Why use strcmp instead of = ? [MATLAB]
  • Topic: MATLAB
  • Thread starter Thread starter nickadams
    Matlab
3 replies · 11K views
nickadams
If a user answers "yes", "Yes", "y", or "Y" to an input question, I want to enter the while loop. But when I tried to use
user=input('blahblahblah [y/n]: ','s');
while user=='y' || user='Y' || user=='yes' || user=='Yes'
MATLAB recommends I change to strcmp. Why is this?
To test if two strings are equivalent, use strcmp, which allows vectors of dissimilar length to be compared.
http://www.mathworks.com/help/techdoc/ref/relationaloperators.html
Even if the strings had the same length, using == might result in the creation of an intermediate logical array of the same size, whereas strcmp might stop comparing as soon as the first difference was encountered.
It's also a very good habit to learn if you ever move to C++ or Java, because in those languages == and strcmp() do fundamentally different things.
In C++, == checks if the two strings share the same memory, not if the contents of the memory are equal.
So for code like
String a = "string" + " one";
String b = "string one";
String c = a;
You get the strange result that a == c is true (because a and c are both references to the same String object), but a == b is false (because a and b are different String objects).
But strcmp(a,b) and strcmp(a,c) are both true, which is probably how you wanted the comparison to behave.
So for code like
String c = a;
This is not correct. C++ has no String type. For, C++'s std::string type, http://msdn.microsoft.com/en-us/library/8ww0haah.aspx" does perform a lexicographical comparison, so a == b would be true. Also, you may not add two c-string literals in C++.
Java, which does have a String type, does not have an strcmp function at all. This functionality may be performed with the .equals method.
