Why Is My Photoelectron Energy Calculation Off in Auger-Effect Problem?
  • Thread starter Thread starter Antti
    Energy
Antti
This problem is straight from Haken & Wolf - The Physics Of Atoms And Quanta, 7th edition. It's problem 18.9 on page 336. If you happen to have the book that is.
Problem text:
The L_{I} absorption edge in tungsten is at 1.02 Å. Assume that a K_{\alpha} photon is "absorbed" by one of the 2s electrons by an Auger process. Determine the velocity of the photoelectron released.
Attempted solution:
I've used formulas 18.3 and 18.6 in the book. I can use
\bar{\nu}_K_\alpha = \frac{3}{4} R (Z-1)^{2} (18.3)
to get the wave number for the K_\alpha line. I inserted the Rydberg constant and tungsten atomic number, R = 10973731 and Z = 74, and got the wave number 4.386 * 10^{10} inverse meters. This corresponds to the energy = 8.7124 * 10^{-15} Joules. Next I use
E_{kin} = hv_K_\alpha - E_L (18.6)
I set hv_K_\alpha = (the energy I calculated) = 8.7124 * 10^{-15} and E_L = (energy of the ebsorption adge given in the problem) = 1.9475 * 10^{-15}. Subtracting the second energy from the first gives
E_{kin} = 8.7124 * 10^{-15} - 1.9475 * 10^{-15} = 6.765 * 10^{-15} Joules
The correct answer is 5.57 *10^{-15} Joules according to the book. So I'm not that far off but I can't figure out what I've missed.
Your answer looks to be correct, except that you've calculated the KE, when the question asks for the velocity.
Okay, seems like my crappy first post is no longer editable... EDIT: fixed! :)
Gokul: The book gives both the kinetic energy and velocity of the electron in the answer. I have only compared the first value since the velocity can't turn out right if the kinetic energy is wrong. So my answer isn't correct. I should have been more clear about this, sorry.
For the KE, I get almost exactly the same number that you got (6.8*10^{-15}J), and I think Moseley's law is more than sufficiently accurate for 2 sig figs.
I see. Well that obviously raises the question about how they got the answer in the book. I think you can understand that I'd rather trust the authors than you ;)
I understand.
To make sure you've understood the principle properly, and feel confident that you have, you should work through part 4 of the solved example on pg. 334 and make sure you get the correct answer. You could also try more problems from other books.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
