Why does wave amplitude indicate particle location in QM?
The discussion revolves around the interpretation of wave amplitude in quantum mechanics (QM) and its relation to particle location. Participants explore the conceptual framework of wave functions, probability densities, and the nature of particles and waves in QM, addressing both theoretical and conceptual aspects.
  • Some participants question why wave amplitude is associated with the likelihood of finding a particle rather than describing the wave itself.
  • Others assert that there is no such thing as "the wave from the particle," arguing that waves do not have a single spatial location.
  • A participant references a video that illustrates the wavefunction as a probability density for locating a particle.
  • Concerns are raised about the origin of wave amplitude, with some suggesting it describes probabilities for measurement results rather than originating from particles.
  • Some participants argue that each particle contributes to the overall wave function, while others dispute this, stating that the wave function describes the system as a whole.
  • There is a discussion about the implications of adding particles to a system, with conflicting views on whether this is a valid operation in non-relativistic QM.
  • Participants express uncertainty about the meaning of wave amplitude and its relationship to particles, with some emphasizing that the wave function does not represent a wave with a source.
  • Technical details are provided regarding the mathematical formulation of wave functions and their probabilistic interpretations.
Participants express multiple competing views regarding the interpretation of wave amplitude and its relationship to particles. There is no consensus on the nature of wave functions, their origins, or the implications of adding particles to a system.
Discussions include unresolved questions about the definitions and assumptions underlying wave functions and their interpretations. The debate touches on the limitations of classical analogies in describing quantum phenomena.
kurt101
TL;DR
Why do we say that wave amplitude tells us where we are likely to find the particle versus where we are likely to find the wave from the particle?
Why do we say that wave amplitude tells us where we are likely to find the particle versus where we are likely to find the wave from the particle? Isn't the later a more accurate description of the QM math?
Because, first, there is no such thing as "the wave from the particle", and second, waves don't have a single spatial location anyway.
No.
Have a look at this video. I'm amazed every time I watch it. To me, the video shows why it is natural think of the wavefunction as giving the probability density for finding a particle at a location.
If the wave amplitude does not come from particles, where does it come from? (in the QM mathematical sense)
I don't know what you mean by this.
  • Skeptical
It doesn't "come from" anywhere. The wave function describes the probabilities for different possible measurement results. That's just what the wave function is.
If I ask you what the position of a wave is, what's your answer? There isn't one: the concept doesn't make sense. A wave doesn't have a single particular position the way a particle does. So it doesn't make sense to talk about the probability of finding a wave in a particular position, the way it makes sense to talk about such a probability for a particle.
Each particle contributes to the overall wave function of the system and so the wave function comes from the particles.
But it does make sense to talk about the contribution to the amplitude at a specific location from a wave source. If you have a particle in a system and then you add a second particle that second particle changes the probability amplitudes in the system. What could have changed the probability amplitudes in the system in this case other than a wave source?
  • Skeptical
No, they don't. Each particle is a degree of freedom of the system, and the wave function describes probabilities for the system. There is no general sense in which the individual particles "contribute" to the wave function.
No, it doesn't.
But the quantum wave function is not a wave with a source. It's not radiation. It's a different thing.
No. In ordinary non-relativistic QM you can't add particles to the system. You have to include all the particles at the start.
In relativistic QFT, particles can be created or destroyed, but "particles" aren't fundamental anyway; quantum fields are. "Adding a particle" is just a particular quantum field operation. Viewing it as "changing the probability amplitudes in the system" is not a useful way to view what is going on.
Your whole conceptual scheme here seems to be wrong. This question isn't even answerable.
kurt101 said:
If the wave amplitude does not come from particles, where does it come from? (in the QM mathematical sense)I don't know what you mean by this.
In non-relativistic quantum mechanics you can describe some quantum states (the socalled pure states) of a particle by the wave function ##\psi(t,\vec{x})##. It's physical meaning is that
$$P(t,\vec{x})=|\psi(t,\vec{x})|^2$$
is the probability density for the position of the electron when observed at time, ##t##.
I've no clue what you mean by "the wave amplitude comes from pariticles".
