Why don't photons possess mass?
  • Level: Undergrad
  • Thread starter Thread starter misogynisticfeminist
    Mass Photons
86 replies · 17K views
da_willem said:
..invariant mass would be the one having no place in GR because it is not the source of a gravitational field, energy (proportional to relativistic mass) is?
Yup. I agree to a certain extent.
Thanks for the Am. J. Physics articles (do you know if it's possible to get them delivered in Europe?).
If you have access to a university library then they should have it.
I'm still reading your article on the concept of mass (It's quite large you know...).
Unfortunately it was very large. I was hoping to keep it shorter when I wrote it but there is a lot to the subject and I chose thoroughness over shortness.
Sure. Do you have his mailadress; A.Einstein@hotmail.com or something??! :smile:
baez@math.ucr.edu or john.baez@ucr.edu
This is a photo of John - http://andrej.com/mathematicians/B/Baez_John.html
Reminds of of Mr. Kotter. :laughing:
Saying that relativistic mass has no role/place in relativity is pretty silly since it has always been there and must always be there. Saying it doesn't is like saying that momentum has no role/place in relativity. E.g. consider the force on a particle with proper mass m0
[tex]\bold F = \frac{d}{dt}\left \frac{m_0 (d\bold r/dt)}{\sqrt{1-(d\bold r/dt)^2/c^2}}\right[/tex]
Does v = dr/dt have a role? After all I never need to substitute v into any equation. But let's try it anyway.
[tex]\bold F = \frac{d}{dt}\left \frac{m_0 \bold v}{\sqrt{1-v^2/c^2}}\right[/tex]
Does [itex]= \gamma = 1/\sqrt{1-v^2/c^2}[/itex] have a role? After all I never need to substitute [[itex]m = \gamma m_0[/itex] into any equation. But let's try it anyway.
[tex]\bold F = \frac{d(\gamma m_0 \bold v)}{dt}[/tex]
Does [itex]m = \gamma m_0[/itex] have a role? After all I never need to substitute m into any equation. But let's try it anyway.
[tex]\bold F = \frac{d(m\bold v)}{dt}[/tex]
Does [itex]\bold p = m \bold v[/tex] have a role? After all I never need to substitute <b>v</b> into any equation. But let's try it anyway. <br /> <br /> [tex]\bold F = \frac{d\bold p}{dt}[/tex]<br /> <br /> Seems that each time I defined a quantity the equations became simler. But I need not have defined serveral of those quantities, including velocity and momentum. Even force doesn't have to be defined. E.g. I can write the Lorentz "force" law as <br /> <br /> [tex]\frac{d}{dt} \frac{m_0 (d\bold r/dt)}{\sqrt{1-(d\bold r/dt)^2/c^2}} = q(\bold E + \bold v \times \bold B)[/tex]<br /> <br /> I can express the law of conservation of momentum by saying that mv is conserved. This holds in all cases, not just for tardyons, when m = relativistic mass.<br /> <br /> I call the introduction of each term, i.e. v, m, p, gamma, f, etc. "Economy of thought."<br /> <br /> Pete[/itex]
humanino said:
One can always formally define [tex]m=\sqrt{E^2 - \vec{p}\,^2} = \sqrt{p^2}[/tex] but no physical interpretation in a rest frame can be obtained from it for a real photon (for which [tex]m=0[/tex]). Then, for a virtual photon the mass defined in this way is perfectly legitimate.
Just a Note: When discussing quantum mechanics one has to keep in mind that quantities which are meaningful in classical relativity become meaningless in relativistic quantum mechanics and quantum field theory. The above relation defines proper mass as mentioned above. Relativistic mass becomes ill-defined in quantum mechanics, as does [itex]\bold p = \gamma m \bold v[/itex] and [itex]\bold F = d\bold p/dt[/itex] since each is a function of velocity and velocity is not a well-defined quantity.
Relativity (SR and GR) is a classical theory and as such photons really have no place in it in principle. However that doesn't mean that its not highly useful.
