Why is multiplying by a unit conversion ratio the same as multiplying by 1?
16 replies · 3K views · last reply
member 731016
Please see below
Please see below
Suppose I want to convert 100,000 metric Tonnes to kilograms, then I would perform, a unit cancellation:
Given that 1 t = 1000 kg
##100,000 t \times \frac{1000~kg}{1 t} = 1 \times 10^8 kg##, however, why are we allowed to multiply the 100,000 by that?
My reasoning is,
##1 t = 1000 kg##
##1 = \frac{1000 kg}{1 t}## therefore multiplying by ##100,000 t## by ##\frac{1000 kg}{1 t}## is the same as multiplying by 1
Does someone please know whether my reasoning is correct?
Many thanks!
My reasoning is,
##1 t = 1000 kg##
No, it is not. Treat the dimensions in the equation as you would unknown variables.
You need to expand on that.
##100,000t \times 1 = 100,000t## which is incorrect not the answer to the question.
##\frac t t=1## as a next step yields the correct answer.
How is that different?
I guess you mean something like this?
##ax = by \Rightarrow x = \frac{b}{a} y##
then substitute to get ## cx = c (\frac{b}{a} y) = (c \frac{b}{a}) y ##
where ## a,b,c ## are constants and ## x, y ## are units (variables?)
This is instead of
##ax = by \Rightarrow 1 = \frac{by}{ax} ##
## cx = cx (1) = cx (\frac{by}{ax})= (c \frac{b}{a}) y ## as others suggested.
I feel like I'm missing your point here.
You can multiply 100,000t by 1 and you do indeed get 100,000t. So what? That not what is sought. What is sought is to get a final answer in kg, not in t. To do that you need to multiply 100,000t by 1000Kg/t to get 10E8Kg. Units matter.
My point is the OP used "reasoning" which, while useful in creating or validating a conversion factor, doesn't solve the equation by itself whereas, after including it in the calculation, simple cancellation does :
##100,000 \cancel t \times \frac{1,000kg}{\cancel t} = 100,000,000kg##
I believe that such equation is not correct.
##1000~kg/t## is simply a rate, a proportion.
It is used only because it is useful in mathematical operations, where it can be cancelled to obtain the desired units.
IMHO, it is not different from ##3600~s/h## or ##1000~km/m##
Is there a situation where assuming the equation is correct will get you in trouble?
I agee that it is not different from 3600s/h or 1000m/km.
It is not incorrect if used as a conversion factor ; but the OP specifically asked "Are we allowed to multiply like that"... then proceeded to not bother, or at least not show the bother.
I am looking for the substantive reason that you believe it is sometimes wrong.
Frabjous said:
I am looking for the substantive reason that you believe it is wrong.
That I believe what is wrong ? That ##100,000t = 100,000t## is not a useful answer for "convert from tonnes to kg's" ?
I agree that it is not different from 3600s/h or 1000m/km.
No, unless it is taken out of context.
It may be mathematically correct, but I don't know enough to see any value in something like
##1=1~kilo-banana/1000~bananas##.
Handwritten unit conversion on a tablet: the example asks to express 320 revolutions per minute in radians per second. Fraction 320 rev/1 min times 1 min/60 s times 2π rad/1 rev, with the units cancelled out.
Obviously you have never studied economics on the Planet of the Apes. :wink: Low utility situations do not invalidate a concept.
There are known pitfalls when dimensionality comes into play. For example, the addition of non-dimensional numbers or the dimensional equivalence of torque and energy. We struggle through.
