Why eliminate time when deriving the range formula for long jump
51 replies · 7K views · last reply
rudransh verma
In 1991 Mike Powell jumped 8.95 m. Powells speed on takeoff was 9.5 m/s and g=9.8 m/s^2. How much less was powells range from the max possible range for a particle launched at same speed?
$$R={v_0}^2\sin(2\theta)/g$$
$$R=9.21 m$$
$$Difference = 9.21-8.95$$
$$D=0.26m$$
My question is when do we use the formula for R given above. Because we could have calculated the Rmax by ##R=(v0\cos(\theta))t## and then subtracted R from it to get the answer.
Why the x and y component in the derivation of this (R)formula are combined by eliminating t?
  • Textbook page with the heading The Horizontal Range, showing derivation of R = (v0^2/g) sin 2θ0 by eliminating t from R = (v0 cos θ0) t and 0 = (v0 sin θ0) t - ½gt^2, with the note that R is maximum at 45°.
How do you know what t would have been for max range?
Btw, the given formula is only for when the trajectory starts and finishes at the same height.
Because we wanted to find the trajectory of the particle Which will be in form of its Y-Coordinate & X-Coordinate
You can use this formula also because for this situation when the Body is landing on the same height from where it started We can simply write Y=0 and then Find X(eliminating x=0 because that would be the starting point ).
For a real world long jump, the landing position has the jumper's center of mass lower than at launch due to posture. One launches standing up. One lands as low as one can manage.
Also, the length of the jump is from the takeoff line to the point where the jumper's first body part touches the sand. The feet are considerably far ahead of the center of mass and that is why jumpers try to land with feet as forward as possible without their butt hitting the sand first.
Or after.
"Long jumps are measured from the forward edge of the take-off board to the impression in the landing pit closest to the take-off board made by any part of the body of the jumper."
jbriggs444 said:
Or after.
That contradicts what I found here. Goes to show how reliable the web is.
Screenshot of a wikiHow page titled Tracking the Jumper's Landing, showing a cartoon of a long jumper's hand and elbow hitting sand, with a green circle marking the landing point, and step 2 text about which body part hits the sand first.
Adopting a "first point hit" marking policy would favor a strategy of laying out flat and, perhaps, bending the knees slightly to ensure a heel-first hit. This would also make measurement more prone to irresolvable dispute.
The reference I had found was here.
We need to find the max R which can be calculated by putting ##theta=45## in this formula. I guess we have to use this formula anyway.
In the derivation of the formula they took two eqns for s, one vertical and horizontal and eliminated t. So the whole point of this is to find R easily even when t is not given.
$$R=v0cos(theta0)t$$
$$0=v0sin(theta0)t- \frac12gt^2$$
$$R=\frac{v0^2}{g}sin2(theta0)$$
We don’t know t and theta both, Yes?
You already said that you know what theta needs to be to maximize R.
You had a perfectly good formula involving ##v_0## (known), ##g## (known), ##\theta## (known) and ##t## which you could easily solve for t:$$0=(v_0 \sin \theta)t - \frac12gt^2$$In fact, you did solve for ##t## and used the solution in your next equation.
[Minor edits on your ##\TeX##. I used \sin instead of sin. This changes the font, removing italics, improving readability. I used \theta rather than theta0. The zero subscript was distracting and the Greek letter is shorter than the name of the Greek letter. I used the subscript introducer ("_") for the subscript on ##v_0##. I thought about removing that subscript entirely, but left it to preserve similarity with the original]
@jbriggs444 is right. I can find t and then I can use horizontal displacement eqn to get max R.
But the original doubt of this thread is final R eqn is used when you are not given t and launch angle ##\theta## is given.
In post #1 you are given v. You ask why you would use ##R=v^2\sin(2\theta)/g## to find ##R_{max}## "instead of using t".
The formula tells you that R is maximised at ##\theta=\pi/4##, and using it you don't need to find t.
If you want to do it using t then you first have to find t. The formula you are using to do that requires you to know ##\theta=\pi/4##. How did you know that except by using ##R=v^2\sin(2\theta)/g##?
So I am baffled as to a) why you think it is simpler going via t instead of using the formula and b) why you think you have succeeded in doing so.
But the original doubt of this thread is final R eqn is used when you are not given t and launch angle θ is given.
What are you doubtful about? Are you questioning whether the range formula is valid for all theta?
haruspex said:
You ask why you would use R=v2sin⁡(2θ)/g to find Rmax "instead of using t".
I am questioning the existence of this formula. When you can do it via the obvious way by finding t why have we derived a new formula?
haruspex said:
The formula tells you that R is maximised at θ=π/4, and using it you don't need to find t to calculate R, just ##\theta##
Ok so this is your answer. So it was not known experimentally first but by the formula first.
As I posted, we first have to find t without using ##\theta=\pi/4##. We can do that by writing the two usual equations:
##y=v\sin(\theta)t-\frac 12gt^2##, ##x=v\cos(\theta)t##
Substituting y=0 to find the time when it lands:
##2v\sin(\theta)t=gt^2##, ##2v\sin(\theta)=gt##
Plugging that into the x equation:
##x=v\cos(\theta)2v\sin(\theta)/g=v^2\sin(2\theta)/g##
Now we can see x is maximised by ##\theta=\pi/4##.
The formula exists. It is your choice whether to remember it or to remember how to deduce it. I was never good at remembering formulae, but I could usually remember how to get them.
A more challenging version is to consider max range on a slope - a standard calculation for gunners in days gone by.
@haruspex I have the formula for ##R=\frac {{v_0}^2 sin2 \theta}{g}## and seeing it we conclude at ##\theta=45## we have max R.