Then again this is yet another discussion about terminology and semantics. But such conversations are not a waste of time since Physical concepts are free creations of the human mind, and are not, however it may seem, uniquely determined by the external world. - Einstein
Refering to proper mass as "mass" and labeling it "m" instead of m[sub0[/sub] is just a way to simplify things in a certain context. E.g. in particle physics one studies the inherent properties of particles. It'd be exhausing to keep using the qualifier "proper" evertime you spoke of the proper mass of a particle. State what you mean once and be done with it - whatever simplifies things for you and your reader per your taste. However this would mean referring to the proper lifetime of a particle simply as the "lifetime". In relativity the lifetime of a particle is not the same thing as the particle's proper lifetime, yet its rare to see the proper lifetime actually called the "proper lifetime."
Pete
Pete said:
photons really have no place in [a classical theory] in principle
I would really appreciate if you elaborate on this. Since light has such a central role in GR, I don't understand this issue.
Is this merely the fact that individual quanta of light appear only in quantum phenomena ?
Or do you mean to say that light is entirely described by a wave in classical theory ?
Is it something else ?
Thank you in advance.
Light, yes. Photons, no.
Yes.
No. In quantum theory you cannot assign a velocity vector to a photon whereas in classical mechanics/relativity you can. In relativity you should think of a photon as a classical particle which moves at the speed of light, not as a quantum particle, wave-partilce duality and all, until there is a full-fledged theory of relativsitic quantum theory.
Note that I didn't say that it wasn't useful or that I wouldn't speak of photons in SR/GR. On the contrary, I often do. But to be honest I think of them as classical particles which move at v = c.
Are you familiar with the tex Exploring Black Holes? If so then seen the acknowledgment section (http://www.eftaylor.com/pub/front_matter.pdf)
Philip Morrison made several suggestions and convinced us not to invoke that weird quantum particle, the photon, in a treatment of the classical theory of relativity (except in some exercises).
That was what I had in mind.
Pete
humanino said:
Thanks for clear and fast answer Pete.
Glad to help. But that was just an opinion and I'm not attached to it 100%.
Photons are funny animals. Even some of the most well know physicists are not even convinced that they exist. For instance, Willis E. Lamb, Jr., Nobel Laureate, wrote a paper entitled Anti-photon, Applied Physics B, 60, 77-84(1995) in which he argues that photons don't exist. And as you probably know, Lamb shared the Nobel prize in 1955 for "his discoveries concerning the fine structure of the hydrogen spectrum."
As the abstract states
It should be apparent from the title of this article that that author does not like the word "photon," which dates from 1926. In his view, there is no such thing as a photon. Only a comedy of errors and historical accidents led to its popularity among physicists and optical scientists. etc.
Good reading and well worth your time.
Pete
At this point I'd say toss in the circular filing cabinet. I've grown tired over the years of this topic and I've chosen to (1) delete the paper from my website and (2) say this only - Mass is what you define it to be and if you choose to defined it as I've explained then you can't go wrong.
Besides that I'd say don't bother with it. Its a waste of time worrying about a definition when you know what the definition is.
Pete
Note: I won't be able to discuss this or anythiing else in the near, or even the foreseeable, future. Due to the problem of my herniated disk I have to spend more time off my feet and out of my chair and spend more time on the couch on my back. The internet is too much of a temptation and what very little time I spend on it is turned out to be far too much and is causing to much damage. to the disk. I will therefore be offline, at least until my back is all better and probably for a while, if not permanently.
Have a good one and it was a pleasure knowing you all.
Pete
I'm sorry to hear that your situation is made worse by using the internet. Thanks though for your fast and accurate replies, and the discussions. I hope your back gets better and we will see you again on PF.
