Why is the speed of light the same everywhere in the Universe?
  • Context: Undergrad
  • Thread starter Thread starter Rick16
    masses Speed of light
The discussion revolves around the question of why the speed of light is considered to be the same everywhere in the universe. Participants explore theoretical implications, assumptions in physics, and the relationship between light speed and gravitational effects, as well as the potential for varying physical laws across different regions of space.
  • Some participants propose that the speed of light could be affected by mass, suggesting that it might differ in various regions of space, such as within the solar system versus interstellar or intergalactic space.
  • Others argue that the speed of light is invariant due to the assumption that it moves along null geodesics, supported by experimental evidence.
  • A participant questions how experimental evidence can support the speed of light's invariance in distant locations.
  • Some assert that there is no evidence indicating that the laws of physics vary across different locations or times, maintaining that the same physical laws apply universally.
  • Participants mention significant unexplained phenomena, such as the accelerated expansion of the universe and dark matter, while discussing the need for alternative theories like MOND.
  • There is a distinction made between the speed of light in vacuum and in other mediums, with one participant noting that light travels slower in glass.
  • Some participants emphasize the importance of the fine structure constant in discussions about light speed and its implications for physical laws.
Participants express differing views on whether the speed of light is truly invariant across the universe, with some supporting its constancy based on current theories and experimental evidence, while others question this assumption and suggest the possibility of variation due to mass or other factors. The discussion remains unresolved with multiple competing views present.
Participants highlight the need for mathematically sound models to support claims about varying physical laws, and the discussion includes references to unexplained phenomena that challenge current understanding without providing definitive solutions.
  • #31
Rick16 said:
It is attracted? That is new to me, except in the case of a black hole. If light is attracted by the star that sends it out, wouldn't that imply that it speeds up the farther away it gets from the star since the attraction decreases with distance?
The attraction is most easily seen as a deflection for light from a distant star passing by the sun on its way to a telescope on Earth. [This is the Eddington experiment mentioned by @PeroK in #20].
We see a resulting change in the apparent direction to the far away star when the sun passes nearby and an eclipse allows us to see.
Since light always moves at ##c## in vacuum, attraction in the radial direction does not manifest as a slow down. Instead, it manifests as a red shift for light climbing up or a blue shift for light falling down.
The red shift or blue shift is cumulative, of course. It reflects the difference in gravitational potential. A sort of integral of the tangential component of gravitational acceleration along the trajectory.
  • #32
For Newtonian gravity, the speed of light can indeed change. This is another quantitative demonstration of the deficiency of Newtonian gravity for relativistically moving objects. However, it would not speed up as it gets further away, it would just decelerate less.
For general relativity, the local speed is unchanged, even in the case of a black hole. Only the direction changes. Both the fact that in GR the speed is unchanged and also the quantitative amount of the change in direction are consistent with experiment.
  • #33
Dale said:
Why not? The Newtonian acceleration is independent of the mass. So it is easy to account for the acceleration in the model. Why would you say it cannot be used?
I would say it like this: The Newtonian model is correct for nonzero masses. Therefore it applies to nonzero masses. But it is not correct for zero mass. Therefore it does not apply to zero mass. What is wrong with this reasoning?
  • #34
What's wrong is that it is just an assertion without proof. Can you show mathematically that the Newtonian model has a discontinuous limit for ##m\rightarrow0##?
  • #35
Since Newton's law of gravitation predicts that light would speed up (or decelerate less) the farther away it gets from a star, and this prediction is generally taken to be incorrect, isn't this proof enough, i.e. proof by counterexample?
  • #36
Dale states in post #32 that "For Newtonian gravity, the speed of light can indeed change." Can you cite a reference that supports your claim that "this prediction is generally taken to be incorrect"?
  • #37
References can be found throughout this thread. My original question was whether the speed of light is constant everywhere in the universe, and I was told that it is. It is apparently a general consensus among physicists that the speed of light is constant, which means that physicists take the prediction of the Newtonian model to be incorrect. If it is really incorrect or just assumed to be incorrect -- that is exactly at the heart of my original question.
