Why is there something, rather than nothing?
  • Thread starter zankaon
27 replies · 7K views · last reply
zankaon
The opposite of a great truth is also a great truth - T. Mann
For example, the opposite of empty set {} is a non-empty set, such as the set of integers, or the finite sets we experience in our mundane life.
also a lesser context can define the greater context, and vice versa.That is, each is defined by what it is not i.e. its antithesis; for example, the antithesis of quanta and spacetime manifold.
so what if our universe, or a divergent cyclical set of universes (hence non-empty set with 1:1 correspondence to integers), has a greater context of simplest case i.e. empty set? Might this be indirectly inferred; of course without perturbing such alleged greater context? Such as if there were multiple 'universes'.
1. Why assume that the configuration 'nothing' is default?
2. Why assume that 'something' needs to come out of 'nothing' to be called 'something'?
3. Quantum Mechanics has shown that there is no fundamental difference between 'something' and 'nothing'.
The reason that something exists is because the state of nothing is unstable, decaying into something.
[tex]\Delta E \Delta t \ge \frac{h}{2\pi}[/tex]
Nequaquam Vacuum
"nothing" is a human idea- the Universe is
The Jocaxian Nothingness [Nada Jocaxiano]
João Carlos Holland de Barcellos
translated by Debora Policastro
The “Jocaxian Nothingness” (JN) is the “Nothingness” that exists. It is a physical system devoid not only of physical elements and physical laws, but also of rules of any kind.
In order to understand and intuit JN as an “existent nothingness”, we can mentally build it as follows: we withdraw all the matter, energy and the field they generate from the universe. Then we can withdraw dark energy and dark matter. What is left is something that is not the nonexistent. Let us continue our mental experiment and suppress elements of the universe: now, we withdraw physical laws and spatial dimensions. If we do not forget to withdraw anything, what is left is a JN: an existent nothingness.
JN is different from the Nothingness we generally think of. The commonly believed nothingness, which we might call “Trivial Nothingness” to distinguish it from the JN, is something from which nothing can arise, that is, the “Trivial Nothing” follows a rule: “Nothing can happen”. Thus, the “Trivial Nothingness”, the nothingness people generally think of when talking about “nothingness”, is not the simpler possible nothingness, it has at least one restriction rule.
Jocax did not define the JN as something in which nothing exists. Such definition is dubious and contains some contradictions as: “If in the nothingness nothing exists, then, nothingness itself does not exist”. No. First, Jocax defined what it means to exist: “Something exists when its properties are fulfilled within reality”. Therefore, JN has been defined as something that:
1- Has no physical elements of any kind (particles, energy, space, etc.)
2- Has no laws (no rules of any kind).
Being so, JN could have physically existed. JN is a construction that differs from the “trivial nothingness” since it does not contain the rule “Nothing can happen”. That way, Jocax liberates his JN from semantic paradoxes like: “If it exists, then it does not exist” and claims that this nothingness is SOMETHING that could have existed. That is, JN is the simpler possible physical structure, something like the minimal state of nature. And also the natural candidate for the origin of the universe.
We must not confuse the definition of the NJ with rules to be followed. It is only the declaration of a state. If nature is in the state defined by conditions 1 and 2 above, we say it is a “Jocaxian-Nothingness”. The state of a system is something that can change, differently from the rule that must be followed by the system (otherwise it would not be a rule). For example, the state “has no physical elements”; it is a state, not a rule because, occasionally this state may change. If it was a rule it could not change (unless another rule eliminated the first one).
Being free of any elements, JN does not presume the existence of any existing thing but its own and, by the “Occam’s Razor”, it must be the simpler state possible of nature, therefore with no need for explanations about its origin. JN, of course, does not currently exist, but may have existed in a distant past. That is, JN would be the universe itself – defined as a set of all existing things – in its minimal state. Thus we can also say the Universe (being a JN) has always existed.
JN, as well as everything that can be understood by means of logic, must follow the tautology: “it may or may NOT happen”. This tautology – absolute logical truth – as we shall see, has also a semantic value in JN: it allows things to happen (or not).
