Why does x² + x + 1 have no root in ℤ₄?
4 replies · 2K views · last reply
Math Amateur
MHB
I am reading Chapter 2: Commutative Rings in Joseph Rotman's book, Advanced Modern Algebra (Second Edition).
I need help with Exercise 2.47 on page 114.
Problem 2.47 reads as follows:
View attachment 2692I need help with showing that $$f(x)$$ has a root $$ \alpha \in \mathbb{F}_4 $$.
My work on this part of the problem is as follows:
The elements of $$ \mathbb{F}_4 $$ are 0, 1, 2 and 3.
Now we proceed as follows:
$$ f(0) = 0^2 + 0 + 1 = 1_4 \ne 0_4 $$
$$ \Longrightarrow 0_4 $$ is not a root of $$f(x)$$ in $$ \mathbb{F}_4 $$
$$ f(1) = 1^2 + 1 + 1 = 3_4 \ne 0_4 $$
$$ \Longrightarrow 1_4 $$ is not a root of $$f(x)$$ in $$ \mathbb{F}_4 $$
$$ f(2) = 2^2 + 2 + 1 = 7_4 \ne 0_4 $$
$$ \Longrightarrow 2_4 $$ is not a root of $$f(x)$$ in $$ \mathbb{F}_4 $$
$$ f(3) = 3^2 + 3 + 1 = 13_4 \ne 0_4 $$
$$ \Longrightarrow 3_4 $$ is not a root of $$f(x)$$ in $$ \mathbb{F}_4 $$
... ... BUT I seem to have shown (wrongly I'm sure!) that f(x) has no root in $$ \mathbb{F}_4 $$?
Can someone please help me with this issue?
Peter
Uh..."2" and "3" DO NOT EXIST in $\Bbb F_4$.
The elements of $\Bbb F_4$ can be written as $0,1,a,a+1$ or: (using vector notation) as $(0,0),(1,0),(0,1),(1,1)$.
Let's use the former to show that $a$ is a root of $x^2 + x + 1$.
As you may recall from a prior post, we have:
$a^2 = a\cdot a = a+1$.
Thus:
$a^2 + a + 1 = (a + 1) + (a + 1) = (1 + 1)(a + 1) = 0(a + 1) = 0$.
In fact, $a + 1$ is the "other root":
$(a + 1)^2 + (a + 1) + 1 = (a + 1)(a + 1) + (a + 1) + 1 = (a + 1 + 1)(a + 1) + 1$
$= (a)(a + 1) + 1 = a^2 + a + 1 = 0$ (by the above).
Indeed:
$(x - a)(x - (a + 1)) = (x + a)(x + (a + 1))$ (since $\Bbb F_4$ has characteristic 2)
$= x^2 + x(a + 1) + ax + a(a + 1) = x^2 + (a + 1 + a)x + a^2 + a$
$= x^2 + ((a + a) + 1)x - 1 = x^2 + ((1 + 1)a + 1)x + 1$ (remember, $1 = -1$)
$= x^2 + (0a + 1)x + 1 = x^2 + x + 1$.
The 4-element field is NOT $\Bbb Z_4$, which is NOT a field, because it has ZERO DIVISORS (zero divisors cannot have inverses, but they ARE non-zero, and in a field EVERY non-zero element HAS to have an inverse).
Explicitly:
$[2]_4 \cdot [2]_4 = [0]_4$, but $[2]_4 \neq [0]_4$.
Thus:
Indeed:
Explicitly:
Thanks for the help Deveno ... ... I certainly need to get a better understanding of finite fields ...
Peter
There are 3 main ways to look at a finite field.
The first way is to focus on the addition. The first thing that one can show is that the subgroup of $(F,+)$ generated by $1$ is ALSO a field, called the PRIME FIELD of $F$. There is a reason for the name "prime":
$\langle 1\rangle \cong \Bbb Z_n$ for some natural number $n$, this number is called the CHARACTERISTIC of the field.
Since $\Bbb Z_n$ forms a ring under multiplication, we see that $\langle 1\rangle$ forms a sub-ring of $F$. Let's call this ring $P$.
Now every non-zero element of $P$ is a unit (since this is true of $F$). This tells us something special about $n$: it must be prime. Why?
Well, if $n = ab$, for positive integers $1 < a,b < n$, we have:
$(a1)(b1) = (ab)1 = n1 = 0$, so $a1 \neq 0 \in F$ is a zero-divisor. But $F$, being a field HAS no zero-divisors. This means $n$ cannot be composite, and $n = 1$ is not a possibility, since in a field, $0 \neq 1$.
So $P \cong \Bbb Z_p$, for some prime $p$. And this is a field.
Now $F$ can be made into a $P$-module in a natural way- define, for $a \in P$, and $x \in F$:
$a\cdot x = ax$, where the RHS is the multiplication in $F$.
Since $P$ is itself a field, $F$ is a $P$-vector space. If we choose a basis: $\{x_1,x_2,\dots,x_n\}$, it is clear we get:
$|P|^n = p^n$ distinct vectors in $F$, that is: $|F| = p^n$, where $n$ is the cardinality of the basis.
In this view, addition is trivial: we just "add the coordinates". Multiplication, however, is somewhat of a mystery.
The second way is to focus on the multiplicative group: it turns out that the multiplicative group of a finite field is CYCLIC, and therefore has a generator (called a PRIMITIVE, or primitive element). Now the multiplication is trivial, but addition is brutal.
The third way ties the two together: We start with the ring $Z_p[x]$, and choose an irreducible polynomial $f(x)$ of degree $n$. It is clear, then, that $Z_p[x]/(f(x))$ is a finite field with $p^n$ cosets. In fact, ALL finite fields arise this way. This allows us to express elements of this field as "polynomials in $u$", where $u$ is a root of $f(x)$ (which corresponds to the coset $x + (f(x))$).
Thanks so much Deveno ... ... Really great overview/tutorial on finite fields ... Just working through it carefully now ... ...
Peter