  • #38
If the constancy of the speed of light were an indisputable fact, then this fact could be used for a proof by counterexample that the Newtonian prediction is incorrect, right? If you say that the constancy of the speed of light is not enough to invalidate the Newtonian model, shouldn’t I conclude that the constancy of the speed of light is not an indisputable fact?
  • #39
There is no doubt that the Newtonian prediction is incorrect.
We have been arguing about what exactly the Newtonian prediction is. You cannot answer that one by physical experiment. It is a question of language and logic, devoid of physical significance.
  • #40
Okay, if I don’t have to prove that the Newtonian prediction is wrong, I thought that I would repeat my question from this morning, but I think I have found the answer myself. I have to learn to better distinguish between what happens in nature and what is part of a specific model. I will now shut up and read more books. Thank you very much.
  • #41
The Newtonian model is not correct for non-zero masses either. So that is not the concern. We know that the Newtonian model produces predictions about the motion of both massive and massless objects that are incorrect because they do not match experiment.
The concern is what is the prediction for a massless object, regardless of its correctness. Saying that the prediction is incorrect actually recognizes the fact that there is a prediction.
Again, decelerating less is not at all the same as speeding up.
Yes, but it proves a different thing. It proves that Newtonian gravity is not a correct theory in that respect. It does not prove that it doesn’t make a prediction.
  • #42
Light bending around the gravity of the sun was observed with the understanding of Newtonian physics and reported in German by Johann Soldner in 1801 in Germany. https://en.wikisource.org/wiki/Tran...on_of_a_Light_Ray_from_its_Rectilinear_Motion
Henry Cavendish did the same in 1784, but never published it. Although slightly different assumptions on the model for the source of the light, at the 1st order approximation, they agree, both only-half the value predicted by GR and confirmed by British scientist Eddington's solar eclipse experiments in Africa during the eclipse of 1919. There was considerable unrest at the time, during WWI, which made this revelation unlikely from political bias. The accuracy of Eddington's formula of light bending were found accurate with later measurements in the 50's and subsequent eclipses. Einstein's prediction in 1915 of gravitational waves were observed in 1974 indirectly and accurately 100 years after 1915 from much stronger pulsar gravity fields. https://www.wikiwand.com/en/General_relativity Many scientists contributed to these revelations to support Einstein's Gravity equations.
https://www.wikiwand.com/en/Tests_of_general_relativity
https://www.wikiwand.com/en/Eddington_experiment#Expeditions_and_observations
  • #43
I want to come back to this briefly. My main point was that I thought it might be possible that the speed of light would be affected by gravity. I have now come up with an argument to convince myself that this is not the case, using the equivalence principle:
For an observer, who accelerates radially away from a star, the speed of light coming from the star would not change, because according to special relativity the speed of light does not depend on the speed of the observer. According to the equivalence principle, the speed of light can then not change within a gravitational field either. Can this be considered a valid argument? I am aware that I use acceleration within the context of special relativity, but what is important here is not actually the acceleration but just the fact that the velocity of the observer does not make a difference for the speed of light, whether the observer accelerates or not.
I have also identified one reason for my confusion. A black hole is generally described as an object so dense that nothing can escape from it, not even light. This seems to suggest that light is affected by the gravitational pull of the black hole, and if that is the case, why would light not be affected by the gravitational pull of stars as well? Here is my current understanding of the situation:
Photons do lose energy when they move away from a gravitational source, but this energy loss only affects the photons’ oscillatory frequency, not the speed of propagation of the wave (I am not sure why this is so). Anyway, when light “tries” to escape from a black hole, it is not the wave that is slowed down to a standstill, but it is rather the photon oscillations that are slowed down to a standstill, and once the photons stop oscillating, the wave collapses. Is this about the right way to look at it?
  • #44
No. That is not what the equivalence principle says.
