Why doesn't the Moon spin on its axis?
  • Level: High School
  • Thread starter Thread starter RichD
    Moon Spin
61 replies · 42K views
RichD
If someone is going to answer this with "Why should it" then Why does the Earth (and many planets) spin on their axis?
I'm sure someone told me the answer once, but I can't remember, and it's bugging me...
Astronomy news on Phys.org
It does spin (with a period of about 28 days), that's why we always see the same side as it revolves around the earth.
To anticipate your next question of "Why does the moon rotate in the the same time as it orbits the Earth?", the answer is "tides".
Just as the Moon causes tides on the Earth, the Earth exerts a tidal force on the Moon. This force tends to stretch the moon out online the line joining it to the Earth.
At one time, the moon spun at a much higher rate then it does now. But the action of the Earth's tidal force on it caused friction which slowed it down unitl it reached the state iti is in now where it always faces one side towards the Earth.
(Actually, the moon kind of rocks back and forth in a motion called Libration. This is caused by the fact that the Moon does not have a perfectly circular orbit, and therefore its rotation will lag behind or speed ahead a little of its orbit at different points. )
The Moon's tides are also slowing the Earth's rotation, but since the Earth is some 81 times more massive that the Moon, it will still take some few billion years before the Earth always presents one side to the Moon.
Thanks Guys
I really should have thought about the 28 day period, that makes perfect sense!
The anticipated answer was very interesting though, thanks for that.
Well that want happen, because our friend Moon is going to leave us before that date. Reason: tides again.
While the Moon is receding due to this process, it will never leave Earth orbit completely because of it. The Earth should become tidally locked with the Moon by the time the Moon's orbit has increased by about 1.6 times its present distance and its oribtal period has increased to about 2 months.
In order for the Moon to break free of the Earth and follow it own independent orbit around the Sun, it would have to recede to more than 2.4 times its present distance.
But it is true that the Earth will in all likelyhood never become tidally locked with the Moon, but for another reason.
Before it happens, our Sun will expand into a Red giant, engulfing both the Earth and Moon.
"It does spin (with a period of about 28 days), that's why we always see the same side as it revolves around the earth."
Wrong.
Earth, during it's formation didn't have a moon, but there was a massive collision of some sort sending tons of Earth into space. The debris orbitted the Earth and beganm to form the moon. Whilst the moon was forming, not only was the debris affected by the forming moon, but by the Earth's gravity. As a result one side of the moon is heavier and this has 'calibrated' the moon's orbit so that it always faces the earth.
The moon does 'spin' in a way. Though in reality it wobbles negligibly from side to side undergoing simple harmonic motion.
I think.
Lunar rotation matches solar one
I have noticed that the period of rotation of the moon pretty well matches the average rotational period of the sun, something like 28.35 days I think. I think they match to within a couple of percent.
The Sun has an 'average' period because it is fluid, and the north and south polar regions don't rotate at the same angular rate as the equator.
It seems unlikely to be a coincidence. The moon's period may have gradually tuned itself to the sun's, possibly via (earthly?) tidal mechanisms. Sorry if this is well known.
Wrong.
I think.
the_truth
While you are correct that the moon probably formed as a result of a massive collision during the Earth's early formational period, you are incorrect about the moon not spinning. Janus' explanation is correct.
Visualize it with 2 coins (both face-up). Now have one coin "orbit" the other, keeping the face toward the second coin at all times. You'll see that, in order to do this, it spins on its axis once per revolution around the other coin.
You are also correct that the moon does have a "wobble", called libration. Here's an awesome movie clip of the effect...
http://antwrp.gsfc.nasa.gov/apod/ap010218.html
It's not quite "negligible" (except of course to the casual observer) as it allows us to view about 59% of the moon.
eek, I said 'Wrong.' in an arrogant manner.
During the formation of the moon, centripetal acceleration would have negated any effects of gravity the Earth would have on the forming moon. Also the original rotation of the moon would have prevented it's elliptical orbit from making the moon a 'pear' shaped body.
I noticed this a few moments after I got up and walked away from the computer.
Kepler's laws
Try this;
Assume the moon is a sphere and you could suspend it from its geometric center (the center of its core); in a uniform gravitational field it would hang earth-side-face down.
Whatever the moon's origin (capture by or collision with the earth) it is unlikely to have remained molten long enough to become absolutely homogeneous (mass distributuon wise) and therefore its center of mass does not correspond with its geometric center.
