Why this paradox in calculating eigen values for T*T ?
  • Level: Graduate
  • Thread starter Thread starter vish_maths
    Eigen values Paradox
9 replies · 3K views
vish_maths
Let T be an operator on the vector space V and let λ1, ... , λn be it's eigen values including multiplicity .
Lets find the eigen values for the operator T*T then ( where T* refers to the adjoint operator . <u,v> denotes inner product of u and v )
< Tv , Tv > = < λv, λv >
= λλ° < v , v >
= |λ|2 < v , v>
( where λ° is the conjugate of λ . )
=> <T*T v, v> = < |λ|2 v, v >
=> T*T has an eigen value |λ|2 for the same eigen vector v which T possesses.
This can be inferred because :
Suppose f is a linear functional on V . Then there is a unique vector v in V such that f(u) =<u,v> for all u in V.
( A linear functional on V is a linear map from V to the scalars F , As sheldon axler pg 117 says it ) The above argument must imply then that : T*T v = |λ|2 v ( Doesn't this imply v is an eigen vector of T*T ? )
now, let's consider a matrix $$M(T) = \begin{bmatrix}
1 & 3 \\
0 & 2
\end{bmatrix}$$
[ 3 1 ]T is clearly an eigen vector with eigen value = 2 .
(T* T ) =\begin{bmatrix} 1 & 0 \\ 3 & 2 \end{bmatrix} multiplied by \begin{bmatrix}
1 & 3 \\
0 & 2
\end{bmatrix}$$
= \begin{bmatrix}
1 & 3 \\
3 & 13
\end{bmatrix}$$
M(T* T ) upon multiplication with [ 3 1 ]T should produce a vector equal to
4 [ 3 1 ]T
however , \begin{bmatrix}
1 & 3 \\
3 & 13
\end{bmatrix} multiplied by [ 3 1 ]T = [ 6 22 ]T .
Can you please advise why this paradox exists ? Am i making a mistake somewhere ?
Thanks
I don't understand the bra-ket notation, but I think
is wrong.
The eigenvectors of a matrix and its (conjugate) transpose are different in general. Your proof seems to assume they are the same. If ##Tx = \lambda x##, then ##x^*T^* = \lambda^* x^*##, but that doesn't make ##x^*## a (right) eigenvector of ##T^*##. (It is a left eigenvector of ##T^*##, of course).
There's no bra-ket notation there, just inner products, absolute values, and the definition of the adjoint operator.
= λλ° < v , v >
= |λ|2 < v , v>
Why would ##\langle T^*Tv,v\rangle=\langle|\lambda|^2v,v\rangle## imply that ##T^*Tv=|\lambda|^2 v##?
I see that you tried to prove this, but the argument doesn't seem to make sense. There appears to be something missing from it as well. f(u)= what? Did you mean f(u)=v for all u? That actually implies that v=0.
Suppose f is a linear functional on V . Then there is a unique vector v in V such that f(u) = for all u in V.
Note that if we let w be any vector that's orthogonal to v, we have ##\langle T^*Tv,v\rangle =\langle T^*Tv+w,v\rangle##.
is wrong.
Thanks. <u,v> as fredrik pointed refers to the inner product of u and v . I get your argument regarding the adjoint operation.
Hi Fredrik,
Thanks for the answer. i have corrected it in the main thread , f(u) = <u,v> for all u in V.
I think the equation < Tx , y > = < z, y > => Tx = z if and only if < Tx , y > = < z, y > is valid for all y in V. ( w[itex]\in[/itex] V ) .
Lets consider the more general case of < w , y > = < z , y > , then w = z if and only if this relation is valid for all y [itex]\in[/itex] V.
Proof : Suppose there exists an another different quantity w≠z | < w , y > = < z , y >
Then : < w - z, y > = 0 for all y [itex]\in[/itex] V .
=> when y = w - z , then :
<w-z,w-z> = 0 => w = z .
<T*T v, v> = < |λ|2v, v > -------- (1)
=> I guess , T*T has an eigen value |λ|2 for the same eigen vector v which T possesses , if and only if (1) is valid for ALL v [itex]\in[/itex] V .
If it holds for all v, I think the correct conclusion is that T*T is equal to ##|\lambda|^2I## where I is the identity operator. But more importantly, as you know, you have only proved that the equality holds for a specific v.
It is clearly not true for all ##v\in V## since you took a very special ##v##, namely an eigenvector.
Fair comment, but (as an ex-mathematician turned engineer) I never use the < > notation for inner products and have to think at least twice what "adjoint operator" means :smile:
But in any case the problem here is with the math, not with the notation!
Got it. Didn't keep into consideration all v in V have to satisfy the condition . Thanks !