[itex] <br /> <br /> <br /> The way you present it, the definitions you choose at every step are totally arbitrary. So, to someone who does not know physics, it might sound like physicists just defined things as they wish with no physical motivation. That's of course very misleading.<br /> <br /> To make my point, consider the following step: <br /> <br /> <blockquote data-attributes="" data-quote="pmb_phy" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> pmb_phy said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> [tex]\bold F = \frac{d}{dt}\left \frac{m_0 \bold v}{\sqrt{1-v^2/c^2}}\right[/tex]<br /> <br /> Does [itex]= \gamma = 1/\sqrt{1-v^2/c^2}[/itex] have a role? After all I never need to substitute [[itex]m = \gamma m_0[/itex] into any equation. But let's try it anyway. </div> </div> </blockquote><br /> So why not define [itex]scoobydoo = \frac{\bold v}{\sqrt{1-v^2/c^2}}[/itex] instead of defining gamma and then putting the gamma with the mass? After all, someone who would not already know some SR would probably find it more natural to put all the v dependence together. <br /> <br /> The reason of course is that the way things are grouped and the choice of new definitions are not at all arbitrary, as it might look from your post.<br /> Things are defined according to how they transform under certain symmetries. That's what we always do in physics, from simple nonrelativistic mechanics to particle physics and GR. Symmetry is the key point. Unfortunately it's not pointed out often. For example, the quantity [itex]m_0[/itex] is a useful concept because it's invariant under Lorentz transformations. The quantity [itex]\bold p = \gamma m_0 \bold v[/itex] is a useful concept because the sum of this quantity is conserved in a collision (no matter what frame we are observing the collision from). So we give names to these quantities. the quantity "scoobydoo" I defined above has no invariance property so it's not useful to give it a special name. The same things is true for the quantity [itex]\gamma m_0[/itex]. It has no interesting property so it should not really be given a special name. It's only if someone wants to keep using expressions familiar from nonrelativistic mechanics that there is some justification to treating this quantity in a special way (for example, if one really wants to keep using [itex]\bold p = m \bold v[/itex] then one must define [itex]m = \gamma m_0[/itex]). But there is no reason for wanting to keep using the nonrelativistic expressions. It's totally subjective. I think it makes more sense to accept the fact that expressions are different in SR than in classical mechanics and that the momentum is simply [itex]\gamma m_0 \bold v[/itex].<br /> <br /> Pat[/itex]
nrqed said:
It's totally subjective. I think...
I think this is the whole issue, it's just a discussion over semantics. And to a large extent in physics you are free to make your own definitions to make the equations 'more elegant'.
But anyway, Peter is not going to reply, see a few posts ago:
Thanks. It seemed to get a tad better - then it got much worse. I have to see a neurosurgeon next week. I may need surgery. I have a doctors appointment today and there is a computer next door. This is the exception to the rule though.
The point of my post that Pat responded too was that "has no role" is a meaningless thing to say pertaining to the concept or rest mass. Regarding the expression p = M(v)v. As we all know when this is the momentun of a particle then M(v) = [itex]\gamma m_0 \bold v[/itex] and m0 is an inherent property of the particle. This is often take to apply to everything and this may not be the case. Momentum may depend on the orientation of the body relative to its velocity.
There is an excellant example in
Mass renormalization in classical electrodynamics, David J. Griffith and Russell E. Owen, Am. J. Phys., 51(12), Dec. 1983.
The authors consider a dumbbell which consists of two identical charges held together by a rod. The momentum of the dumbbell has one value when the axis is parallel to the velocity and another value when perpendicular. In the arbitrary case where the axis makes an angle between those two values there is a range of values. And the momentum is not even parallel to the velocity in general!
[qote=Pat]The way you present it, the definitions you choose at every step are totally arbitrary.[/quote]Definitions are always "arbitrary" in that they are not set in stone by God. Perhaps Pat is unfamiliar with the saying
Physical concepts are free creations of the human mind, and are not, however it may seem, uniquely determined by the external world. - Albert Einstein
See http://www.geocities.com/physics_world/physical_concepts.htm for full quote and reference.
So we give names to these quantities. the quantity "scoobydoo" I defined above has no invariance property so it's not useful to give it a special name. The same things is true for the quantity . It has no interesting property so it should not really be given a special name.
