C:
  double *s;
  *s=*ave;
Why is s a pointer here?