We cannot say that events in the JN must necessarily occur. Eventually, it is possible that nothing really happens, that is, JN may continue “indefinitely” (time does not exist in a JN) without changing its initial state and with no occurrences. But there is a possibility that random phenomena can derive from this absolute nothingness. This conclusion comes logically from the analysis of a system without premises: as JN, by definition, does not have laws, it can be shaped as a logical system without premises.
We shall interrupt a little in order to open up an explanatory digression. We are dealing with two types of “Jocaxian-Nothingness”: the physical object named “JN”, which was the universe in its minimal state with the properties described above; and the theory which analyses this object, the JN-Theory. The JN-Theory, the theory about the JN-object (this text), uses logical rules to help us understand the JN-Object. But JN-object itself does not follow logical rules, once there are no laws it must obey. Nevertheless, I do not believe we will let possibilities to JN-object escape if we analyze it according to classic logic. However, we must be aware that this logical analysis (JN-Theory) could maybe limit some potentiality of JN-Object.
Within a system without premises, we cannot conclude that something cannot happen. There are no laws from which we can draw this conclusion. That is, there is no prohibition for anything to happen. If there is no prohibition for anything to happen, then, eventually, something may happen. That is, the tautological logics remain true in a system without premises: “something happens or not”. If something occasionally happens, this something must not obey rules and, therefore, would be totally random and unpredictable.
We call the first JN randomizations Schizo-Creations. This schizo-creations, once they come from something without laws, are totally random and, if we could watch them, they would seem completely “schizophrenic”. Of course with the first randomizations, JN is no longer the original JN as now it owns something, that is, the JN transforms. Because JN is not limited by any laws, it may eventually also generate laws, to which its elements - now itself – would have to obey.
Let us show how the random generation of laws can produce a logical universe: suppose laws are generated randomly in a sequence. If a new law is generated and does not conflict with the others, all of them remain undamaged in the set of generated laws. However, if a law that conflicts with other laws previously generated appears, it replaces (kills) the previous laws that are inconsistent with it, since it must be obeyed (until a newer law opposes to it). Thus, in a true “natural selection” of laws, only a little set of laws compatible to each other would last. That answers a fundamental philosophical question about our universe: “Why does the universe follow logical rules?”
Thereby, the Jocaxian Nothingness is the natural candidate for the origin of the our cosmo, since it is the simpler possible state nature could present: a state of such simplicity there would not be the need to explain its existence. And, by logical consequence of this state, anything could be (or not) randomized, even our physical laws and elementary particles.
The question might be more properly stated as "Why is there zankaon's personal experience?"
OK, I agree with the generality of this, but are you saying anything new?
This is as old as Anaximander's apeiron, as old as Paticca-samuppada (Buddhist dependent co-arising). It is CS Peirce's semiotics. Are you extending these ideas in anyway or just rediscovering them?
I would suggest you consider vagueness as something even simpler than "nothingness" - even of the Jocaxian kind. Vagueness is also simpler than even nothingness's counterpart, everythingness or plenitude.
See this thread for some orientation and let us know if you are saying something different?
https://www.physicsforums.com/showthread.php?t=301514
The originality of the idea is two:
1- "WHY" the nothingness could be generate anything : Because tehre have NO LAWS.
If there is no law then there is no restriction ou conservation law too.
therefore things can happen.
( anyone explain this with the SAME idea? )
2- The question : WHY PHYSICAL LAWS MUTT OBEY THE LOGIC?
Also is explained by "natural selection" from Jocaxian nothingness.
What theory explain the origin of the physical laws?
"Within a system without premises, we cannot conclude that something cannot happen. There are no laws from which we can draw this conclusion. That is, there is no prohibition for anything to happen. If there is no prohibition for anything to happen, then, eventually, something may happen. That is, the tautological logics remain true in a system without premises: “something happens or not”. If something occasionally happens, this something must not obey rules and, therefore, would be totally random and unpredictable."
