Will matter eventually decay as the universe expands indefinitely?
  • Level: Graduate
  • Thread starter MathematicalPhysicist
    Death Universe
72 replies · 16K views · last reply
Chalnoth said:
I'm not aware of anything specific. My reasoning simply consists of:
1. The plasma which emitted the CMB was a nearly-uniform thermal bath at around 3000K. We know it was almost perfectly thermal because of the almost perfectly-thermal spectrum of the CMB.
2. A 3000K thermal plasma doesn't have anti-matter.
This won't work in Dirac-Milne. If matter and anti-matter repel each other, when when you look at the CMB you are seeing a 3000K thermal plasma, only that you see 3000K matter plasma at some parts of the sky and 3000K anti-matter plasma at some other part of the sky. Now where the matter and antimatter meet, you'll see "weird stuff" but off the top of my head, if the zones are big enough and people aren't specifically looking for "weird stuff" they won't find it. In particular, the domain boundaries are going to be at large angles, and people have been looking at small angle fluctuations.
Now, I still think that the standard model is going to win, but we are talking about levels of uncertain. I'd be willing to bet US$20,000 that there is insignificant amounts of anti-matter in the universe, but I wouldn't be willing to bet US $1 million. I would be willing to bet say $500,000 that there are large amounts of dark matter. If you asked me to go on an airplane that will blow up if the sun doesn't work with nuclear fusion, I'd get on it, since I'm that sure. If the airplane would blow up if the universe had any substantial amount of antimatter, I wouldn't get on it.
This thing about assigning money to uncertainty isn't merely a game. AEGIS has been budgeted at about a million Swiss francs. If we were sure that antiprotons would respond to gravity the same way protons do, it would be a utter waste of money. But we aren't...
More to the point, if it comes down to deciding whether the articles should get published or whether people should get grant money, I've been very impressed by what the Dirac-Milne people have come up with. Even if they are wrong, they have come up with interesting questions.
For example, one big problem with slow growth cosmologies is that you burn up all the deuterium. Case closed... The first papers just talked about deuterium creation processes that people figured out in the 1970's wouldn't work. But then someone points out that if you have a source of anti-protons, then the conclusions of the 1970's that you can't get large amounts of deuterium goes out the window.
And let's suppose we drop an anti-proton and it falls down. One thing that is an interesting question is if you have domains of matter and antimatter, could they be larger than the observable universe. There's an anthropic "broken symmetry" here. If you have a universe that is equal matter and anti-matter then you don't get physicists. If you have a universe that is asymmetric toward either matter or anti-matter then you will (since physicists in the anti-universe will assume that they anti-matter is matter).
So if you assume that the distribution of baryon number at the start of inflation is *random* what happens?
Chalnoth said:
My understanding is that the inflaton mass had to be many orders of magnitude higher than the proton mass, so that at best this could account for a minuscule fraction of the baryons.
That assumes that the inflaton has a limited baryon number. There's no reason that I can think of that a single inflaton couldn't have a baryon number of say a million. That's the nice thing about hypothetical particles, you can make up anything.
Also you can assume that baryon number is stored an a massless field. By analogy, a neutrino with +1 lepton number can interact with a neutron with 0 lepton number to generate an electron with +1 lepton number. You could have large numbers of massless particles with non-zero baryon number interact with the inflation field to create protons. Or maybe they aren't massless. Any reason why something with non-zero baryon number has to interact with the strong force?
Yes, I'm inventing particles at random here, but it's no worse than what the supersymmetry people are doing, and if you can find some constraints on the baryon number of the inflation field, that would be useful to put a leash on that.
I'm pretty sure that would quite dramatically change the spectrum of the CMB, and in particular it would change the spectrum in a way that is dependent upon location on the sky that doesn't simply look like a tiny change in temperature.
Except now you're leaping into the realm of incredible implausibility.
The trouble with large angle changes is that there's a lot that could get lost in data reduction. For example, if you had a domain wall that was in the galactic plane, you'd never see it.
If people have looked for this and not found it, that's one thing. Have people looked?
Any particular reason why a field with a large baryon number is implausible? The trouble with inflation is that we aren't bound very much by observation. It's hard to tell what is "plausible" or not. I mean what makes a field with a baryon number of 100000 less plausible than a supersymmetric particle or axions, or all of string theory?
That's a serious question.
Also you don't need a baryon number of 100000. Suppose you have a very massive inflaton that all had +1 baryon number. During inflation, the inflaton decays into baryons. All you have to do is to have the mass proton / mass inflation be less than the baryon asymmetry and everything works out, and that gives you numbers.
The reason that inflation works the way that it does is because it creates a more "natural" theory if inflation wipes out pre-inflationary information and dilution gives a good way of doing it. However, if you trying to keep pre-inflationary information, it doesn't seem that difficult to do that.
At around 100GHz or so the anisotropies in the CMB are brighter than even the galactic plane, except very close to the galactic center. And you can use various sorts of multifrequency analysis to get a pretty good map of almost the entire sky that is nearly all CMB. So no, not even that would work.