That is quite untrue. You're considering this in a vaccum. Its not even clear what you mean by "no interesting property." Have you ever met two people who agreed on all points as to what is "interesting"? v is not invariant and yet I consider it useful. Consider something else besides a point particle. Consider a continuos mass distrubution. Then the mass of the distribution is the inetral of dM = (1/c2)T00dV over the volume of the distribution. This integral is evaluated in the zero momentum frame. What is it that you think dM is? Consider the case of em radiation. Let all radiation in the region x>0 be moving in the +x direction and let all radiation in the region x<0 be moving in the -x direction. What do you think dM means in this case? I.e. when you're adding these quantities, what is it that you're adding?
Consider also that it is not m0 that is the source of gravity, [itex]\gamma m_0[/itex] is the source. Thus a beam of photons all moving in the same direction will generate a gravitational field. Consider a sheet of matter in the z = 0 plane. If you consider the mass of the particles that make up the sheet as [itex]\gamma m_0[/itex] then when you consider the fact that it behaves as if the gravitational mass increases like [itex]\gamma m_0[/itex] then it becomes a very interesting quantity.
Pat - Do you think that v is an "interesting" quantity?
It's only if someone wants to keep using expressions familiar from nonrelativistic mechanics that there is some justification to treating this quantity in a special way..
- This comment makes no sense to me. People don't define things so as to look like the non-relativsitic case. It is simply a definition. Take as an example what happens in physics - Components of things like 3-force are actually what gets measured in the lab. These things are not invariant. The lifetime of a free neutron is not the same as the proper lifetime of 15 minutes. When the thing is moving in the lab then, on average, it lives longer when it is moving then when it is at rest. A moving rod is shorter than a stationary rod. That is physically measurable.
Its unwise to consider only the expression [itex]\bold p = \gamma m_0 \bold v[/itex] as defining mass and to only consider it in a vaccum. There are extremely good reasons to define mass as [itex]m = \gamma m_0[/itex]. Please don't be offended by this but its not like all these physicists for the last 100 years were so dense as not to think the way you do on this point. They've found by careful examination under various situations that the most reasonable thing to call "mass" as [itex]m = \gamma m_0[/itex]. The way you define it doesn't always work. In fact it is invalid for a rod which is under stress and moving parallel to its length. That can be shown by looking at the stress-energy-momentum tensor.
Take care all and see you the next time I have a doctors appointment.
Pete
ps - Pat; to see more examples of where [itex]\bold p = \gamma m_0 \bold v[/itex] fails, or where the definition of "invariant mass" of a system fails pleas see - http://www.geocities.com/physics_world/sr/invariant_mass.htm
There is also an imortant comment at the bottom of page 104 in Ohanian's text "gravitation and spacetime" regarding this. He explains the trouble with adding 4-momenta when the momenta are not constant and the particles have a spatial separation
Note; - That is what the authors conclude in that paper. I am not convinced that they are correct. However they do speak of a paradox regarding this problem so I suspect a piece of this puzzle is missing.
Pete
There is also an imortant comment at the bottom of page 104 in Ohanian's text "gravitation and spacetime" regarding this. He explains the trouble with adding 4-momenta when the momenta are not constant and the particles have a spatial separation[/QUOTE]
Then let me be more specific: I think that when constructing a theory, the starting point is a question of symmetries and invariance. What are the symmetries that we think our system (and the equations) must possess? I think that's the starting point. Then one builds quantities that have specific transformation properties under those symmetries. Equations must relate things that have the same transformation properties, so these are the "interesting" things to work with. Of course, one can measure anything one wants! But the theory will involve quantities which have specific transformation properties. That's the whole point of using tensors to build relativistically covariant equations. If we did not pay attention to transformation properties, we would be trying a lot of crazy equations that would prove useless in the end. Why didn't Dirac try writing down equations involving only P_0 separately, or just P_x and P_y, etc?? Because he knew his equation would prove up useless if it was not Lorentz invariant.
*Of course*, when you change the applications of a theory, the symmetries change and the useful quantities become different. What were useful quantities in classical, nonrealtivistic mechanics are no longer useful in SR, and what is useful in SR may have to be modify when going to GR.
All I was saying is that I the quantity [itex]\gamma m_0[/itex] is not a useful concept in SR. The mass [itex]m_0[/itex] is a useful quantity, and the quantity [itex]\gamma m_0 \vec{v}[/itex] is useful as the zeroth component of the four-momentum, but not [itex]\gamma m_0[/itex].