"Within a system without premises we cannot conlucde that something cannot happen...". So if we imagine a possible world in which there is absolutely nothing, it cannot be a law, in such a world, that nothing happens, because the existence of such a law would require something to substantiate it.
I see how someone could believe that to be true, but then you go on to say, "then, eventually, something may happen". But even if there is no law preventing something happening in an empty possible world, it may still be the case that nothing does, in fact, happen. That is, there is a whole range of possible worlds in which, initially, nothing exists, and because there are not even any laws, there is no law preventing something coming into existence. But there will be at least one of those possible worlds in which nothing ever does come into existence. In order to explain why there is something rather than nothing, you would have to explain why this is not the case with our world.
Yes, this is way I would look at it. If we start with every degree of freedom, then this is both everything and nothing. If things are dynamic in all directions, then no direction really exists.
So what has to be added to this chaos is constraints. And once constraints start (as you say, there could be a wide variety of proto-constraints that get tried) you get a rapid phase transition across the system because only globally self-consistent constraints will have the lawful strength to persist.
You can find good models of this in self-organising criticality - Ising models, Kauffman's autocatalytic nets, etc.
And it is also the metaphysical view put forward at the beginning of philosophy by Anaximander. C. H. Kahn's Anaximander and the Origins of Greek Cosmology is an excellent source.
Again, I think this is taken for granted by a reasonable number of people. So your foundational picture is right and deserves to be more widely understood.
But the job is then to cash out the metaphysics as physics. This would demand a much more mathematical framing of the ideas.
The answer is : By chance.
Of course the nothing could be stay as a nothing but there is a possibility to not.
It is random efect, like the time that the eletron decay a level and issue a foton:
There is no law to prevent or say what is the moment it will decay, its a random event.
But you don't say that have no laws in this system.
Beside this, you don't say you start from NOTHING, it seens in that text you link
yuou DISCARD origin from cosmo from nothingness, therefore your stuff is not a nothingness
but it is something diferent from nothingness.
If there is a chaos then there are something diferent from nothingness !
The problem is that at beginning there is no laws neither logic laws
and hence is difficult to model using mathematics because this use logic too.
Do you mean methodologically when we approach the problem we can't use logic, or do you have some insight into the beginning of the universe showing that logic and laws didn't apply :confused:?
Or the third option that I prefer. If laws are self-consistent global regularities that emerge, then the laws don't have to be "in existent" from the start so long as they are immanent.
This concept is very hard to grasp.
No time/space and no energy/matter, we have no way of knowing what happens in JN and can only speculate using the laws of our universe which do not apply to the place we are trying to describe.
So doesn’t this make any statement we make about JN complete nonsense?
Dr. Who called it E-space (but there was stuff (planets and people, Well Vampires) in it).
I think the entire universe can be summed up in a simple equation “-1+1=0” right now we are at 1 or -1 and JN would be 0 .
But that is just my best guess about the nothingness.
define "opposite".
opposite(A) = Not (A)
Do you mean methodologically when we approach the problem we can't use logic, or do you have some insight into the beginning of the universe showing that logic and laws didn't apply ?
See the text:
See the text:
I'd agree with both these statements.
I would add that opposite(A) = Not (A) has both symmetric and asymmetric possibilities.
Symmetric is when the opposites are of the same scale. So the plus and minus of charge for example.
But real opposites is about symmetry-breaking - opposites in scale.
So atom~void would be an example. The A is as small as possible and the not-A is as large as possible. Same with event and context and other local~global oppositions.
It is also an important point is that we can know that whatever is observed to come out of a vagueness must logically have been present originally as one of its potentials. But that does not necessarily exhaust all its possibilities and so define it. On the other hand, it might. So this is a live area of argument.
In that manner I think yes:
No, because if we analise it using logic, we can get a portion of the possibility we can have
from this extrange object .
The best equation for JN is :
JN = 0 / 0
Hello all,
So, would I then be right in saying that from this JN-object (manifold ?) , anything and everything could manifest itself ?
Everything being the sum of all possible ‘anythings’ that could pop up, but only some of the ‘anythings’, and certainly not everything, could subsist and sustain themselves.