Photon energy is not an intrinsic property of the photon. It is a property relative to a coordinate system. Photons do not lose energy as such. Instead, we judge their energy according to a coordinate system where the receiver is [locally] at rest. And relative to a coordinate system where their transmitter was [locally] at rest. Those are not the same coordinate system. There is no requirement that the energies be identical.
The speed of light is always locally ##c## regardless of the locally inertial coordinate system that one adopts and regardless of photon energy.
The idea that the horizon in a black hole is some kind of stationary place is quite wrong.
The horizon is a so-called "outgoing null surface". Locally, it sweeps past any material object at the speed of light. This is an invariant fact. It does not depend on how fast the material object is moving. The relative speed of the horizon as it sweeps past is always ##c##.
In a more global sense, the velocity of the horizon is a more slippery concept. One has to select a coordinate system and report the velocity relative to those coordinates. In the curved space time of general relativity, there is no such thing as inertial coordinates that extend to the horizon. The velocity of the horizon depends on the choice of non-inertial frame. In Schwarzschild coordinates, for instance, the velocity is undefined because the coordinates do not cover the horizon itself.
  • #45
No. The general point is that the speed of light in a gravitational field isn't well defined. It is well defined in a small region, in which case you can apply special relativity and deduce that you will always see it pass you at ##c##. Over large regions, the speed depends on how you choose to define "space", because that affects how far you've decided the light travels.
Event horizons are not places. They are null surfaces, which are neither places in space nor moments in time. Critically, if you pass through it it will pass you at the speed of light according to your local measurements. That's a local explanation for why light cannot escape it - it would need to be going faster than light to catch the horizon. It can hover at the horizon (in theory - this is an unstable situation, like balancing a pencil on its point).
Curved spacetime is a strange place. The only really sensible way to make sense of it is to learn about the geometry.
  • #46
Thank you, I will heed this advice.
But, as usual, there are confusing points in the answers, the most confusing one being this:
How can the speed of light have the constant value -- suposedly everywhere in the universe -- of 300,000 km/s and at the same time be ill defined? I understand that the speed depends on the definition of space, but this is still confusing. The whole point of this thread is that I am trying to understand why light should have this same value of 300,000 km/s everywhere, and I feel that I am now farther away from understanding it than before.
That's a pity. The equivalance principle is really helpful to understand other phenomena like gravitational lensing and redshift and I was hoping that it could be used to understand this point as well. But if the speed of light is not well defined, I guess the principle cannot be used here. It looks like I have to get back to manifolds and Christoffel symbols.
  • #47
No matter where you go, the speed of light will have the constant value. Locally. So if you are way over there in Andromeda and you measure the speed of light with local equipment, you'll get ##c##.
But if you are sitting over here, trying to measure a velocity way over yonder, there is a problem. Your coordinates do not reach. Or if they do reach, they curve on the way. That is a problem.
There is a way around the problem: parallel transport. It is a mathematical way to take a velocity over there and bring it up close without having to involve a coordinate system. You move the velocity incrementally over a path from there to here.
Unfortunately, it turns out that in curved space time, the velocity you end up with over here depends on the path over which you do the parallel transport.
So velocity at a distance is not a well defined thing in general relativity.
  • #48
Thanks a lot, this is a very helpful comment. The same goes for the comment about photon energy not being an intrinsic property of the photon. I know about parallel transport, but this is the first time that I hear that it is path dependent in GR.
  • #49
"Light always travels at ##3\times 10^8\mathrm{ms^{-1}}##" is true in flat spacetime (and only in inertial coordinates there). In curved spacetime it's true if you measure over small enough regions, ones that are small enough that the effects of curvature are negligible on your experiment. That means that light will always pass you at ##3\times 10^8\mathrm{ms^{-1}}## as measured by your own pocket ruler and watch. But it is not true over larger regions, at least not in general, because velocity is not well defined for things that aren't close enough for you to neglect the effects of curvature. I see @jbriggs444 has already covered this while I was typing, so I'll leave it there.
