Why doesn't a photon's mass increase to infinity?
  • Context: Undergrad
  • Thread starter Thread starter Francis Ward
    increase Infinity Mass
64 replies · 6K views
Dr Whom said:
So besides their position they do not change or undergo any entropic increase or equivalently experience time. Which is precisely what I stated in the first place. Elementary SR.
Photons do not exist in elementary SR. You need QFT for that. Furthermore it is generally not relevant to talk about what is “experienced by” a classical massless particle, since it has no rest frame.
Also, photons do not have a well defined position operator.
Dr Whom said:
In what way do you believe photons change during their travel?
In a curved spacetime, their frequency/wavelength changes as they travel.
Dr Whom said:
By moving only on spacelike worldlines at the speed of light no time passes. Basic SR.
Please quote correctly. This was something you wrote, not something Peter wrote. It's also incorrect - light travels on null worldlines, not spacelike ones, and proper time is not defined along them. Coordinate time is, though. So a correct statement would be that proper time is not a concept that applies to light.
Redshift is the obvious one.
Dr Whom said:
If they did then the information they contain would be compromised making all observational data unreliable. .
It seems like you are saying that only things traveling on null worldlines can carry information. If you are claiming that, could you explain how a CRT monitor works? If you are not claiming that, could you say what you do mean?
girts said:
@nitsuj, I think we can measure the energy from even a single photon IIRC, but what has that to do with it's mass (even if there is some) ?
thinking that radios, eyes and other thing don't get more massive from absorbing more photons. That their energy is "free" of mass; is massless.
if the incoming photons' momentum net to zero on the body does that add to the mass of the body
Orodruin said:
No. You can never measure anything exactly. Measurements are always subject to measurement errors leading to uncertainties.
What about, are the errors and uncertainties known; their causes? I'd consider the uncertainty principle to be a known unknown and kind of irrelevant with respect to experimental errors. Surely for the equipment and other parts of the experiment the source of the errors are known, mitigated and corrected for as reasonable.
Mass is not additive. The mass of an object that has absorbed a photon will be greater than the sum of its original mass plus the [zero] mass of the original photon.
This is an observer effect, not an effect inherent to the light signal. The wavelength also changes if the observer changes velocity but it is still the same light signal. The 4-frequency is parallel transported along the signal world line, which is as close to saying “does not change” as is possible.
I am not talking about the uncertainty principle. If you knew what the measurement errors were they would not be measurement errors. There are errors that you simply cannot get around. You might know their distribution but there is no way you can know exactly how a particular measurement was affected.
This is a fair point; but it's worth noting that the same statement would apply to the 4-velocity of a timelike object moving on a geodesic. So this definition of "does not change" does not have the implications that @Dr Whom is thinking it does.
Imagine a laser beam traveling a cosmological distance, doing a U-turn around a black hole, and returning to source. The returned beam will not have the same frequency as the enmitted beam as measured by the source (in general). I agree that all that's happened is that the photon has had its four momentum rotated, but I have difficulty not regarding that as a change.
Can we stop calling it “photon”? It hurts my eyes. :rolleyes:
This is about the spacetime curvature. Of course the observer will see a different direction but there are many reasons for this. First of all, the spacetime event of emission is not the same as that of reception so you have to define what “change” means by means of parallel transport or Fermi transport of the observer frame. The spacetime curvature implies that transports will depend on the worldline, so it is not strange to find that the signal travels in a different direction according to the observer. Still, it is an observer effect. You can find any direction and frequency you like simply by changing observer.
I agree, I just wanted to point out that many people seem to think that “frequency” is some inherent property of a light signal, but it is not.
The simple answer, photons have zero rest mass. Rindler, Essential Relativity.
So, to explain why I raised this question in the first place. I am not a physicist (you all fall back in amazement at that revelation - not). I read books by physicists (currently Max Tegmark - Mathmatical Universe) and I find myself questioning so much that is taken for granted. Not out some desire to question for question sake, but to try to understand. So the photon question - to which we really do not have any definitive answer, is just the microscopic end of the questions. Einsteins mass/energy equivalence, which I understand is proven experimentally, says that if an object increases in energy, it also increases in mass. Hence the rubber band analogy used by Brian Cox. So, if we take the question of a person traveling in a vehicle (his frame of reference), regardless of the speed of the vehicle, relative to his frame of reference, the person is stationary. Outside the frame, he in fact has increased kinetic energy. Therefore his mass should increase. Is this actually what happens, or does his mass remain the same? Take the scenario to it's ultimate conclusion, with the vehicle traveling close to the speed of light, the observer in the vehicle still feels stationary ... but what about his mass?