I also would think that this sort of feature would be vastly, vastly brighter than the CMB anisotropies which are only about one part in 10,000 of the average temperature (which also means that the overall CMB temperature is far brighter than the galaxy everywhere in the sky).
Quantization generally prevents such things from occurring. Especially if the baryon number comes along with electric charge (which appears to be the case).
Well, what would prevent the inflaton field from decaying into baryons before inflation ends in this scenario? Why wouldn't the inflaton field simply immediately decay into baryons?
My understanding is that reheating normally is thought to occur through a resonance of the inflaton field oscillating around its potential minimum, as opposed to your typical particle decays. I don't believe that this sort of effect would allow any transfer of any particle numbers from the inflaton to the standard model particles.
Until someone, (perhaps me), actually runs the numbers, I'm not entirely convinced that you can't make something like that disappear. Off the top of my head, you wouldn't be looking for bright spots, you are looking for lines where the brightness is anomolously low, and it would be easy to disregard these features as local scattering.
Also CMB doesn't measure brightness. They measure wavelength distribution, and the error bars at large angles are huge.
http://www.cmu.edu/cosmology/events/cosmic-acceleration/will_kinney.pdf
There's nothing here that conflicts with quantization. You still have integer baryon numbers. They are merely very high. Also neutrons have +1 baryon number but no charge.
Just look up arxiv.org and look for Q-ball. One you have field theory, you end up with point like topological defects with huge charge and baryon number.
If you can link baryon number with charge they you can come up with firmer arguments.
Alien space bats. Normally we are constrained by observations, but since there are no such constraints as far as inflatons go, I can invoke alien space bats. Now it gets interesting if I invoke alien space bats, and I *still* can't get it to work, that's interesting.
Now if you don't like alien space bats, then if the temperature is much larger than than the mass of the inflaton then we ought to expect the backward reactions to create inflatons to be on the order of the inflaton->baryon reaction rate.
What I'm looking for is an explicit contradiction. For example, if you can show that a baryon number of one million violates Lorenz covariance, that would be a strong argument. However, if you say "to get this to work you need X" then you need to explain why X can't exist. For inflation, that's going to be a hard slog.
For CMB or nucleosynthesis, you can see that there are no alien space bats. My point is that for the inflationary era, you can't.
It's actually quite simple.
You have things like the Affeck-Dine mechanism in which some particle field gets baryon numbers due to CP violation during inflation, and then at the end transfers those baryon numbers to the SM particles
see http://arxiv.org/pdf/1108.4687.pdf
Now the wrinkle here is that instead of violating CP during inflation through alien space bats, you argue that the inflation field (or some other field that gets tagged along) has non-zero baryon symmetry before inflation gets started, and rather than generating the baryon asymmetry, the alien space bats merely preserve it.
Also, I'm talking about the situation in 2012, one of the nice thing about Planck and LHC is that I won't be able to invoke alien space bats in 2020.
Scratch that about alien space bats needed to keep the inflaton from decaying into baryons. I just ran some rough numbers and the simple answer for what keeps the inflaton from decaying into baryons immediately is "absolutely nothing." The inflationary time scale is 10^-32 seconds, and it's trivial to have a inflaton whose decay rate is on that order.
What you'd be looking for is areas where there is actually less plasma, and instead is the occasional matter/anti-matter annihilation. This wouldn't be an effect on the scale of the tiny temperature anisotropies. This would be significant compared to the overall 2.7K temperature of the CMB, which is 10,000 times brighter, and much brighter than any other source of light in the sky.
This isn't at all true. Instruments like WMAP and Planck specifically measure relative radiation intensity at different places in the sky at specific wavelengths. Most such instruments aren't very good at measuring the absolute brightness directly: this is inferred through, for example, the dipole in the CMB induced by the motion of the Earth around the Sun. But they are extremely good at measuring relative brightness in different locations. That's what they're built for.
The large error bars you see here are not measurement errors alone. They are measurement errors plus cosmic variance. The measurement errors on low multipoles with WMAP are extremely tiny (typically much smaller than the errors on high multipoles). The cosmic variance errors, however, are based upon our theoretical model of the physics that produce the CMB, a model which makes a probabilistic prediction on that just isn't very precise at low multipoles.
In essence, the theoretical prediction of how the CMB should look given a set of cosmological parameters (e.g. normal matter density, dark matter density, dark energy density, etc.) is not a specific value, but a variance. Since the prediction is only the variance, and since low multipoles have a small number of independent components (e.g. 5 components for ell=2), the measured variance can vary dramatically from the theory variance without being inconsistent with the theory.
At higher multipoles, where you have a lot of independent components, the measured variance and the theoretical variance have to match much more closely for the theory to agree with experiment.
Those aren't particles, though. Those are large collections of particles localized at a specific point.
Anyway, we'll see. But these models seem to me to be highly contrived and thus highly unlikely.
