Will level of liquid increase if ice melts in it?
  • Context: High School
  • Thread starter Thread starter jd12345
    Ice increase Liquid
The level of liquid remains unchanged when ice melts in water due to the principle of buoyancy, where the volume of water displaced by the ice equals its weight. Ice, being less dense than water, displaces a volume of water equal to its weight. When the ice melts, it converts to water, maintaining the same weight and thus the same displacement. In contrast, when ice melts in oil, the level of the oil decreases because the density of water is greater than that of most oils, resulting in less volume being displaced after melting.
  • Understanding of buoyancy principles
  • Basic knowledge of density and volume displacement
  • Familiarity with phase changes of substances
  • Concept of thermal expansion and contraction
  • Explore Archimedes' principle in detail
  • Study the effects of temperature on water density
  • Investigate the behavior of ice in various liquids
  • Learn about thermal expansion in different substances
Students of physics, educators explaining buoyancy concepts, and anyone interested in the properties of materials and their interactions with liquids.
jd12345
How will the level of liqid change if ice melts in it?
If its water then there is no change - i know this will happen but i don't understand it( intuitively )
Moving on to other liquids - like oil and mercury - what will happen to their levels?
Please help me understand
I actually did find the result for water by writing equations but i do not understand it intuitively - same for others. Thank you
Assuming the cross-section is constant, the level of water can be said to be directly proportional to the volume of water + volume of water displaced due to the solid object. Now, the solid object here is ice, which is lighter than water, and hence, the volume displaced by it is equal to the weight of the ice cube (since the other portion is then out of water.) Now, when the ice melts, the weight does not change, and hence, the level does not change since the density of ice is less than water. The important facts here are:
1. Ice is lighter than water hence, the displacement is equal to the weight
2. Ice melts into water and not some other liquid whose density is different and hence, the displacement of weight is equal to the displacement of volume after melting.
Thanx a lot
But could you do the same thing for another liquid like oil
Ice floating in oil? What would happen when ice melts - would help me a lot - thank you
Any object floating in a liquid displaces a volume of the liquid corresponding to the mass of the object.
If it changes state but still floats then there will be no change to the level of liquid.
Water ice floating on oil, then melting, would sink, water being heavier than (most if not all) oil. It would therefore be displacing less volume than before and the level would drop.
In fact, it's not quite straightforward with ice floating in water. The melting ice will cool the water, causing it to shrink slightly if warmer than 4C, or expand slightly if cooler.
Thank you!
13K
16K