A line from the center of the Earth would pass through the moon's center of mass on its way to the moon's geometric center. If the moon's two centers DID correspond, then the moon could spin at any rate on any axis it chose.
Kepler's laws relate to the centers of mass of astonomical objects... not their geometric centers.
That's also incorrect. As Janus explained, the cause is tidal locking. Many other bodies in the solar system exhibit the same behavior, for the same reason.
- Warren
The Sun's period of rotation is 24.6 days
The Moon's sidereal period(fixed star to fixed star) is 27.32 days, this is a difference of 10% not just a couple of percent.
The Moon's synodic period(full moon to full moon) is 29.53 days for a difference of 20%
And even this situation is temporary. As the Moon is moving slowly away from the Earth, its period of revolution is getting longer.
So yes, it is just a coincidence, and not even a very good one at that.
Just a few points on the moon's Librations. There are four: libration of Latitute, libration of longitude, diurnal libration and physical libration. Only the last, and smallest of these is due to any actual "wobble" by the Moon itself.
Libration of latitude is due to the Moon's equatorial inclination to its orbit. We alternately see the Moon's North pole and South pole depending upon which point is is at in its orbit when we see it. (Much the way the Sun shines alternately on the North and South pole of Earth over the course of a year.)
Libration of longitude is due to the fact that while the moon's rotation rate is constant, it orbital speed is not. As the Moon approaches perigee it speeds up in its orbit, and as it approaches apogee it slows down. As a result, the Moon's rotation(which remains constant) lags behind and speeds ahead during the course of a month. This allows us to see an additional few percent of the Moon's surface.
Diuranl Libration is due the fact that over the course of time from moonrise to moonset we see the Moon from different angles as the Earth rotates. Thus allows us to see about 2% more of the Moon.
Physical Libration is due to the the fact that the moon is not perfectly spherical(it is slighty elongated towards the Earth), and that the librations of latittude and longitude cause the Earth's gravity to tug slightly off-center of this elongation. This actually causes a small alternating change in the Moon's rotation. This libration only amounts to about a mile on the Moon's surface.
Reply to Janus
I think you are referring to the Sun's Sidereal period, whereas I was referringto it's synodic period.
If you take the synodic period (which is the natural one to look at from the point of view of it's effect on earthly and lunar issues, I think you will find it is very close to 27.32, probably 27.35 (I may well have mis-remebered it as 28.35 instead of 27.35)
You mention both of the moons periods, why ignore the two solar periods, and pick the wrong one to boot?
Fine, the Sun's synodic period is 26.37 days. Using your own line of reasoning, we should then compare this to the synodic month. This still gives us a difference of 12%
Besides that, you are ignoring the fact that the Moon's present orbital period is transistory, In the past it was shorter and in the future it will be longer.
One billion years ago it was about 23 days, and in one billion years it will be about 31 days.
So once again, mere coincidence.
Reply to Janues
I agree it is hard to deduce an accurate figure for the average synodic period of the sun, but all the figures I have seen are around 27.3 days, not 26.something days, can you support the figure you have given? Perhaps your figure is the period for the sun's equator, whereas I am referring to the average for the whole volumne of the sun (ie the _effective_ period in relation to the mass of the sun)
It is not necessarily logical to always compare two synodic periods, and I think you argument in this regard is somewhat weak (relying on your assumption of how my logic would work without knowing me, rather than anything else).
Also, we don't know the period of the Sun's rotation millions of years into the future or past, the relationship may have been maintained over that period by mechanisms that have not occurred to you in the last 24 hours.
For example, the synodic period may have changed due to changes in the Earth's orbit. If there was some kind of tuning mechanism, it may keep things in step somehow.
According to my figures, the sun's average synodic rotation period is 27.3 +- about 0.05 days, and the moons sidereal period is about 27.35, which is a little bit too much of a coincidence to dismiss out of hand.
Of course, you may well be right, it could be coincidence, but you originally objected to this idea based on a solar period of 24.something days, you are allowed to show some flexibility and change you mind in the face of new information you know :)
IF there was a connection between Solar rotation and Lunar period (really big if) it would be synodic to synodic or sidereal to sidereal. Not synodic to sidereal.
The synodic month is conjunction to conjunction. thus it is the period between times when the Earth, Moon and Sun have the same relative positions to each other, and the one, if any, to be synchonized to the rotation of the Sun.
So even if we take the 27.3 day figure (mine was from a quick calculation comparing the Sun's rotation to the Earth's orbital period), you still end up with an 8% variation.
