Why is there a universal speed limit c?
  • Context: Undergrad
  • Thread starter Thread starter CosmicVoyager
    Limit Speed Universal
210 replies · 45K views
CosmicVoyager
Greetings,
Why is there a c? Why is there a speed limit to the universe? Why is there a limit to how quickly a cause can follow an effect at distance? Why is there a "causality constant"?
What is(are) the limiting factor(s) that make it what is? The speed limit is a consequence of what? Is what we know to be the speed limit the result of measurements? Or is it a logical problem that can be figured out in a thought experiment?
What was God thinking? lol
Thanks
CosmicVoyager said:
Greetings,
The reason I asked that question https://www.physicsforums.com/showthread.php?p=3174840 was so that I could ask this question properly.
Thanks
Of course I do not know the answer to your question. However, you might be interested in considering the following. Perhaps nature decided to manifest its physics on a R4 manifold with a 4-dimensional space populated with 4-D observers. Observers could take the form of objects with relatively long world lines (relatively short 3-D lengths) oriented in various ways. Affine coordinates were selected as a background for the natural positioning of the 4-D objects in patterns that would manifest physics. That is, the same physics would be manifest to all observers, regardless of the orientation of the world lines.
There are world lines for inanimate 4-D objects and worldlines for 4-D observers. However, the world lines, extending along the X4 axis of a given object, would be oriented with angles that would not exceed 45 degrees. Along with this, observers experience the phenomena of time--the observer (in some sense) moves along his world line at the speed, c. And any observer, at any instant of time, would "live in" a 3-D cross section of the 4-D universe at the corresponding point along his world line. Further, that view would be along X1 of his affine coordinates (X2 and X3 are suppressed in this example).
In the sequence of views below, different observer world lines are shown, corresponding to increasing velocities with respect to a rest frame. The X1 axis always rotates to an angle symmetric with the X4 relative to the 45 degree world line. You see that if the world line of an observer rotated 45 degrees clockwise, then the X1 would rotate 45 degrees counter clockwise, and the X4 and X1 would then be colinear. That would represent some kind of physical boundary--the observer would not be able to make any sense of such a 3-D cross-section view of the manifold. Correspondingly, the physics is designed to avoid this colinear result for observers.
Of course that 45 degree world line is a 4-dimensional photon, having the velocity, c. Thus, the speed of light, in this fanciful description of 4-dimensional space inhabited by 4-D observers, is a natural consequence of an affine space designed for 4-D observers who must experience the same physics, regarless of their world line orientation. Accordingly, all observers will obtain the same value, 186,000 mi/sec, when measuring the speed of light, regardless of an observer's speed.
The answer to a "why" question like this can depend on what you take to be an unprovable postulate. The following FAQ entry is aimed at a slightly different question, which is why c is frame-invariant. However, once you believe in a frame-invariant speed, it's pretty hard to escape the conclusion that that speed is also the speed limit on cause and effect. As for the reason c has the numerical value it has, the reason is that we defined a system of units in which it has that value. Relativists often find it more convenient to work in a system where c=1.
FAQ: Why is the speed of light the same in all frames of reference?
The first thing to worry about here is that when you ask someone for a satisfying answer to a "why" question, you have to define what you think would be satisfying. If you ask Euclid why the Pythagorean theorem is true, he'll show you a proof based on his five postulates. But it's also possible to form a logically equivalent system by replacing his parallel postulate with one that asserts the Pythagorean theorem to be true; in this case, we would say that the reason the "parallel theorem" is true is that we can prove it based on the "Pythagorean postulate."
Einstein's original 1905 postulates for special relativity went like this:
P1 - "The laws by which the states of physical systems undergo change are not affected, whether these changes of state be referred to the one or the other of two systems of co-ordinates in uniform translatory motion."
P2 - "Any ray of light moves in the 'stationary' system of co-ordinates with the determined velocity c, whether the ray be emitted by a stationary or by a moving body."
From the modern point of view, it was a mistake for Einstein to single out light for special treatment, and we imagine that the mistake was made because in 1905 the electromagnetic field was the only known fundamental field. Really, relativity is about space and time, not light. We could therefore replace P2 with:
P2* - "There exists a velocity c such that when something has that velocity, all observers agree on it."