Seems to me that the ‘need’ for something to emerge, become and evolve from a JN-object has so much potential and strength, that I just don’t see how a null outcome, ‘nothing’, being only one possibility out of everything, can be that dominant resultant, never mind sustain itself.
Regards,
VE
YES! Exactly.
Yes, because laws have defined to be obeied.
Thus, if another law pop into existence and contradict some old law then the old law
can not subsiste.
I don't know if I understand but,
the all infinite possibilities only one stay a nothing.
jocaxx,
I see you talk about laws, didn't you forget about that space-time, particles .. etc. Or do you think they are laws also, but then in what sense.
It is a complicated define things without laws because things are defined with its properties and if those properties keep constant in the time, we can say there is some LAW to obligue to stay constant.
Because if no exist law to keep something constant in the time then this thing do not have to stay constant. It could be constatn for a while but coul be change either.
Then if some stuff has propertyes those properties have to be manted via laws, then laws have to exist too.
Then there is no need for 1 and 2. since 1 is only known by its properties which are 2. Correct. Or do you blieve that particles themselves exist beside their properties (laws).
Hello all,
can not subsist.
OK, here’s a thought;
From point 2 and the quoted sentence above, I would hypothesize that JN could generate a first law followed by a second law that contradicts and replaces the first one, only to be replaced by the same first law that comes back again, contradicting the second law, forming a cycle that has a probability of being never-ending.
Depending on the mechanism involved in JN’s law creation and annihilation, this could be a starting point from which a third law could emerge and validate both laws in their eternal cycle as an initial motion from which all energetic laws could originate from, giving birth to materialisation on its way to become a universe.
Just a thought…
Regards,
VE
how I did before is complicated define stuff without laws.
But I think is possible , perhaps, to have entities without laws.
Then the physical elements could be this kind of things.
But I agree that to something generate anything it is suficient have no laws controling it.
YES ! It is possible too !
I don't know if I understod.
But if ther Law #1 and the Law #2 are contradict each other then how a third law (#3)
could do law #1 and #2 coexist together?
Hello jocaxx,
Simply in stating that law 1 and 2 always contradict themselves.
However, let me reword my thought a little better… both laws would not really contradict themselves but would rather describe two opposite and complementary results of the same law, the third one, that would state in its formulation, that this opposition (as well as the third law itself) can only subsist if there is interaction between result 1 and 2. They cannot remain static, as this would indeed be illogical.
This interaction could take the form of an energetic exchange, having the potentiality of generating all future laws of motion and their results.
VE
The “Jocaxian Nothingness” F.A.Q.
Frequently asked questions about the Jocaxian Nothingness “JN”
Jocax, Feb/2009
Translated by Debora Policastro
1 – What is the Jocaxian Nothingness (JN)?
A: The JN, differently from existent things, presents the following properties:
P1- There are no physical elements of any kind (matter, space or energy).
P2- There are no laws of any kind.
2- Does the JN exist?
A: We can only say that the JN exists in case something that has the properties of a JN (P1 and P2 above) exists. Nowadays, the JN does not exist anymore, but it could have existed in a distant past, before the Big-Bang.
3- Is the JN a being?
A: Yes. Once it has properties, it should exist in order to be a recipient of such properties.
4- Could the Jocaxian-Nothingness feature of not having any rules or laws be a rule itself?
A: No. A rule establishes some kind of restriction. For instance: “my car must be red” is a rule, but “my car is red” is not a rule, but the state of the car. Occasionally, the car could be painted blue. Establishing that the “Jocaxian Nothingness” is the state of nature in which there are no rules is not a rule that must be followed, but also a state of nature that could change (or not).
5- Would saying that anything can happen be a rule? An imposition to the Jocaxian Nothingness?
A: Yes. However, if you look at the text I emphasize that in the Jocaxian Nothingness anything can happen OR NOT. This is not a rule, but a logical tautology, an absolute truth in any circumstances or scenarios. That implies that the Jocaxian Nothingness, just like anything, follows a tautology (an absolute truth), not a rule.
