Will a Sealed Steel Container Float in the Ocean?
12 replies · 2K views · last reply
mailmas
A large sealed container full of air falls into the ocean. It has internal dimensions of 6.06 2.59 2.43 m, with walls made of steel (8050 kg m3 ) which is 2.00 cm thick. Does it float?
FBuoyancy = density*volume*g
weight = mg
m = density*volume
density of salt water = 1030 kg/m^-3
Volume = (6.06)(2.59)(2.43) = 38.139
FBuoyancy = (1030)(38.139)(9.81)
= 385,367.9 N
= 385,000 N
Weight:
Wtot = Wair + Wsteel
Wair = m*g = density*volume*g = (1.29)(38.139)(9.81) = 482.65 N
Wsteel = (8050)(38.139)(.02meters)(9.81) = 60,237.1 N <- I don't understand what to do about the thickness.
Weight = 60,719. 8N which is less than FBuoyancy which means it floats.
Is this right?
You should not be using the volume of the cube here. You should be adding up the area of the sides and multiplying by the side thickness. That would be the volume of the steel of the sides.
Oh alright. The original problem said it was 20 feet high so I'm going to assume I multiply .02m by 2.59m and 2.43m. Then multiply that number by 6.
V = (.02)(2.59)(2.43) = .1258m^3
6V = .755m^3
Then,
Wsteel = (8050)(.755)(9.81) = 59,641N
I think you should handle each of the 6 sides separately using the correct dimensions for each side. The 6.06 meters is approximately 20 feet, so that is where that came from. The inner volume is not exactly the same as the outer volume because of the metal thickness, but that may not be enough to matter.
I think I understand my mistake now. But I don't know which measurement is the width or length so I just chose one to calculate:
Area of Long Part = (6.06)(2.59) = 15.69m^2
4*15.69 = 62.79
Area of Top/Bot = (2.59)(2.43) = 6.3m^2
6.3+62.79 = 69
V= 69(.02) = 1.38m^3
So weight of steel is: Wsteel = (8050)(1.38)(9.81) = 109000N
4*15.69 = 62.79
How many sides have dimension 6.06 x 2.59?
How many sides have those dimensions?
How many remaining sides are there?
4 Long Parts and 2 for Top and Bottom. I forgot to multiple by 2 for the 6.3.
2(6.3)+62.79 = 75.3
V= 75.3(.02) = 1.5m^3
Wsteel = (8050)(1.5)(9.81) = 119000N
But you do know there are two sides of each, right?
Oh okay yeah I get it.
(6.06)(2.59)(2) = 31.39
(6.06)(2.43)(2) = 29.45
(2.43)(2.59)(2) = 12.59
Atot = 73.42
V = 1.46
Wsteel = (8050)(1.46)(9.81) = 116000N
Atot = 73.42
V = 1.46
Looks ok.
haruspex said:
Looks ok.
Thanks. Do you see anything else wrong with the answer?