And finally, there are completely different systems of axioms that are logically equivalent to Einstein's, and that do not take the frame-independence of c as a postulate (Ignatowsky 1911, Rindler 1979, Pal 2003). These systems take the symmetry properties of spacetime as their basic assumptions.
For someone who likes axioms P1+P2, the frame-independence of the speed of light is a postulate, so it can't be proved. The reason we pick it as a postulate is that it appears to be true based on observations such as the Michelson-Morley experiment.
If we prefer P1+P2* instead, then we actually don't know whether the speed of light is frame-independent. What we do know is that the empirical upper bound on the mass of the photon is extremely small (Lakes 1998), and we can prove that massless particles must move at the universal velocity c.
In the symmetry-based systems, the existence of a universal velocity c is proved rather than assumed, and the behavior of photons is related empirically to c in the same way as for P1+P2*. We then have a satisfying answer to the "why" question, which is that existence of a universal speed c is a property of spacetime that must exist because spacetime has certain other properties.
W.v.Ignatowsky, Phys. Zeits. 11 (1911) 972
Rindler, Essential Relativity: Special, General, and Cosmological, 1979, p. 51
Palash B. Pal, "Nothing but Relativity," http://arxiv.org/abs/physics/0302045v1
R.S. Lakes, "Experimental limits on the photon mass and cosmic magnetic vector potential", Physical Review Letters 80 (1998) 1826, http://silver.neep.wisc.edu/~lakes/mu.html
CosmicVoyager said:
We can prove that massless particles must move at the universal velocity c.
I am asking why there is a "universal velocity c."
Thank you for your answer, but I don't understand it :-( One reason is the terminology. I am very good at explaining anything to anyone. It is a rare talent I have. But first I need to understand it. I am hoping someone can explain it to me closer to the way I would. Not assuming one knows what manifolds and world lines are. To break it down step by step. Illustrations would help/ I don't understand the one above.
I will try to read this more times and see if I can translate it.
I think the spacetime diagrams with the world lines might be a way for you to grasp some fundamental concepts. I realized that you might not understand the diagrams at all, but I didn't really know your background well enough to judge. It was a description that I hoped would not get too detailed and lengthy.
I can walk you through the understanding of the spacetime diagrams if you wish to pursue things in that kind of detail. And there are others on the forum here who are better than I at explaining things.
Regarding th diagram, what are X1, X2, X3, and X4? Is X4 the observer? Why does it also say X4 is time? I can't make out what is at the end of the black lines. It this a 2D graph? What does it mean by the blue axes rotate?
"The blue X4 and X1 axes would appear to converge on themselves, becoming colinear, in the limit as the observer's speed approaches light speed."
Huh? LOL "in the limit"? "appear to converge"? What does how something appear have to do with how fast things can travel?
Greetings,
Here are examples of what a conceptual explanation as to why there is a universal speed limit would be like, if they were true :-)
Ideas:
- Everything in the universe is moving through a medium. The medium causes resistance. The faster something goes the greater the resistance is. The resistance increases exponentially similar to air resistance increasing on a car.
- Time and space are made up of indivisible units. The fastest possible speed is one space unit per unit of time, otherwise things would be skipping over points in space.
Does anyone know the answer and able to explain it?
Thanks
Because God said so.
Really, there is no answer to this question. We OBSERVE the universal speed limit of the speed of light. However, WHY this is the case is impossible to answer. If there were no speed limit, you could formulate a universe that works perfectly well. It would be different than what we see in our limited-speed universe, but that universe would probably think "hmm, why is there no speed limit?". It just is what it is. Any explanation you would get is not an answer to your question, it's just a way of explaining what the world is like BECAUSE there is a universal speed limit, not what brought about it in the first place.
There is an answer. It's just no one has thought of it yet :-)
"but that universe would probably think "hmm, why is there no speed limit?""
No, if they know of nothing to limit the speed, there is no reason to think there should be a limit.
Right now, I don't know of anything to restrict speed, other than the total energy available to accelerate something."Any explanation you would get is not an answer to your question"
Yes it would, like the two examples answers I gave.
What is it that is restricting the speed?
I think the Lorentz post by bcrowell might explain it, but I do not understand it.
