Without evaluating the Legendre symbols, prove the following....
  • Thread starter Thread starter Math100
    Legendre Symbols
The discussion centers on proving that the sum of products of integers and their Legendre symbols modulo 73 equals zero, specifically that r=172 r(r|73) = 0. Given that 73 is an odd prime and 73 ≡ 1 (mod 4), the established theorem states that k=1p-1(k|p) = 0 for any prime p, confirming the assertion. The participants suggest leveraging the quadratic residue theorem and the properties of Legendre symbols to validate the proof without direct evaluation.
  • Understanding of Legendre symbols, specifically (k|p).
  • Familiarity with quadratic residues and non-residues modulo a prime.
  • Knowledge of modular arithmetic and properties of prime numbers.
  • Basic grasp of Euler's Criterion and its implications for quadratic residues.
  • Study the properties of Legendre symbols in detail, focusing on their behavior under modular arithmetic.
  • Learn about the quadratic residue theorem and its applications in number theory.
  • Explore Euler's Criterion and its proof to understand its role in determining quadratic residues.
  • Investigate the implications of the theorem k=1p-1(k|p) = 0 for various primes.
Mathematicians, number theorists, and students studying modular arithmetic and quadratic residues, particularly those interested in proofs involving Legendre symbols and prime numbers.
Math100
Without evaluating the Legendre symbols, prove that ## 1(1|73)+2(2|73)+3(3|73)+\dotsb +72(72|73)=0 ##. (Hint: As ## r ## runs through the numbers ## 1, 2, ..., 72 ##, so does ## 73-r ##.)
Let ## p ## be an odd prime. Then ## \sum_{r=1}^{p-1}r(r|p)=0 ## if ## p\equiv 1\pmod {4} ##.
Since ## p=73 ## in this problem, how should I prove that ## \sum_{r=1}^{73-1}r(r|73)=0 ##? Given that ## 73=1\pmod {4} ##.
Math100 said:
Homework Statement:: Without evaluating the Legendre symbols, prove that ## 1(1|73)+2(2|73)+3(3|73)+\dotsb +72(72|73)=0 ##. (Hint: As ## r ## runs through the numbers ## 1, 2, ..., 72 ##, so does ## 73-r ##.)
Are you sure? We know that ##\displaystyle{\sum_{k=1}^{p-1}\left(\dfrac{k}{p}\right)=0}## for any prime. That would be ## (1|73)+(2|73)+(3|73)+\dotsb +(72|73)=0 ## in your notation.
Math100 said:
Relevant Equations:: Let ## p ## be an odd prime. Then ## \sum_{r=1}^{p-1}r(r|p)=0 ## if ## p\equiv 1\pmod {4} ##.
If this is really true, then there is nothing to show. ##p=73## is odd and ##73\equiv 1\pmod{4}## so the formula applies to ##73.##
It is already proven in case the formula is true. Maybe you should prove the formula:
p\equiv 1\pmod{4} \Longrightarrow \sum_{k=1}^{p-1}\left(\dfrac{k}{p}\right)=0
In that case, you should tell us what you already know and what we could use to prove it, e.g. the quadratic residue theorem.
fresh_42 said:
Are you sure? We know that ##\displaystyle{\sum_{k=1}^{p-1}\left(\dfrac{k}{p}\right)=0}## for any prime. That would be ## (1|73)+(2|73)+(3|73)+\dotsb +(72|73)=0 ## in your notation.If this is really true, then there is nothing to show. ##p=73## is odd and ##73\equiv 1\pmod{4}## so the formula applies to ##73.##
Maybe by substituting ## (r|p)=(-1)^{(p-1)/2}(p-r|p) ## into ## \sum_{r=1}^{p-1}r(r|p)=0 ##? But then we have ## \sum_{r=1}^{p-1}r(r|p)=\sum_{r=1}^{p-1}r(-1)^{(p-1)/2}(p-r|p) ##. How should I proceed from here and simplify to ## \sum_{r=1}^{p-1}r(r|p)=0 ##?