  • #50
The change in frequency in the Doppler effect is not an intrinsic change in the wave, but a result of the motion of the source and receiver. In terms of light travelling in a vacuum, the redshift or blueshift is a result of the relationship between the source and receiver. This can be relative motion; and/or, a difference in gravitational potential around a star or planet; and/or, a separation in expanding space.
In general, it's false to imagine the light intrinsically changing frequency as it travels.
  • #51
When we're talking about the speed of light being the same everywhere, we mean locally: we measure the speed of light inside our lab, and our lab is small enough that curvature effects are negligible across its width. No matter where in the universe we position our lab, as long as it is small enough we will get the same result when we measure the speed of light.
When we say that the speed of light is ill-defined in curved space, we mean globally: there is no sensible definition of the speed when the curvature effects are not negligible.
  • #52
Yes, the photon energy comment should not have surprised me. There is no proper time for light waves, consequently there is no proper frequency, consequently there is no intrinsic energy.
But what about photons losing energy on their way out from a star? This loss of energy does decrease their oscillatory frequency, doesn't it?
  • #53
Both the energy and frequency as measured by observers hovering at constant altitude decrease as they travel upwards, yes.
  • #54
This thread has been going on for three months now. Are we any closer to resolving it? These messages remind me of Frank Gorshin in the old Batman TV show: "Riddle me this, Caped Crusader!"
Lets try another direction. Do you believe there are 12 inches in a foot everywhere in the universe? Even in distant galaxies? Even near black holes?
  • #55
In this thread you have mentioned manifolds and Christoffel symbols, which suggests you are studying GR seriously from some academic source. Your questions, however, suggest (IMO) that you are still thinking largely in terms of classical, Newtonian physics. Somewhere along the line you seem to have lost sight of the basics of SR and GR. For example, that light has an invariant speed can be taken as a postulate of SR. In that respect, it is a presumed law of nature on which the physical theory is built.
In GR, we have essentially the postulate that spacetime is locally like SR - where locally is defined mathematically in terms of tangent spaces. That implies that when measured locally the speed of light is invariant.
Moreover, in GR there are is no global inertial reference frame - and the search for coordinate-independent laws of physics takes you into the realm of manifolds and tensor analysis and away from the Newtonian concepts that depend upon absolute space and time. IMO, you need to revise and fully digest the theoretical and mathematical basis of GR, and try to dissociate that from the intuitions of classical, Newtonian mechanics.
  • #56
Okay, I will work on it. Thank you for the advice.
  • #57
Vanadium 50 said:
Well first, the speed of light is not the same everywhere in the universe. I am looking at a piece of glass now, and the speed of light is measurably slower in it.
The speed of light in vacuum is the sane everywhere, just as the speed of light in glass is the same everywhere. Why wouldn't it be? What would make vacuum here be different than vacuum there?
Indeed, but the speed of light differs in different transparent substances. So its speed in some substance unknown in our solar system might be different and unknown surely? Could patches of dark matter in the universe affect its speed?
  • #58
It's good to ask questions and think outside the box, too, though, as you have been doing. New discoveries sometimes come when there is a conceptual leap which is then tested and found to be correct.
  • #59
Of course. So what? That has no effect on the fact that the speed of light in a vacuum is everywhere the same.
No, since dark matter doesn't react with em radiation but even if it did, so what? That would have no effect on the fact that the speed of light in a vacuum is everywhere the same.
  • #60
No.
From https://home.cern/science/physics/dark-matter#:
"Unlike normal matter, dark matter does not interact with the electromagnetic force. This means it does not absorb, reflect or emit light, making it extremely hard to spot."
So by its very definition dark matter is perfectly transparent and cannot alter the propagation of light (including its speed) in any way. That's why it can't be seen!
  • · Replies 16 ·
  • · Replies 45 ·
  • · Replies 51 ·
  • · Replies 19 ·
  • · Replies 130 ·
16K
  • · Replies 22 ·