If so, show me a relativistically invariant equation of SR which contains [itex]\gamma m_0[/itex] not as part of a four-vector!
So we are talking about GR or SR? I thought we were discussing SR. In any case, show me one of the fundamental eqs of GR which contain [itex]\gamma m_0[/itex] by itself (not as a component of a tensor) and then I will agree with you that it is a useful quantity to define in itself.
In classical mechanics, it is, indeed. Because the symmetries that are interesting are the ones under Galilean transformations and one is dealing with inertial frames. In that contex, the quantity [itex]d \vec v/ dt[/itex] is an invariant and that's why it appears in Newton's second law. (of course, we could do it the other way around and talk about the equation in order to define inertial frames, etc but I am following here the symmetry -> laws of physics approach).
Tell me, if you are saying that it's totally up in the air what physical quantities we single out, then why do we put the three components [itex]v_x, v_y, v_z[/itex] in a vector in the first place?? It's because the concept of a vector is invariant under rotation of the coordinate system whereas the individual components are not! Of course, one can measure the indivudual components in an experiment, but from a conceptual point of view, it makes more sense to group the 3 components in a vector. Is your point of view that grouping the 3 components ina vector a totally arbitrary definition??
What about things like [itex]d^3 \vec v/ dt^3[/itex]? Why don't we use that quantity in classical mechanics? Of course, it *can* be measured. And anyone could come along and claim it's a useful quantity and so on.
I just don't see any reason to introduce gamma m_0 other than to have the momentum equation look like the NR expression. It does not transform a scalar, a vector or any type of tensor for that matter under Lorentz transfo. The rest mass is an invariant, and the four-momentum transforms as a 4-vector. But splitting the four-momentum in a way (as a product of this "relativistic mass" times something else) such that the two pieces have no particular property under Lorentz transfos is not a ueful step, IMHO.
Of course, one can measure anything in a lab. Including the x component of the momentum of an electron in any frame. By why didn't Dirac write an equation for the x component of the momentum of an electron? Because it is not a useful quantity to build the theory upon. And why? Because separating the x component hides the summetries underlying the theory! Of course one could work out separate equations for the x, y,z and t components but then one would realize that they are linked in a nontrivial way . And that means that they are not useful quantities from a theoretical point of view because the symmetries are not made explicit. Same thing for [itex]\gamma m_0[/itex].
Likewise for the length of the rod. Ofcourse, it is shorter in motion. But we don't have a separate equation for the length of the rod when it is moving at 0.1 c, at 0.2 c etc etc. The equations contain the proper length. If you want to fidn the length when it is moving at 0.1 c, you don;t look up an equation for that quantity, you use the Lorentz transfos to figure it out. So the useful quantity here is the proper length, not the length at 0.1 c. For the same reason, the useful information for a particle is its rest mass.
I know it's an old debate. And I am not at my office so I can't give references but there are many people who do say that we should not teach the concept of relativistic mass anymore, that's it's an historical "faux-pas". It's a bit like using imaginary time in SR and GR. It used to be done but it is now realized that it's not conceptually a good approach (see for example MWT).
The way "I define" it...you mean just m_0? Well, it should be clear if we are doing SR or GR. But in either case, all I am saying is that considering the quantity [itex]\gamma m_0[/itex] in isolation (and not as part of a four vector or a tensor) is incorrect. Of course, you can look at a certain mass distribution in a specific frame and say that it is something we can measure. All I am saying is that the meaningful quantity to discuss is the four-vector or the tensor, not a component in a specfic frame, for a particular mass distribution. That's what I mean by "useful" vs not useful quantities.
And I think that in teaching or presenting physics it's important to emphasize that anything can be measured and we can single out any combinations of of quantities we want, but the correct way to approach physics is through symmetries and that the useful quantities are the ones with specific transformation properties.
Pete
Take care. I do very sincerely hope that you will be feeling better!
Pat
I'll look. However, my issue is not with the four-momentum, it's with singling out gamma m_0! But I'll look.