Smallest test:
\begin{align*}
\left(\dfrac{1}{5}\right)+2\left(\dfrac{2}{5}\right)+3\left(\dfrac{3}{5}\right)+4\left(\dfrac{4}{5}\right)&=
1+2\cdot (-1)+3\cdot (-1)+4\cdot 1=0
\end{align*}
Ok, no counterexample. Let's see what the hint says:
\begin{align*}
\sum_{k=1}^{p-1}k\cdot \left(\dfrac{k}{p}\right)&=\left[1\cdot\left(\dfrac{1}{p}\right)+(p-1)\cdot\left(\dfrac{p-1}{p}\right)\right]+\left[2\cdot\left(\dfrac{2}{p}\right)+(p-2)\cdot\left(\dfrac{p-2}{p}\right)\right]\\
+&\ldots +\left[((p-1)/2)\cdot\left(\dfrac{((p-1)/2)}{p}\right)+((p+1)/2)\cdot\left(\dfrac{((p+1)/2)}{p}\right)\right]
\end{align*}
Can you simplify these terms?
Hint: ##\left(\dfrac{k}{p}\right)=\left(\dfrac{p-k}{p}\right)## if ##p\equiv 1\pmod{4}.## Is the number of brackets ##[\cdot]## even or odd?
fresh_42 said:
Smallest test:
\begin{align*}
\end{align*}
\begin{align*}
\end{align*}
So ## \sum_{k=1}^{p-1}k\cdot (\frac{k}{p})=[1+72\cdot (\frac{72}{73})]+[2+71\cdot (\frac{71}{73})]+\dotsb +[36\cdot (\frac{36}{73})+37\cdot (\frac{37}{73})]=73+73+\dotsb +73 ##?
No.
We get from ##\left(\dfrac{k}{p}\right)=\left(\dfrac{p-k}{p}\right)## for ##p\equiv 1\pmod{4}## that
\begin{align*}
\sum_{k=1}^{p-1}k\cdot \left(\dfrac{k}{p}\right)&=\sum_{k=1}^{(p-1)/2}\left[k\cdot\left(\dfrac{k}{p}\right)+(p-k)\cdot\left(\dfrac{p-k}{p}\right)\right]\\
&=\sum_{k=1}^{(p-1)/2}\left[(k+p-k)\cdot \left(\dfrac{k}{p}\right)\right]=p\cdot\sum_{k=1}^{(p-1)/2}\left(\dfrac{k}{p}\right)
\end{align*}
We get from ##p\equiv 1\pmod{4}## that there are an even number of summands, namely ##\dfrac{p-1}{2} ## many. This means we have to show that there are equally many Legendre symbols with ##+1## as there are with ##-1.##
I assume from the example with ##p=5## that ##\left(\dfrac{k}{p}\right)=-\left(\dfrac{k+1}{p}\right)## if ##k< \dfrac{p-1}{2}.## That would be the easiest way to sort all ##\dfrac{p-1}{2}## summands by pairs of ##+1## and ##-1.## Can you prove this? Or find an argument for why it is true? Or is there another grouping such that
\sum_{k=1}^{(p-1)/2}\left(\dfrac{k}{p}\right)=0\quad ?
fresh_42 said:
No.
\begin{align*}
\end{align*}
That seems to be right. Because ## 73 ## has 36 quadratic residues and 36 non-quadratic residues. So they should cancel each other out leaving the answer to ## 0 ##. Also, earlier you mentioned that there's another theorem which claims ## \sum_{r=1}^{p-1}(r|p)=0 ## for any prime, where both the number of quadratic residue and non residue modulo ## p ## are exactly ## \frac{p-1}{2} ##. And if ## (\frac{k}{p})=(\frac{p-k}{p}) ## for ## p\equiv 1\pmod {4} ##, then
\begin{align*}
&\sum_{k=1}^{p-1}k(k|p)=\sum_{k=1}^{p-1}(p-k)(p-k|p)\\
&=\sum_{k=1}^{p-1}(p-k)(k|p)\\
&=p\sum_{k=1}^{p-1}(k|p)-\sum_{k=1}^{p-1}k(k|p)\\
&=-\sum_{k=1}^{p-1}k(k|p).\\
\end{align*}
Thus ## \sum_{k=1}^{p-1}k(k|p)=0 ##.
