mitchell porter
- 845
Factually, whether or not it can do this is unknown, for two reasons: we don't know the global structure of string theory, and small nonzero masses are apparently very hard to calculate in string models.Physics Monkey said:Basically, I think its crazy to think that structure of the world at a few GeV tells us much of anything about the structure of the world at [tex]10^{18}[/tex] GeV (and vice versa)...
This is because I suspect the landscape is a real thing. Does anyone really think that string theory, with all its incredible richness, can't accommodate a bit heavier of an electron, or an extra generation of very heavy particles, or any number of other minor (or even major) tweaks?
The AdS/CFT duality encourages me to think of string theory as consisting of a large number of separate quantum theories - you could think of them as different superselection sectors - one for each distinct boundary theory. Then you have the work by Brian Greene and others on how the space of CY manifolds is connected by conifold transitions (also see the much more recent work of Rhys Davies on "hyperconifold transitions"), which suggests one big theory. It's very unclear to me how it all comes together in the end. Maybe there are one or two "big" superselection sectors, in which a large number of different CY vacua are dynamically accessible, and then a lot of "small" superselection sectors, in which string theory isn't so interesting. But there are so many unanswered questions: Do CY vacua even have holographic duals? What about topology change in the boundary? Are there "sectors" devoted specifically to de Sitter space (as Tom Banks suggests), or does dS get realized only as a fluctuation in AdS space?
It's also hard to say whether there will be much of a landscape in the realistic-looking sectors of string theory. Jacques Distler seems to think that there will be a landscape for values of the cosmological constant, but not necessarily for the standard model parameters. I believe he's thinking in terms of a high-genus CY space, with the standard model fields e.g. existing on branes wrapped around just a few of the cycles, and with the cosmological constant arising from branes wrapped on distant cycles which only interact gravitationally with our branes. This is a setup where the value of the cosmological constant can be anthropically selected, as suggested by Weinberg, because the topology etc of those distant cycles is independent of the local cycles, and the cosmological constant in this scenario is just the sum of many independent positive and negative components. But local structures, according to this argument, will be much more rigid.
As for the second reason - calculating the masses is simply difficult, even in a completely specified model - see the papers discussed in https://www.physicsforums.com/showthread.php?t=455180". The authors flatly state that they are unable to determine the masses, so for now all they do is show that the observed masses are within the available parameter space.
But this situation won't exist forever, and this brings me to a more esoteric reason for believing that masses aren't as tunable as you might think - the Koide relation between the electron, muon, and tauon masses, which is also mentioned in that thread, and which has occasionally been discussed in this forum. Very few particle physicists have even tried to build models that explain that formula, because there ought to be loop corrections to it coming from QED; yet it's still exact at low energies, so something must be cancelling those corrections. We may have little or no idea of what the explanation is, but if string theory can match reality, it will surely be by providing a mechanism that explains the formula, not just by matching the observed masses through three independent acts of fine-tuning. But the existence of such a mechanism means that the possible masses are more constrained than naive landscape thinking suggests.