To me the goal and purpose of a theory in the end is to describe nature and what we observe. What we observer are not invariant quantities.
The purpose of tensors in SR/GR is to meet the criteria of covariance in the laws of nature.
This is the point where opinion comes into it and we've left the area of calculation and prediction. In any case - Anything which is conserved is important. That is a pretty universal opinion. And [itex]\gamma m_0[/itex] is a quantity which is conser ved and that fact does not rely on the conservation of energy as many seem to think.
The mass [itex]m_0[/itex] is a useful quantity, ...
I agree. Proper time is important as is coordinate time. Coordinate time is as important as proper time and mass is just as important as mass. But you seem to keep arguing in a vacuum. There is more than one reason why (relativistic) mass is so often spoken of in the relativity literature. It has all the properties that one associates with mass, i.e. the inertial properties, the active and passive properties of gravitational mass. Proper mass has none of those.
..the quantity [itex]\gamma m_0 \vec{v}[/itex] is useful as the zeroth component of the four-momentum, but not [itex]\gamma m_0[/itex].
That is incorrect. [itex]\gamma m_0[/itex] is the time component of 4-momentum. People replace it with inertial energy E but its more correct to use P0 = mc since it plays the role of time component perfectly since if dX is a spacetime displacement then dX0 = ct. So it t is the time component of dX then mc is the time component of P.
Why would you get that impression. Mass is mass. Relativity is relativity. There is no reason that I know of to define mass differently in SR than one does in GR. In fact it'd be a bad idea to do so in my opinion.
You're incorrectly demanding that mass must be a tensor in GR for it to be important. That's like saying that energy or pressure are not important in GR because they're components of tensors. That's your personal opinion. I don't expect you to agree with me and I don't expect you to think that its important. There's little use in wanting everyone to think in the exact same way. It'd be a pretty boring world and it would slow down the progress of physics.
However there are two equations which come to mind. One is in MTW. It reads
u*Tu = Mass
Where T is the energy-momentum tensor, u is the 4-velocity of the observer and "Mass" is what some people call "relativistic mass" or "mass-energy." MTW use the term "mass" in the section where they demonstrate the the energy-momentum tensor is symetric. This is in the beginning of the section in MTW where they speak of mass as the source of gravity
One can't really define these 4-tensors and 4-vectors without defining the components. I don't recall ever seeing someone define the energy-momentum tensor without ever speaking about the components. There are ways to speak of components as scalars. For example;
m = P*U/c2
Here m = mass (i.e. relativistic mass) of the particle whose 4-momentum is P as measured by an observer whose 4-velocity is U. Some people call this the energy as measured by the observer but it depends on what one calls the time component. As above u*Tu = Mass is the same thing. This is an observer-dependent invariant.
One can take something like the Faraday tensor and contract it with the 4-velocity of an observer and get the electric field 4-vector. Take the scalar product of the electric field 4-vector with a basis vector and get a component of the electric field. Notice that all of this is tensor manipulation, i.e. contractions of tensors etc.
For more on the electric field 4-vector see Wald or Thorne and Blanchard's text
http://www.pma.caltech.edu/Courses/ph136/yr2002/chap01/0201.2.pdf
You've been speaking of GR/SR completely from the geometric view and as if it were the only view that there is. There is also the 3+1 view that is used quite often as is the analytic treatment of tensors rather than the geometric treatment of tensors.
I've snipped the rest since its more of the same, i.e. more of "any number which is not a scalar is useless/not important." I see no use in going down that road since its all semantics.
And there are many people who say that one should teach relativistic mass and that it is incorrect to claim that it is an historical "faux-paux". It is certainly no such thing. All arguments I've seen to back that claim up are flawed.
Some examples of authors whose texts use relativistic mass Wolfgang Rindler, Richard A. Mould, Ray D'Inverno, Bernard F. Schutz (see his new book), etc. (These are authors whose texts where published after 1991).
[/qupte]
Why do you refer me to MTW? They themselves use relativistic mass although they call it "mass" or "mass-energy" rather than "relativistic mass."
Thanks. I go into surgery Monday. Wish me luck folks.
