Why <v,v> >= 0? Understanding Inner Product Definition
  • Level: Graduate
  • Thread starter Thread starter 9k9
8 replies · 4K views · last reply
9k9
I think I am missing a subtle point of the definition of a inner product. All the texts I have seen state <v,v> >= 0
If you have say:
v=(1,2i)
then <v,v> = -3 (Using the definition where you do the dot product, while conjugating the first term)
This is a negative number and defies the above definition of an inner product.
Is it that (1,2i) is not in an inner product space and therefore doen't have an inner product?
welcome to pf!
hi 9k9! welcome to pf! :smile:
(1,2i).(1,-2i) = 1.1 + 2i.-2i = 1 - 4i2 = 5 :wink:
Welcome to PF, 9k9! :smile:
The inner product for vectors with complex numbers is defined with a complex conjugate (as tt showed).
Without it, you have shown yourself that the resulting vector product does not satisfy the axioms for an inner product.
It seems to me that you did not conjugate the first term.
Perhaps you can write out your calculation?
Thanks for the welcomes, I see now I didn't read the definition correctly and I was only trying to conjugate the first element in the vector, rather than the first term in each of the products.
What do you mean by "the first term"? State the definition you are using.
<v,v>=0 only when v=0
the definition for inner-product is Ʃ(v[itex]_{j}[/itex])([itex]\overline{v_{j}}[/itex]) for 1≤j≤n where n is the length of vector v
note that [itex]\overline{v_{j}}[/itex] is defined as the adjoint, or conjugate transpose
when dealing in ℝ, you'll never get <v,v>=0 because it is merely taking the square of each term {(a[itex]_{1}[/itex])[itex]^{2}[/itex]+...+(a[itex]_{k}[/itex])[itex]^{2}[/itex]}
for all k[itex]\epsilon[/itex]dim(v) and then taking the square root of that sum
√(Ʃa[itex]_k{}[/itex]) which means that the inside sum must be ≥0 else the inner product wouldn't exist because we are in ℝ,
but would also never equal zero unless v=0 and then 0[itex]^{2}[/itex]=0
it's the same for ℂ since squaring terms ends up those new terms becoming positive, rather non-zero and non-negative
Welcome to PF!
Hi Krovski! Welcome to PF! :smile:
Ah, no … that fooled me at first, too …
it's "<v,v> >= 0" …
and the >= is because 9k9 doesn't have a Mac with a key that types "≥" ! :biggrin:​
it's "<v,v> >= 0" …
good catch and thank you
