X is an element of Y, such that 2/X is in Y. Is this allowed
  • Context: Graduate
  • Thread starter Thread starter Uvohtufo
    Element
The discussion revolves around the validity of defining a set in terms of itself within set theory, specifically examining the expression M = { x | (2 / x) ∈ M }. Participants explore whether such definitions are permissible and the implications of using self-referential definitions in mathematical contexts.
  • One participant questions the validity of the definition M = { x | (2 / x) ∈ M }, noting that it relies on an infinite regress of criteria.
  • Another participant suggests that the definition does not make sense without ensuring that the expression 2/x is valid, proposing a modification to specify the set of integers.
  • A different participant argues that while the equality can be meaningful if M is already defined, it does not guarantee the existence or uniqueness of such a set.
  • One participant shares a practical example related to sound harmonics, expressing uncertainty about how to formalize their set without self-reference.
  • Another participant clarifies that defining a set by itself is problematic due to the potential for confusion and the need for a clear definition.
  • There is a mention of impredicative definitions, suggesting a deeper philosophical consideration of the topic.
Participants generally agree that defining a set in terms of itself leads to complications and is not straightforward. However, there is no consensus on the broader implications or the specific conditions under which such definitions might be acceptable.
Participants highlight limitations in the definitions discussed, including the need for clarity in the expression 2/x and the requirement for a well-defined set M before making self-referential definitions.
Uvohtufo
Hey guys,
I was working on something today and I was trying to formalize what I was doing, and I tried to write out:
M = { x | ( 2 / x ) [itex]\in[/itex] M }
Then I thought about it and wondered whether this is allowed in set theory. Its not clear that there is anything in M at all, and thus its not clear whether any X would be in M. The criterion rests on an infinite number of other criterion. Is this allowed in any system of set theory? And if it isnt, why not?
If it is allowed, how about:
The Natural Numbers = {x | x-1 [itex]\in[/itex] M [itex]\vee[/itex] x = 0 }
This doesn't really make sense, since you haven't said anything that ensures that the expression 2/x makes sense. You could attempt to remedy that by writing e.g.
$$M=\{x\in\mathbb Z\,|\,2/x\in M\}$$ instead. But this still doesn't make sense, since you're using the definition of M in the definition of M.
The set of all x such that x-1 is in M and x=0... This would be {0} if -1 is in M, and ∅ otherwise.
As Fredrik said, it doesn't make sense. Perhaps you wanted to say something like x=2/x, but I am just guessing...
It makes sense if you don't use it as a definition. So if ##M## is already defined, then ##\{x\in \mathbb{Z}~\vert~2/x \in M\}## is well-defined and thus the equality
[tex]M=\{x\in \mathbb{Z}~\vert~2/x \in M\}[/tex]
makes sense and can be true or false.
But there is no guarantee that there is a set ##M## that satisfies the equality or that this set is unique, so you can't use the equality to define ##M##.
So I was working on a project related to sound harmonics. I had 12 harmonics/tones expressed as whole number fractions, all between 1 and 2, and I also wanted to have the reciprocals (multiplied into the range of 1 and 2), in the set of tones I was working with. So I had 15/8, and I wanted 16/15 expressed in my set of tones too (2 / (15/8))
I mean, there was nothing stopping me from just adding the reciprocals to what I was doing, but I tried formalizing it for fun. I probably have no way of defining this, other than just defining the set by listing its elements right?
Oh I see. So if I said something like:
P = { x | ( 2 / x ) ∈ M }
then it would be okay?
Also, some what off-topic, I am also curious why its not allowed to define something by itself. I could see how its confusing, but I am not sure why that alone should be reason not to so.
Well that was an or, not an and. x = 0, or x - 1 is in M. So {0, 1, 2, 3, 4, 5...}.
What do you mean? Like, I can't do ##M## = {x | x = 4} ?
No, but if you first define M, you an then define P by writing e.g. ##P=\{x\in\mathbb R\,|\,2/x\in M\}##. The main reason why you have to specify the set that x is an element of is that 2/x doesn't make sense for arbitrary sets x.
A definition of M must tell us what set M is. If you can prove that there's exactly one set such that ##M=\{x\,|\,\text{some statement about M}\}##, then you can take this equality as the definition of M.
Ah, I read it wrong then. But the expression ##\{x\,|\,x-1\in M\lor x=0\}## still has several problems. First of all, what is M? Second, there's nothing that ensures that x-1 makes sense. You could however write ##\mathbb N=\{x\in\mathbb Z\,|\, x-1\in\mathbb N\lor x=0\}##. But to take this as a definition of ##\mathbb N##, you must prove that there's exactly one set ##\mathbb N## that satisfies this equality.
This equality is fine. It defines M to be the set {4}.
Thank you Fredrik, and Bacle2.
Definitions, and descriptions, I find to be extremely interesting. But that has little to do with math or physics so I'll avoid that conversation.
  • · Replies 18 ·
  • · Replies 64 ·
  • · Replies 17 ·