6- The Jocaxian Nothingness does not have physical elements or laws. Does it have any POTENTIAL?
A: If “potential” means the possibility of transforming itself, the answer is yes. However, we must bear in mind that possibility is not certainty. The Jocaxian Nothingness could eventually never become or generate something else.
7- Would the Trivial Nothingness, where nothing can happen, be more likely than the “JN”?
A: No! The nothingness people usually think of, which I called “the trivial nothingness” (TN) is infinitely more unlikely to happen as the origin of the universe than the JN. The “trivial nothingness” would have INFINITE embedded rules that must be followed, i.e. it could not generate fields, space, it could not generate a chair; it could not generate physical laws, god, a Big-Bang, life, particles, etc.
8 – Is the “Inexistent Nothingness” purer than the JN?
A: The Inexistent Nothingness is a “nothingness” where nothing exists, not even itself!
Therefore, it is intrinsically contradictory. Since it does not exist, it could not have properties, but once it has the “not having anything” property, it should exist. Thus, if the “IN” exists, it cannot be inexistent, and if it is inexistent, it cannot exist. It is a contradiction, and that is why it was not used as the generator of the cosmos.
9 – What is the difference between the “Universe” and the “Cosmos”?
A: The Universe is the aggregation of everything that exists. Thus, each possible “Bubble Universe” or “Multi-Universe” is, in fact, part of the same Universe. That is why it is more correct to name each “Bubble Universe” as “Bubble Cosmos”. Therefore, a Cosmos would be a place in the universe governed by its own physical laws, isolated and with no interconnection with other cosmos.
10- Is the JN the Universe or has the JN originated the Universe?
A: If we understand the definition of the Universe as being the aggregation of all that exists, the JN would be the universe itself. It would be the universe in its minimal state, the simplest state possible. Therefore, the JN could not originate the universe, since it is the universe itself, where time does not exist. Later it could have materialized randomly one or more cosmos.
11- Is the JN limited to our logic? Could it be illogical?
A: There are two interrelated concepts about the Jocaxian Nothingness: The Jocaxian Nothingness Object (JN-Object) and the Theory about this JN-Object (JN-Theory). The JN-Object is defined as something that has properties relative to the JN (P1 and P2) above. The theory about the JN (JN-Theory) is based on logic and explains how the JN-Object could have materialized our cosmos at random. It is possible to say that the JN-Object does not have laws therefore it does not need to obey logic, and is it correct, indeed. However, by analyzing the JN-Object from our classic logic, we are not attaching new possibilities to the JN-Object, but the opposite: we could, in fact, be limiting the possibilities of the JN-Object which means, maybe it could be more totipotent than we can imagine.
12- Is the JN no longer a JN in case it have materialized something randomly, therefore losing the capacity of doing it?
A: The materializations of the JN are called “schizo-creations”. The Universe was in a JN form. When the first schizo-creation of the JN happens, it means that the JN cannot be the JN anymore, as now the universe has at least one element: its first schizo-creation. In case this schizo-creation is not a law that prevents the universe from materializing other things, like a law that transforms it into a trivial nothingness, then this schizo-creation, which is the evolved JN (EJN), could occasionally continue to generate schizo-creations. Only the generation of laws that restrict the generation of laws could prevent new schizo-creations.
13- Is it possible to isolate a portion of the cosmos and transform it in a JN?
A: Hardly. Since our cosmos is flooded with physical laws, in order to create a JN it would be necessary to withdraw all the physical laws from that portion. No one knows yet if it is possible or how it could be done.
14- Is it necessary to sort laws temporally in order to have a natural selection of laws? That is, would time be a prerequisite?
A: It would not be a big problem in case we needed some “time law” or “time” itself to sort laws materialized by the JN. It would be enough only to “wait” that one of the schizo-creations was a temporal law. Thereafter new laws would be sorted and undergo the “natural selection”.
15- What is the evidence that our cosmos came from a JN?
A: The evidence would be a logical universe where there are no physical contradictions between its physical elements.
Its complicated !
but what is not complicated in this kind of schizo theory ! :-)
