Why solve J(X_k) ΔX_k = -F(X_k) instead of computing J⁻¹(X_k) directly
  • Level: Undergrad
  • Thread starter Thread starter Ax_xiom
5 replies · 2K views
Ax_xiom
So the formula used to solve non-linear equations using the Newton-Raphson method is this $$ X_{k+1} = X_k - J^{-1}(X_k)F(X_k) $$ and instead of finding ##J^{-1}(X_k)##, we solve for the change that will be applied to ##X_k## (##\Delta X_k##) using this relation $$J(X_k) \Delta X_k = -F(X_k)$$ and the next iteration will be this $$ X_{k+1} = X_k + \Delta X_k $$ My question is that wouldn't you need to solve for ##J^{-1}(X_k)## anyways when doing that? If so, why do we do that step in the first place?
We don't solve linear systems numerically by finding an inverse matrix; that is incredibly inefficient. Instead we use other methods, like Gaussian elimination or LU decomposition.
So what happens comptationally during the ##J(X_k) \Delta X_k = -F(X_k)## step? Do you express the problem as a series of linear equations and solve them?
Edit: I think that might be the case. I was under the impression that using Gaussian manipulation to solve a system of equations would give you the inverse matrix for free, but I don't think that is the case
If ##A## is invertible, then solving ##Ax = b## by Gaussian elimination where ##b## consists of zeros except for a 1 in the ##i##th row will give you the ##i##th column of ##A^{-1}##.
I'm assuming that this is computationally inefficient and it's much faster to just solve directly.
This is good to know but I attempted to implement this in Excel, and I was only doing it with a 3x3 matrix so it was much easier to just use Excel's MINVERSE() and MMULT() functions
That appears to be the only method Excel provides for solving ##Ax = b##. The documentation does not explain what method Excel uses to calculate a matrix inverse, but assuming it is based on the standard LAPACK library it is using LU factorisation with partial pivoting.