Well, like bcrowell was saying, when asking 'why' questions, you inevitably end-up with a sequence like: Why is 'A' true? Because 'B' is true. Well, then why is 'B' true? Because 'C' is true. Well, then why is 'C' true? ... and you can do this for a long time until the answer comes back as either "Because 'A' is true" or "Because we have observed it in an experiment, and we know Z to be true".
Either way, you need to pick one of the answers in that chain and accept it to be true apriori based on experiments and observations (this will be your postulate).
Now you can directly accept P2* as a postulate (ie. we know there is a speed limit because we have observed it) and then, well, that will be your answer. It's the physics equivalent of "Because I said so ! "
If you want to dig deeper ,you can ignore P2*, assume other postulates to be true, look into other physics postulates (causality, gravity) and then from those experiments you can infer that there MUST be a universal speed limit. In this case your answer will be " there is a speed limit as a property of the universe, because other properties of the universe (properties that we have observed and measure and know to be true) require a speed limit".
Either way you are not better off,really.
'c' as a speed limit is a property of our universe that makes it behave like it does. Changing this speed limit's value (or removing it), much like changing any other property of the universe, would result in a totally different universe where many of the things we are accustomed to might not exist: cause and effect, differences between past an present, time flowing in a single direction.
Did I get it right, bcrowell ?
I am extremely confident that I will understand with there is a speed limit, and when I do I will be able to explain it in a few sentences. And I will ask why someone else who understood couldn't have done that. I know because it keeps happening. There is an explanation for why there must be a limit and why it is what it is.
From another thread:
jambaugh said:
A better understanding of c, is not so much as the speed limit but as a unit conversion factor. The E=mc^2 equation is an identity "mass is energy" plus a unit conversion.
1kg = c^2 joules.
In that context, also note that "speed" is just a slope in space-time and unitless when working in common units. I find this helps to understand the "speed limit" as a geometric phenomenon instead of a dynamic one.
This is excellent. I think this is headed in the right direction. Conceptually, the important form of the equation e=mc^2 is c=squarroot(m/e). The real question is why is the speed limit of the universe equal to the square root of the mass of any object divided by it's energy. I get the feeling that it must be, by the very definitions of what mass and energy are. I don't see it yet though. I think this is very close. Something to do with the fact that energy is motion. I will think about it. If anyone can illustrate why that must be so, please do.
The square root of mass divided by energy. Hmm...
As explained in #3, the answer to this sort of question depends on what you want to use as postulates. Spell out your postulates for us, and then people can take a crack at answering your question.
Maybe if chaotic inflationary cosmology is right, and there is a multiverse, with each universe having different values for all the constants and forces, perhaps the speed of light came to be like it is merely by chance. In some other universe it might be faster, or slower, than it is in our universe.
As noted there is no known answer...any more than we know why an electron and proton have the charge we observe...
but is likely due one of the following reasons:
(a) nature "selected" this UNIQUE factor because it's a constant that makes our unique and one time one of a kind of universe (and hence us) possible,
(b) It's one of an infinite number of possible situations among an infinite number of universes..and this one happened to give rise to us...
(c) "God", Allah, Budda, or anoher designer of your choice, picked it...and maybe us, too...
Why not? Historically, when we did not know of a speed limit, it was asked why there is no speed limit. Why wouldn't the converse be true?
No, the speed of light is the restriction, even with infinite amounts of energy available.
This is getting ot what another poster said. If you use your idea that there are some sort of discrete steps things have to take in space-time or what have you, that model is probably going to be simply a consequence of this speed limit of the universe. Then again, maybe it is the other way around? Who knows, it's the chicken and the egg problem. The speed of light can be your assumption and ideas B, C, D, and E follow from the speed of light. Or you can take idea B, C, D, and E as postulates, and the speed of light being constant will follow from that.
The thing is, most people see the speed of causality as the speed limit and use it as one of the many postulates when constructing theories. So theories never give a "why" to that question, only ideas that follow. You COULD postulate something else completely unrelated to what we know about physics and if by some miracle you came to the conclusion that the speed of light has to be constant (and of course, everything else we already know about physics), but that would be wild to say the least.
I disagree. Depending on what you take as your postulates, there can be a known answer. If you choose the postulates used in this paper Palash B. Pal, "Nothing but Relativity," http://arxiv.org/abs/physics/0302045v1
, for example, then the existence of a frame-invariant speed limit is a theorem that can be proved from those postulates.