Why is this the case?
\begin{align*}
\end{align*}
Very nice!
Very nice!
From ## \frac{p-1}{2} ##, to find the number of quadratic residues and non-quadratic residues.
Yes, but we need equally many among the first half, from ##1## to ##\dfrac{p-1}{2}.## That would be ##18## quadratic residues and ##18## quadratic non-residues among
\left\{\left(\dfrac{1}{73}\right),\left(\dfrac{2}{73}\right),\ldots,\left(\dfrac{36}{73}\right)\right\}
I was thoughtless.
Your conclusion in post #7 is fine! (My previous post #10 is only valid if we want to show it directly. So maybe it was me who was thoughtless, not you. I blame it on the time gap.)
Your argument eliminates the coefficients (factors) in front of the Legendre symbols. Unfortunately, the consecutive Legendre symbols ##\left(\dfrac{a}{p}\right),\left(\dfrac{a+1}{p}\right)## do not alternate in general. The case ##p=5## was too small to recognize that. This table shows the distribution: https://en.wikipedia.org/wiki/Legendre_symbol#Table_of_values
So we are left to show that
\sum_{k=1}^{p-1}\left(\dfrac{k}{p}\right)=0.
This is equivalent to what you said: there are equally many quadratic residues as quadratic non-residues among ##\{1,2,\ldots,p-1\}.## Now, why is this the case?
Let ## a ## be a primitive root of ## p ##.
Then the integers ## a^{1}, a^{2}, ..., a^{p-1} ## form a reduced residue system modulo ## p ##
such that ## \varphi(p)=p-1 ##, where ## r\in\left \{ 1, 2, ..., p-1 \right \} ##.
This implies ## r\equiv a^{k}\pmod {p} ## for ## 1\leq k\leq p-1 ##.
By Euler's Criterion, we have that
## (\frac{r}{p})=(\frac{a^{k}}{p})\equiv (a^{k})^{\frac{p-1}{2}}\equiv (a^{\frac{p-1}{2}})^{k}\equiv (-1)^{k}\pmod {p} ##.
Since ## gcd(a, p)=1 ##, it follows that ## a^{\frac{p-1}{2}}\equiv -1\pmod {p} ##.
Note that both ## (\frac{r}{p}) ## and ## (-1)^{k} ## are equal to either ## 1 ## or ## -1 ##.
Thus ## \sum_{r=1}^{p-1}\frac{r}{p}=\sum_{k=1}^{p-1}(-1)^{k}=0 ##.
Sorry, but this sounds rather confusing. E.g. you end a sentence with a specification of ##r## that was never mentioned before. Let me explain the ideas behind the statement.
We are looking for remainders modulo a prime ##p##. These form the additive group ##\mathbb{Z}_p=\{0,1,2,\ldots,p-1\}.## If ##a,b\in \mathbb{Z}_p## then ##a+b \pmod{p} ## is again in ##\mathbb{Z}_p##. We have a zero, addition in associative and we have inverse elements: ##a+(p-a) \equiv 0 \pmod{p}.## It is even a commutative group since ##a+b\equiv b+a\pmod{p}.## These conditions altogether make ##\mathbb{Z}_p## and abelian, additive group.