This is not about mass, it is about relativistic mass. Please see https://www.physicsforums.com/insights/what-is-relativistic-mass-and-why-it-is-not-used-much/
Mass is relative. In the stationary frame the man's mass is his rest mass, a constant. Relative to any frame in which he is moving, his mass is greater.
P.S. as for walking on water, use floating boots or a giant hamster ball. The last is great fun:)
In the modern usage of the word "mass", this is false. Again, the mass that is increasing is the relativistic mass. Relativistic mass is a concept that is largely not used by professional physicists.
Can relativistic mass be measured?
Why is concept of relativistic mass not used?
Relativistic mass is just a rescaling of an object's energy by a factor ##c^2##.
Please read the PF Insight linked to in #43.
Off the point. Petty semantics. As a professional physicist I have no problem with this term.
You regard the distinction between the modulus of a vector and one of its components as "petty semantics"?
Dr Whom said:
Petty semantics.
It is not petty semantics. It is a question of both accuracy in communication as well as pedagogy. Having taught advanced relativity courses for years I can tell you that relativistic mass is clearly up there together with not understanding relativity of simultaneity in what people get wrong. Among laymen it leads to the misconception that an object somehow changes when it gets faster, making them draw the unfortunate conclusion that you can tell if an object has absolute motion by looking at its mass. Among professionals, it has no place because professionals discussing properties of objects generally prefer to talk about invariant properties.
I do not know what field you are in, but in fields where it matters (i.e., mainly high-energy physics) you will not see a single paper mentioning "mass" with the meaning of "relativistic mass". If you go about teaching people about relativistic mass, you are doing them a disfavour in my opinion.
You believe mass is a vector?
No, where did you get that from? Mass, as defined in SR, is the modulus of the 4-momentum of an object. Relativistic mass (or, better, just "energy") is the time-component of this 4-momentum.
Which in the rest frame is the rest mass, or as you prefer rest energy, and is greater in ones in which it moves. As I stated originally.
P.S. I also checked the definition of four momentum in Rindler, Essential Relatvity. This is also mixes momentum, mass and energy in its definition. I made some margin notes years ago when I first noticed the inconsistency. There is a simple test for consistency in physics, that of the units. For a four vector to have a modulus, which it must, all components have to have the same units. The forth term in the four momentum is mc, not m. This may be a simple matter of missing universal constants out of expressions, a habit that oft times creates problems.
Relativistic mass is just a rescaling of an object's energy by a factor c2
So it cannot be measured? And an object inside a vehicle traveling at speed has no increased energy over an object at rest, relative to it's frame of reference?
You are missing the point. There's a distinction between invariant mass and relativistic mass - I see you understand this. But which one you mean when you say just "mass" is not petty semantics, and you are using it in the opposite sense to the vast majority of the professional physics community.
It can be measured - just measure the energy.
This is confusingly written, because you're talking about "travelling at speed" and frames of reference without making clear what's moving with respect to what. If you do make it clear, the question pretty much answers itself.
I think you are imagining one object sitting on a table and an identical object sitting in a car that drives past the table. From the point of view of the table, the object in the car is moving so has more energy than the one on the table. From the point of view of the car it's the object on the table that's moving. So in this frame each object has the same energy that the other object has in the table frame. It's symmetrical.
No, I am saying that an object inside a car that is traveling at speed, has no greater energy than an object sitting in a car that is not traveling at speed relative to the objects frame of reference, which is the car
No one is disagreeing with that. We all agree that an object's kinetic energy in the frame of reference in which it is at rest is zero.
That does not prevent you from measuring the kinetic energy of a bullet in the frame of the target.
I did not say anyone was disagreeing with it. I was clarifying the confusing way I had written my earlier post.
Where did the bullet come in?