This is not terribly convincing without even rough numbers. If you presume that matter and anti-matter repel each other, then you have several hundred thousand years for the matter and anti-matter to separate, and you can make the matter/anti-matter annihilation end up as low as you want. That gets rid of the non-thermal spectrum.
I did a quick calculation of gamma ray flux and to make the numbers work, you have to assume a suppression factor of 10^-2 or 10^-3. That's not a crazy number if matter and anti-matter repel.
At that point you'd have much less plasma at the domain walls, but the temperature would have time to thermalize at which point that you'd have a thermal spectrum and no temperature anisotropy.
Right. But if you have domain walls, then the relative brightness over a large chunk of sky is likely to be the same.
Which means that if there is something funny happening at low multipoles, you aren't going to see it.
Also, because of gamma ray flux, I doubt that we are missing anti-matter. However, getting to what the observations show or don't show is interesting because we could be missing something else. Cosmic strings or GUT monopoles would produce similar domain wall effects. For that matter, if you have a model of CMB at low monopoles, you might be able to use it to map nearby voids.
Right, but at high multipoles everything goes thermal so Dirac-Milne gives you the same basic spectrum.
But the topological defect mechanism as far as I can tell could work for the inflaton. Why do we think the inflaton is a massive particle? It's because we need inflation to happen at a specific time and having a massive particle makes the phase transition happen at the right time. Well, what if you have collections of small particles?
Saying that something is unlikely presumes a meta-theory. One problem with meta-theories is that whether something is contrived or not is a matter of taste. One reason Dirac-Milne is interesting is that it seems less contrived than the standard model, but this is a matter of taste, and the problem with aesthetic arguments is that if someone says it "looks contrived" and you disagree, there's no way of easily resolving the argument.
The trouble with "aesthetic arguments" is that all of our standard models are highly contrived. They end up highly contrived because reality is complicated and you have to do messy things to make the models fit reality. For things that we have lots of observations for, it's relatively easy to figure out what those messy things are. For stuff that we don't, it's not.
So we need more data, but then we have to ask what data do we need. It's not a matter of "wait and see" and "wait and see what?"
This doesn't help, because it would still be much dimmer at the domain walls, which I would be willing to bet would be glaringly obvious in the CMB spectrum. Specifically, it would be glaringly obvious in the spectrum of the anisotropies (because instead of differences in temperature causing the anisotropies, differences in density would cause some of them, which would lead to different spectral effects).
Right, but domain walls would affect multipoles on many scales, because they are linear features.
Why? The optical thickness of the CMB washes out features at high multipoles overall, but the effect of the domain walls should be visible at all scales relative to the CMB anisotropies (which are also washed out at high multipoles due to this effect).
The inflaton is typically modeled as a field, with the quanta of that field being inflatons. I'm not sure a field of solitons makes sense.
I would be willing to bet that Dirac-Milne simply cannot work on purely empirical grounds, just given our current observations of the CMB, regardless of any arguments regarding simplicity.
As for simplicity, however, there are reasonably good measures of simplicity, such as the number of parameters required to describe the model. If a model requires more parameters to describe it, it sure as heck had better explain a lot more experimental evidence than the competing model, or else it's most likely wrong. Even though it's not possible to prove that this is a good way of doing things, and even though there are sometimes arguments about just how simple or complex various theories are, it seems to be a pretty good heuristic that has worked rather well in the past. And there are some rather rough probabilistic justifications for it that at least seem reasonable.
Yes, it is a matter of wait and see, because it takes an overwhelmingly-compelling theory to push people to base new experiments about it.
A lot depends on the geometry of the domain walls, and on the processing that people do to get the multipoles. If the thickness of the domain walls are large compares to the features that people care about, then the only thing in the higher order multipoles are going to be harmonics and it's not hard for those to get lost.
One thing is that if some says "yes I've actually put in domain walls" here is what they look like, that would convince me, but I think that the Dirac-Milne have put enough of a case that I don't think that it's valid to dismiss their challenges without some numbers.
What if the inflaton is a soliton? The reason you need a high mass particle is so that you get the phase transition at the right time. You can have the inflationary particle be relatively low mass but the phase transition happen because of a soliton.
Also, this is a different argument than Dirac-Milne.
It's not that one is willing to bet but how much. I'd be willing to bet US $25K-$50K that Dirac-Milne is wrong. I wouldn't bet my life on it. As far as primordial baryongenesis. I'd be willing to bet several hundred dollars that primordial baryon number is irrelevant, but I wouldn't bet any more than that.
Or one weird observation. All that has to have happen to have people take Dirac-Milne seriously is to drop some anti-protons and watch them go up.
It's up to them to put forward their case, not the rest of us to disprove it. And yes, I really think that the domain walls would produce brightness anisotropies that are much, much larger than the temperature anisotropies we see.
Well, right, and there are groups that are trying. The problem is that it's really, really hard given that gravity is some 40 orders of magnitude weaker than electromagnetism, so that the electric charges of the anti-protons tend to react far more strongly than do their masses.
