Why Are Multi-Barreled Muzzleloaders Inaccurate Despite Aligned Barrels?
  • Thread starter Thread starter kalkyl
    Ballistics Gun
The discussion centers on the inaccuracy of multi-barreled muzzleloaders, particularly those resembling a "machine gun" design. Key factors contributing to their poor accuracy include short barrel lengths (12" to 16"), lack of rifling, and the use of undersized balls that do not fit tightly within the barrels. Additionally, the movement of the carriage during firing exacerbates the spread of the projectiles. While these weapons may have been designed for close-range assaults, their effectiveness is limited compared to single-barreled shotguns, which are easier to manufacture and reload.
  • Understanding of muzzleloader mechanics
  • Knowledge of rifling and its impact on projectile accuracy
  • Familiarity with projectile dynamics and airflow
  • Basic concepts of firearm design and historical context
  • Research the effects of rifling on muzzleloader accuracy
  • Explore the historical use and design of multi-barreled firearms
  • Investigate the physics of projectile motion and airflow
  • Learn about modern muzzleloading techniques and equipment
Firearm enthusiasts, historians, gunsmiths, and anyone interested in the mechanics and historical context of muzzleloading firearms.
kalkyl
I was watching this video where they’re shooting an old muzzleloaded ”machine gun” with a barrel for each shot. I’m surprised that it’s so inacurrate. Why does the bullets spread, when each barrel is pointing towards the same direction? I’ve seen muzzleloaders like the ”duck foot pistol” that has multiple barrels pointed in different directions, it make sense that such guns will have a huge spread pattern - but in this case all barrels are pointing in the same direction - so I thought all shots would get beside each other?
You'll want to learn about rifling then. Or why a knuckleball is so hard to hit (or catch) in baseball.
Basically, the airflow around a fast non-spinning projectile is very chaotic and won't necessarily be the same for each of the bullets. This causes them to follow different trajectories.
The barrels are short, maybe 12" to 16", they have no rifling, and the balls were considerably smaller than the inside diameter of the barrels.
Also, it looked to me like the machine gun moved during its firing.
Its carriage is neither heavy nor secured.
So if they were to use patched roundballs with a tight fit instead, and mount the carriage rigidly so it can’t move, then the pattern will be accurate and not spread?
Here’s another muzzleloaded gun with multiple barrels.
There had to be some advantage with these guns, that justified their production and use. I thought the advantage was the accuracy and effective range compared to a shotgun pattern, that’s why the ”machine gun” pattern surprised me. If there was no advantage with multiple barrels, a one barreled shotgun is easier to make, less heavy and much faster to reload.
I thought the gun sight was a nice addition; like it really mattered, LOL.
It would be MORE accurate and slighly less spread, but hardly accurate. Did you not understand the comments about rifling?
Muzzle loaders with rifled barrels are quite a bit more accurate than muzzle loaders with smoothbore barrels, a fact that the British troops with their Brown Bess muskets learned the hard way, early in the Revolutionary War.
More like initial rate of fire.
You are thinking about that thing the wrong way. It's intended to be a (very) close range assault weapon.
Inaccuracy is a feature.
It's descendants are the 'trench gun' variations. Not something really accurate either...
Production? Do you have information that they were produced in more than a small number?
Also, no there doesn't. At least not in the way you were thinking, I believe. Sometimes maybe gun manufacturers, but much more often individual gunsmiths, reveled in making curious guns.
Exaclty, the relatively short barrels do not need to deflect much to develop a spread. The gun fires laterally in sequence so the last barrel to fire in a row will be the one that is off the most. Additionally the load may have been light since the balls hardly penetrated the board also causing the to drop more before hitting it.
these guns are oddities and were not used much - for military use, grapeshot from a cannon was more effective
It may not have much effect at such short range, but it would be very difficult to ensure equal muzzle speed, due to variations in bullet mass, size of bullet and bore of tube, amount and quality of powder.
I think I remember from way back (so don't take this too seriously), that generally such weapons are not in any case intended to aim at and hit anything. They are used to deny operational access to an area, by filling it with more or less random lethal projectiles. So spread is an important characteristic.
equally true of smoothbore muskets. The whole point was to get a mass of fire into densely packed troops
  • · Replies 23 ·
  • · Replies 18 ·
  • · Replies 56 ·
9K
10K
9K
11K
