Why is it difficult to integrate x^x
  • Level: Undergrad
  • Thread starter Thread starter latyph
    Integrate
99 replies · 137K views
Дьявол said:
Thanks for the correction everybody.
Here is my new solution.
If
[tex] x^x = e^{x\ln x}[/tex]
then
As a side for some reason I was thinking about a good series representation.
If I expand ln(x) first then one gets
[tex]x^x=\Pi_{n=0}^{\infty}exp \left( \frac{(-x)^n}{(n+1)!} \right)[/tex]
Consider what happens now if you plug in [tex]\frac{(-x)^n}{(n+1)!}[/tex] for the Taylor series of an exponential. And then multiply each of these terms together. If you are only interested in the first N terms of the Taylor series, then you only need to consider the first N terms in the product.
Also looking at the series, it kind of looks like the logarithm of x^x is [tex]\frac{1}{x}exp(-x)[/tex]
but I think I must have made a mistake.
Pinu7 said:
Only possible if we can define and inverse function of x^x(which will only work for x>0).
And then, I doubt the integral COULD be solved analytically. However, maybe it would be simpler to approximate?
Hallo Pinu7
It seems we are answering a question outdated. Do you matter?, I don't. Mathematical problems survived wars, so why not years? Ok how to integrate x^x?
You say you can inverse the function for x>0. What will that be?
greetings Janm.
Well the best I managed is an infinite series, which curiously when evaluated from 0 to 1 gives
[[math]]
1-\frac{1}{2^{2}}+\frac{1}{3^{3}}-\frac{1}{4^{4}}+...
[[math]]
I wrote x^x as e^xlnx and used the infinite series e^x. Integrating term by term and used l'Hospital's rule and recursive nature of the integrals to generate the sequence above. Checked using definite integral calculator
how integrate x^x^x ?my teacher ask me)what do you think about it?
Alejandroman8 said:
how integrate x^x^x ?my teacher sak me)what do you think about it?
I think you're in for a lot of swearing and bloody knuckles. Since [itex]x^x[/itex] is positive for all x > 0 then [itex]x^{(x^x)}[/itex] is continuous for x > 0 and therefore Riemann integrable. But trying to find any sort of friendly resolution to it is a fool's errand.
Numeric approximation is your best hope since I think even power series will be intractable.
--Elucidus
Let's not think about how to integrate, just think about the easy case, differentiation, you still wouldn't get nice results at all.
http://the-genius-group-from-uc-berkeley.googlegroups.com/web/Tetration%20Differentiation.pdf?gsc=JivL3wsAAABzdSJOyPIJbvk4ERCPyg5o
Basically, I say (cause and effect stuff/ quark stuff / physically imposside to divide stuff / blah b
going along with everything in nature can be defined as and affacting the reality as (itself is) ,,, call it single definable existence or basically the law of of cause and affect exists...: blah blah blah, no fractions or partial exitstance. (avoid s domain)
(according to the equation derivative guy, (tesla I like)... nueton (sp)...) slope!
der x to x is
is
(xtox - ((xex) - (xe1)to(xe1)) / 1
rise over run in a a non fraxctional (cause and effect world) tadah...
Take a microprossessors class in Electrical Engineering (learn machines do math etc... O'Mally Universiy of Fl... nothing better, I've seen) ...followed by a deep physicall class in statistics (math side, if it exists or maybe not (math dept, might kick your but in statistics) do stilll calll it "counting statistics? get into those sum equations/lin equations and don't get they are the same,
take a math department lin equations classes (at the same time)
that semester will be fun...