The rate of the Moon's recession(and thus the increase of period) is linked to the relative masses of the Earth and Moon, and thus would have no connection to the Sun's rotational period.
So, no, until a feasible mechanism is discovered to explain a physical connection between the Moon's and Sun's respective periods, I see no reason to assume one. Mere coincidence in numbers(even close ones) are not enough.
Reply to Janus
So you now accept that the Moon's sidereal period of 27.35 days is within 2% of the Sun's synodic period of 27.3 days?
... and the three inner Galilean moons of Jupiter take 'locking' a step further - not only do Io, Europa, and Ganymede have synchronous rotation (same face to Jupiter, just like the Moon), but their orbital periods are locked too 4:2:1. Their efforts to break out of the straight-jacket result in quite a lot of crustal heating for Io and Europa - whence volcanoes and a deep global ocean (if buried under 10s of km of ice).
How about the moon of Venus?
I think that the tidal-lock - receeding moon mechanism is explained fairly well here.
http://www.talkorigins.org/faqs/moonrec.html
For the conservation of momentum the idea of Earth "standing still" and the moon having dissapeared, (orbit to large to remain stable in a multi body environment?), is not without merit, I guess.
We do have a terrestial planet "standing still", Venus. Now, if Venus started it's life comparable to the Earth, it should have had a spin rate of several hours initially. If so, no matter what hypothesis you take for the spinning to stop, (Atmospheric tidal lock drag or something like that), there must be a mechanism for conservation of momentum.
So could Venus have had (a) moon(s) that were launched into space due to conservation of momentum?
Not likely, Venus' slowing of rotation is due to solar tidal interaction. The system's angular momentum was conserved by Venus moving into a slightly higher orbit.
Janus,
That solar tidal interaction is modeled by Correia and Lasker.
http://astro.oal.ul.pt/~acorreia/cvpubs/venus1.pdf
http://astro.oal.ul.pt/~acorreia/cvpubs/venus2.pdf
However, they admit that the current end state of Venus retrograde rotation was only possible if the initial spinning rate of Venus could have been about three days. However, empiric relations valid for other terrestrial planets suggest an initial spinning rate of 13,5 hours. A tremendous difference in energy (factor 38). I seem to have lost the envelope on the backside of which I made some rough order of magnitude calculations some time ago (I’ll try again) but I seem to remember that it placed to the initial orbit of Venus pretty close to the sun.
Moreover, Correias model assumes a steady state of Venus dense CO2 atmosphere from the beginning. This seems to contradict the “wet greenhouse model” that attempts to explain the current thermal state of Venus, assuming a more Earth like atmosphere in the beginning. You can’t have both.
I still think that a hypothetical “lost moon of Venus” could better explain the apparent loss of spinning regardless the cause.
Janus,
How so? The maximum distance a moon could have from Venus is about 1.6 times that of the present distance from Earth to Moon. A moon at such a maximum distance would have a period of 53 days. That is also the longest period of Venus' rotation such a moon could cause. This comes way short of the amount needed to match Venus' present period.
Yes you could be right. I jotted some numbers down on another old envellope. The possible angular momentum of Venus around its own axis as a protoplanet with a spinning periond of 13,5 hrs is about six orders of magnitudes less (~0,9 E34 versus ~1,8 E40 kg-m^2/sec), than the angular momentum of its orbit. At least that's what I get, using those numbers:
http://nssdc.gsfc.nasa.gov/planetary/factsheet/venusfact.html
Neglectible indeed. No disappeared moon needed for the conservation of momentum, I guess.
In order for the Moon to break free of the Earth and follow its own independent orbit around the Sun, it would have to recede to more than 2.4 times its present distance.
Please could you explain how this figure (and the quoted ones for a moon of Venus) are calculated?
Thanks.
Thanks.
You use the the Sphere of Gravitational influence for the Planet as derived bu Laplace. the radius is found by:
[tex]R = D_{sp}\left[ \sqrt[5]{ \frac { M_{planet}}{M_{sun}}}\right]^{2}[/tex]
Dsp is the distance from Sun to planet
I didn't know that - thank you. I didn't realize that there WAS a limiting orbital distance!
Janus said:
...There are four: libration of Latitute, libration of longitude, diurnal libration and physical libration.
Libration of longitude...
...allows us to see an additional few percent of the Moon's surface.
Diuranl Libration...
...allows us to see about 2% more of the Moon.
I know the total is about 9%, but what are the individual percentages of the moon that longitude, latitude, Diurnal and physical Libration allows us to see?