Its all semantics anyway. To date nobody has stated anything that can be considered fact as to why one view is correct and the other incorrect. However I have seen people incorrectly think that E/c2 = p/v in all cases. That is an incorrect assumption. This is invalid in some instances when a body is under stress.
Up to this point its been philosophy more than relativity.
Pete
Good luck! I hope this goes well, and you'll feel better afterwards...
Yes, good luck Pete ! We appreciate your discussions. I hope you feel better soon.
Good luck Pete, and get well soon.
We will be waiting for your return man...
regards
marlon :smile:
If mass is energy, but energy is not mass cause it's a wave allthough particles are waves and have mass then I may very well be a wave moving through space in the speed of light with a hundred procent risk of turning into dust in the big nothing.
"Must be some cind of forcefield"
I love subatomic particles I find it a fascinating topic one of "the most' interesting in my opinion but there has been a couple questions that have made me ponder about the true nature of them...
1.are particles pieces of matter? or actual waves?
2.if they are made from actual particles or pieces of matter then are quarks composted of something smaller?
3.if they are not then how can it be possible for it to be fundamental?
4.& Finally if particles are actual waves then what are they waves of? and what prevents us from being see through if we are not made out of actual matter?
If anybody can answer any of these questions you would of helped me out big time and I thank you very much. :confused:
to Mwyn:
1. Its like asking a hamephrodite (sp.) whether he/she is male or female.
2. Strings perhaps, but i don't think anyone in the physics community ever said that quarks are indeed the most fundamental, and absolutely ruled out anything more fundamental than that.
3. Waves basically carry energy from one place to another. Can't really answer the fourth question though...
Particles and waves are two different descriptions of the same thing. There are dual. This means that when trying to describe a particle you can look at them as "little bullets" that bounce on some detector giving a "click"-sound for example. A particle is caracterised by stuff like momentum and energy. Now de Broglie found out that momentum p is equal to h/l ; where l is a wavelength and h is the socalled Planck constant. Energy E is equal to hv ; where v is the frequence. Now l and v are quantities describing a wave. So particles are not waves of something. What you can do when you want to describe a particle with energy E and momentum p is "construct" the equantion of a wave with v and wavelength l. You are describing the same thing but with another "language", if you will. So what this wave is, is of no relevance. The only thing that matters is that when you measure some wave (ie : you determin the v and the l) you are allowed to say that you measured a particle with certain mass, E and p...
This way of working is the fundament of quantummechanics.
Quarks are up till now the most fundamental particles that feel the strong force. This force keeps baryons and mesons together and it also binds an atomic nucleus together. Ofcourse it is possible that some more fundamental "thing" is found. Strings are a result of the attempt to unify all known interactions : gravitation, electromagnetic force, weak force (alpha beta and gamma decay) and the strong force. yet this is still a very young and unstable modell.
marlon
Haelfix said:
Well yes, the photon does not acquire a Higgs mass, but that's somewhat secondary.. The most fundamental reason is that it is a gauge boson, and the U(1) gauge symmetry of electromagnetism is both a global symmetry and crucially a local one. Mathematically, that implies it has zero mass.
INDEED HAELFIX, YOU WROTE THE ONLY GOOD ANSWER TO THE QUESTION OF THIS THREAD!
THIS IS THE REASON WHY PHOTONS DO NOT HAVE MAS!
The U(1)-symmetry is never broken. For this reason, there ain't no interaction with the Higgs-field...
marlon
So basically the question I want to know is that If I could shrink myself into a quantum universe were atoms are the size of basket balls. (highly unlikely yet metaphorically), what would I see? would I see orbs of energy? orbs that look and feel like marbles? or would they be orb like waves?
More like the waves. All the elementary particles in the Standard Model are treated as geometrical points, and no experients exist that give them firm non-zero dimensions, so you wouldn't see orbs. What you might see (assuming of course that you can "see" at this scale) is blobs with a clear gradient of blobness from the center out to trail off at the edges, and a max somewhere in the middle.
I have another question though? would energy itself or the stuff that bonds particles together be made from smaller particles too? like how electricity is composited of electrons, are the atoms blobs of matter or energy?