We have even a field ##\mathbb{Z}_p## because we can distributively muliply in ##\mathbb{Z}_p## and all elements
G:=\mathbb{Z}_p^* = \{a\in \mathbb{Z}_p\,|\,\exists \,b\in \mathbb{Z}_p\, : \,a\cdot b=1\}=\{a\in \mathbb{Z}_p\,|\,\operatorname{gcd}(a,p)=1\}=\{1,2,\ldots,p-1\}=\mathbb{Z}_p -\{0\}
except for the zero form a multiplicative group with ##\varphi (p)=p-1## elements. Since all elements in ##\mathbb{Z}_p## are of order ##p## and all elements of ##\mathbb{Z}_p^*## are coprime to ##p##, they all generate ##G.## This means ##G=\{a^k\,|\,0< k< p\}## for every ##a\in G.##
A character from ##G## is a group homomorphism ##\alpha \, : \,G\longrightarrow \mathbb{C}-\{0\}## such that ##\alpha (a)\cdot\alpha (b)=\alpha (a\cdot b)## where ##a,b\in G## and multiplication in ##G## is modulo ##p.## The characters of ##G## form again a multiplicative group by setting ##(\alpha \cdot \beta )(a):=\alpha (a)\cdot \beta (a).## Say this group of characters is ##M.## Let us fix an (primitive) element ##a\in G.## Then every character is defined by its value on ##a.## Say ##\alpha(a)=z.## Then ##\alpha (a^k)=\alpha(a)^k=z^k## and all elements of ##G## are of the form ##a^k.## The neutral element is the principal (trivial) character ##\chi_0## which maps all elements on ##1##. Then ##\alpha^{-1}(a^k):=z^{-1}## defines the inverse character: ##(\alpha \cdot \alpha^{-1})(a)=\alpha (a^k)\cdot \alpha^{-1}(a^k)=z^k\cdot (z^{-1})^k=1^k=1=\chi_0(a^k).## Furthermore, ##\alpha^{p-1}(a)=\alpha(a^{p-1})=\alpha(1)=1=\chi_0(a),## so every character is of finite order and ##z## has to be a ##p-1##-th root of unity. This means we can identify the group of characters of ##G## with ##G=\{1,2,\ldots,p-1\}## itself
The Legendre symbol for ##p\equiv 1\pmod{4}## is quadratic since ##\left(\dfrac{a}{p}\right)\cdot\left(\dfrac{a}{p}\right)=\left(\dfrac{a^2}{p}\right)=1.## We define the subgroup ##G^2=\{a^2\,|\,a\in G\}< G## of all squares modulo ##p## in ##G.##
Let ##a\in G## be a primitive element again. Then ##a## is of even order ##p-1## and ##2n\not\equiv 1\pmod{p-1}.## (Proof: If ##2n\equiv 1\pmod{p-1}## then ##2\,|\,(p-1)\,|\,(2n-1)## which is impossible.) Thus ##(a^n)^2=a^{2n}\neq a## for all ##n\in \mathbb{N}.## This means that ##a## is no square and ##aG^2\neq G^2.## But ##aG^2## is of order ##2## in ##G/G^2=\{G^2,aG^2\}.## It exists therefore exactly one non-trivial homomorphism ##G/G^2\longrightarrow \mathbb{C}-\{0\}## given by ##G^2\longmapsto \chi_0## and ##aG^2\longmapsto \left(\dfrac{\cdot}{p}\right)## the Legendre symbol. Since ##G^2## and ##aG^2## and ##G=G^2\cup aG^2,## we have equally many elements in ##G^2## and ##aG^2##, i.e. we have equally many squares in ##G## as non-squares. Finally,
\sum_{k=1}^{p-1}\left(\dfrac{k}{p}\right)=\sum_{k\in aG^2}\left(\dfrac{k}{p}\right)+\sum_{k\in G^2}\left(\dfrac{k}{p}\right)=\left|aG^2\right|\cdot (-1)+\left|G^2\right|\cdot (+1)=\left|G^2\right|\cdot (-1+1)=0
and
Math100 said:
\begin{align*}
\end{align*}
and
What a long proof. But what does ## aG^{2} \mapsto ({\frac{\cdot }{p}}) ## mean/indicate? I've never seen this before.
  • · Replies 19 ·