But R is also equal to ##R={v_0}cos\theta t## and here R is max when ##\theta=0##.
So what is it that I am missing?
@haruspex I have the formula for ##R=\frac {v0^2 sin2 /theta}{g}## and seeing it we conclude at ##\theta=45## we have max R.
But R is also equal to ##R=v0cos\theta t## and here R is max when ##\theta=0##.
Let us begin by working with those ##\LaTeX## skills.
You wrote ##R=\frac {v0^2 sin2 /theta}{g}## which yields: ##R=\frac {v0^2 sin2 /theta}{g}##
You wanted ##R=\frac{{v_0}^2 \sin 2 \theta}{g}## which yields: ##R=\frac{{v_0}^2 \sin 2 \theta}{g}##
Edit: Learned something myself. Putting squiggle brackets around {v_0} improves the look of the superscript for exponentiation -- moves it above and to the right of the whole ##v_0## instead of putting it above and to the right of the ##v## which ends up directly above the subscript ##0## where it looks strange.
So what is it that you are missing? You are missing that ##t## (the time until vertical position returns to zero) is a function of ##v_0## and ##\theta##. You cannot set ##\theta## to zero and expect ##t## to remain unchanged.
To put it in another way, you are working to maximize the function: ##R(\theta) = v_0 \cos \theta\ t(\theta)## but you are erroneously treating ##t## as a constant rather than as a function of ##\theta##.
What you are missing is that, on one hand if you set the two equal you get$$R=v_0 \cos\theta t=\frac{v_0^2\sin(2\theta)}{g}=2\frac{v_0^2\sin\theta\cos\theta}{g}\implies t=\frac{2v_0\sin\theta}{g}.$$On the other hand, if you solve the vertical motion equation for the time of flight, you get $$0=v_0 t\sin\theta -\frac{1}{2}gt^2=t\left(v_0 \sin\theta -\frac{1}{2}gt\right)\implies t=\frac{2v_0\sin\theta}{g}.$$There is no contradiction between the two equations.
I suspect what you are missing is this...
There are often several correct methods to solve a problem. Which method you choose depends on identifying the different methods and spotting which method requires the least effort. The ability to do this depends on understanding and experience.
If done correctly, each alternative method will give the same answer.
Some calculations are more common than others so we use pre-derived formulae for convenience. For example, we often use the formula ##s=ut + \frac 1 2 a t^2##. But we don't have to – we could solve the problem starting with the definitions of speed and acceleration; this would take more work.
The same goes for the range formula. Calculations involving (horizontal) range are common. We could do the calculations without using the range formula if required., But using the range formula (if permitted) might save us some work.
jbriggs444 said:
To put it in another way, you are working to maximize the function: R(θ)=v0cos⁡θ t(θ) but you are erroneously treating t as a constant rather than as a function of θ.
R is max at 45. That we have deduced. How can we show it here using this formula of R.
All I know is ##cos\theta## is max at zero.
As I understand it, you want to erase from our minds the already deduced information that R is maximized when ##\theta## is 45 degrees. Then you want to demonstrate that R is maximized at 45 degrees based on the formula: ##R(\theta)=v_0 \cos \theta\ t##.
The straightforward approach to rewrite ##t## as a function of ##\theta## [which, as @kuruman points out has already been done upthread] and then solve for the ##\theta## that maximizes the resulting formula.
This is the standard crank-and-grind approach that you should try when attacking almost any simple optimization problem: 1. Obtain or manipulate a formula for the value-to-be-optimized so that there is only one free variable and everything else is a constant. 2. Solve for the value that makes the first derivative of this function zero. 3. Evaluate the function at that value.
That's not all you know. You also know that the symbol ##t## in the equation stands for the time of flight, and not just any time (that's why subscripts are useful). As stated earlier this time is $$t_{\!f}=\frac{2v_0 \sin\theta}{g}.$$
I don’t really get you. What value to be optimised? Are you talking about the derivative of ##t=\frac{2{v_0}\sin\theta}{g}##
If you are, at ##\cos 90## derivative is zero.
We are trying to maximize R, not t.
##\frac{dR}{d\theta}=-{v_0}\sin\theta t##
No.
jbriggs444 said:
No.
I don’t understand what you are saying in post#22
What did I say there...
You've skipped ahead to work in part 2 before you've completed part 1. You've also made the mistake of ignoring the fact that ##t## is a function of ##\theta##.
So let us go back to the starting point:$$R=v_0 \cos \theta\ t$$We want a formula for the value-to-be-optimized (##R##) in which there is only one free variable and everything else is a constant.
##v_0## is a constant for our purposes.
##\theta## is a free variable.
But ##t## is neither a constant nor a free variable. It is defined as the time when the object hits the ground. Its value will depend on ##\theta##. As has been pointed out more than once, it is given by:$$t=\frac{2v_0 \sin \theta}{g}$$
So we substitute this formula for ##t## into our formula for ##R## and obtain:$$R=v_0 \cos \theta\ \frac{2v_0 \sin \theta}{g}$$Now let us look at this formula. There is only one free variable: ##\theta##. Everything else is a constant.
Now we are ready to proceed to step 2.
If we want to do it the hard way, we could keep our blinders on, apply the product rule for derivatives and get bogged down in some difficult algebra. Or we could get smart and apply the trig identity:$$\sin 2 \theta = 2 \sin \theta \cos \theta$$.
It is just a hop, a skip and a jump from there to concluding that the angle that maximizes ##R## is 45 degrees.
@jbriggs444 I really appreciate all the hard work. But I am asking how ##R={v_0}\cos\theta t## tell ##\theta=45## will provide max R like the other formula for R.