There are two choices. Either the wave function for a system of two particles is the same as the wave function for a system with one particle or it is different.
Particles are not degrees of freedom of the system. The particle is the system. If it's prepared in a pure state, in non-relativistic QM the particle can be described by a wave function ##\psi(t,\vec{x})##, which obeys the Schrödinger equation,
$$\mathrm{i} \hbar \partial_t \psi(t,\vec{x})=\hat{H} \psi(t,\vec{x}),$$
where ##\hat{H}## is the Hamilton operator (in position representation). For a particle in an external potential it reads
$$\hat{H}=-\frac{1}{2m} \hat{\vec{p}}^2 + V(\hat{\vec{x}})=-\frac{\hbar^2}{2m} \Delta + V(\vec{x}).$$
The physical meaning is that
is the probability density for observing the particle at ##\vec{x}## at time, ##t##.
As demonstrated by the nice Youtube movie (though it uses photons rather than particles, where the description with a wave function is impossible and QED must be used, but the qualitative picture is of course the same, i.e., you can for sure find movies of this kind, where massive particles, electrons in the non-relativistic regime are used), a single particle does not appear as some "smeared cloud" but manifests itself as making one dot when registered by the detector (here obviously a scintillation screen or something similar, unfortunately the Youtuber doesn't give a scientific reference/paper, where to find the details of the experiment). Only when accumulating a lot of equally prepared particles going through the slits the predicted probability distribution forms. It clearly shows and interference pattern as the Schrödinger equation predicts.
Of course, also the wave-particle duality is resolved since 1926 with Born's probability interpretation, but that's another story.
PeterDonis said:
No, it doesn't.But the quantum wave function is not a wave with a source. It's not radiation. It's a different thing.
Indeed it's a representations of a single-particle pure quantum quantum state with the above given probabilistic meaning.
Here you simply have one particle at a time going through a double slit and being registered at the scintillation screen (and it's position stored).
Indeed, and photons cannot be in any sense interpreted as particles. They don't even admit the definition of a position observable in the strict sense. Nevertheless, what also QED provides in this case of the double-slit experiment is the probability for detecting a photon at a certain place on the screen (it's given by the energy density of the electromagnetic field), and this forms an interference pattern when many single photons are used. It's similar as for particles, although there's no "wave function" for photons.
I think the standard formulation of QT perfectly answers the somewhat vague question in #1.
The wave function ##\psi(t,\vec{x})## in your own words "describe some quantum states of a particle". ##\psi(t,\vec{x})## is a function about waves and waves have amplitude. How can amplitude from the equation ##\psi(t,\vec{x})## come from anything but particles?
  • Skeptical
Obviously it is different since the two wave functions are on two different Hilbert spaces (the one-particle Hilbert space and the two-particle Hilbert space).
I was a bit sloppy there, yes. A more precise statement would be: for each particle in the system (if we are using non-relativistic QM), there are three degrees of freedom corresponding to its position/momentum configuration space, plus however many more degrees of freedom it takes to describe their internal properties (like spin).
In non-relativistic QM, this is true as you state it for a one-particle system. For multi-particle systems, the particles can be viewed as subsystems.
kurt101 said:
##\psi(t,\vec{x})## is a function of waves
No, it isn't, it's a wave function. What the wave function is a function of is time ##t## and the particle coordinates ##\vec{x}##. It's not a function of waves.
This has already been answered: the whole idea doesn't even make sense. Your conceptual scheme for this is wrong. You need to discard it and adopt a better one.
I wasn't referring to the the parameters of the wave function. I made the correction.
Your "correction", I presume, is this?
If so, it doesn't change anything. Your next question is:
The amplitude (squared) gives the probability of finding the system at time ##t## at the position described by ##\vec{x}##. It doesn't "come from" anything. It's just a function giving the probability.
Again, your whole conceptual scheme about this appears to be wrong. Continuing to ask questions based on that wrong conceptual scheme will not change anything.
The OP question has been answered and the thread is going around in circles. Thread closed.
  • · Replies 109 ·
11K
  • · Replies 19 ·
  • · Replies 27 ·
  • · Replies 105 ·
9K
  • · Replies 35 ·
  • · Replies 19 ·