I am not asking something like you describe above. I am not asking something like why an electron has the charge is does.
What am asking is the same way I would ask why is there a limit to how much mass an object can have, or why is there a limit to ow big and object can be, or why is there a limit to how fast something can spin? It seems there is not reason there should be limits, ad if there is what is limiting factor? What is causing the restriction?
CosmicVoyager said:
Originally Posted by jambaugh View Post
" A better understanding of c, is not so much as the speed limit but as a unit conversion factor. The E=mc^2 equation is an identity "mass is energy" plus a unit conversion.
1kg = c^2 joules.
In that context, also note that "speed" is just a slope in space-time and unitless when working in common units. I find this helps to understand the "speed limit" as a geometric phenomenon instead of a dynamic one."
I hypothesize that it is not a random coincidence that the square root of (m/e) exactly equals the speed limit. I think there is some connection between matter and energy and the speed limit.
Another way to look at it is that everything has wave nature (read up on De Broglie, http://en.wikipedia.org/wiki/Matter_wave). Therefore nothing can go faster than the speed of light, just as no sound wave can go faster than the speed of sound.
Note that different people give different answers to that question, and probably nobody can prove to really have the right answer.
Harald
This argument doesn't make sense. There is no (direct) logical connection between the speed of an electron wave and the speed of a photon wave.
This is incorrect. Once you fix a set of postulates, there is a right answer. See http://arxiv.org/abs/physics/0302045v1
See Einstein, "Does the inertia of a body depend upon its energy content?," Annalen der Physik. 18, 639: 1905. English translations are available online.
My answer here:
https://www.physicsforums.com/showthread.php?t=478783&page=2
in CosmicVoyager's similar thread explains why c defines a limit.
Why c holds the value it does, though, is a different matter entirely. Naturally, the units used are meaningless since metres are derived from the observed speed of light in vacuo and the second relates to Caesium decay. This means that the 2.99897(or whatever) ms^-1 number is not significant as a quantity, but as a unique value, like PI (which is ultimately defined by the curvatre of spacetime), or the the natural logarithm/root, or the fine structure constant, or the universal gravitation, it has a special characteristic of being a constant (to our current understanding, theories of c variance notwithstanding) in our universe.
Regardless of the wavelength of light, how much energy it has, it maintains the constant speed. Unlike massive objects for which the greater their mass, the more energy is needed.
That bosons have a fixed speed, DeBroglie showed how E is related to wavelength as well as mass, giving a means to describe massless objects and waves with momentum equivalent to their massive counterparts. Introduxing Planck's constant, quantised the relativistic energy and allowed working with manifest in the same terms of energy and momentum as massive entities.
______
c=\/h^2.f.L
That frequency and wavelength are related according only to c, c is directly dependent only on the value of another constant.
It depends on who you are explaining it to. If he doesn't understand your language and terms you are using, you first have to teach him that. If you will first learn a little analytic geometry (affine coordinates, how to graph functions, etc.) and the Pythagorean theorem, then you will understand it after looking at my post #5 along with a simple two-line derivation of the Minkowski metric.
You are not even close.
You are going down the wrong path. First figure out what you have to go off and study to understand bcrowell's first post (he has written a first class book on gerneral relativity, but it may be advanced from where you seem to be with your background). Google special relativity and also spacetime diagrams and see what you come up with.
He/she might find this easier going: http://www.lightandmatter.com/html_books/6mr/ch01/ch01.html A similar treatment is Palash B. Pal, "Nothing but Relativity," http://arxiv.org/abs/physics/0302045v1
That wasn't implied; instead it implies that an electron will be increasingly light-like at higher velocities, and cannot possibly move faster than light.
The OP asked "What is causing the restriction". I interpreted this as a physical question, not a question about human postulates that formulate the restriction!
CosmicVoyager, did I understand you correctly?
Harald
Harald
Yes, I mean what is holding the light back. It is like an invisible hand jumps up in front of things at c and stops them from going faster.
I suspect my paradigm might be completely wrong and I need to shift, in which case I need why it is wrong explained. It seems the same as if I were adding more and more to an object to increase it's mass, then suddenly the mass stopped increasing, and I think "What the heck is going on?"
It's impossible to do logical reasoning without starting from some assumptions. Failing to spell out one's assumptions is simply sloppy reasoning.
