Why does vacuum energy density cause repulsion in Friedmann equations?
  • Level: Graduate
  • Thread starter Helpsearcher
    Density Energy
Helpsearcher
Hi there,
I really hope someone can help me with my stupid but urgent problem of understanding something crucial about the Friedman equations.
So; one of them looks like this (forget about the constants; it is about the principles):
change of the scale factor with time - density - cosmol. constant = -k (curvature term)
Then this is sometimes rewritten in terms of densities, which gives:
change of the scale factor with time - (density of matter + vacuum energy density) = -k (curvature term)
Now; here is what I do not get.
Generally the density of the vacuum (or equivalently the cosmol. constant) are treated just like the density of matter; so they have the same effect on the curvature, which somehow should be understandable as energy=matter and so both curve the spacetime.
But then, it is usually stated that the cosmol. constant, and so the vacuum energy density, are working against gravitation (repulsive).
However; I do not understand, how to see this in the equations above. I mean; both seem to have the same effect: energy=matter -> attraction (simplified).
Where is my error of thinking?
I really hope that someone here can enlighten me.
Thx
Cosmological gravitational repulsion means that ##\dot{a}##, the rate of change of the scale factor, is increasing. i.e., that ##\ddot{a}## is positive. The Friedmann equation about which you wrote is
$$\dot{a}^2 = \frac{8\pi}{3} \rho a^2.$$
Differentiating this equation with respect to time gives
$$2\dot{a}\ddot{a} = \frac{8\pi}{3} \left( \dot{\rho} a^2 +2\rho a \dot{a} \right).$$
Consequently, there is cosmological repulsion when ##0 < \dot{\rho} a^2 +2\rho a \dot{a}##.
It is somewhat difficult to see what is going on from this, but a couple of things can be noted:
1) in an expanding universe, there is no gravitational repulsion only when ##\dot{\rho} a^2## is sufficiently negative (as it is for normal matter);
2) for an expanding universe that consists solely of vacuum energy, which has ##\dot{\rho} = 0##, there is repulsion, since then ##\ddot{a} > 0##.
Things become a little clearer when the other Friedmann equation is considered,
$$\ddot{a} = -\frac{4\pi}{3} \left( \rho + 3p \right) R.$$
Clearly, ##\ddot{a} > 0## when ##w = p / \rho## is less than -1/3. Vacuum energy/cosmological constant has w = -1.
Roughly, (for non-exotic matter that has positive energy density) repulsion happens when pressure is sufficiently negative.
Hi;
thank you for the answers.
I totally missed (or have overseen) the second more important equation in this context (the second derivative), which shows the dependencies on the pressure terms.
Will have a deeper look into now that the examination is over. :) Was a little confused the day before.
Thx
