Z^3-1=0 (express using de moivres theorum)
  • Thread starter Thread starter Daaniyaal
10 replies · 12K views
Daaniyaal
Use De Moivre's theorem to obtain solutions to the equation (Z^3)-1=0
z^n= rθ^n(cosnθ+isinnθ)
I am having difficulty on figuring out how to meld the equation to De Moivres Theorem
Write z=r(cos(θ)+isin(θ)). So you have z^3=1. What are the possibilities for r and θ? Start with r. By convention we pick r>=0. What must r be?
r would be 1 and θ=0 right?
Good start! That's one solution. Can you find two more? Try to think of other values of θ that might work. cos(3θ) has to be 1 and sin(3θ) has to be 0.
Dick said:
Good start! That's one solution. Can you find two more, try to think of other values of θ that might work.
ok so
z^3= 1^3(cos(3θ)+isin(3θ))
Daaniyaal said:
Arghh I can't think of anything, do they have anything to do with our "special triangles"? the 45-45-90 one and the 30-60-90 one? I've thought of multiple sin and cos values and none of them are giving me the right answer :( apart from the previous one I have listed.
Not so special. cos(2π)=1 and sin(2π)=0. Suggest a value for θ using that.
dick said:
not so special. Cos(2π)=1 and sin(2π)=0. Suggest a value for θ using that.
2pi!
Sorry I keep taking too many hints, I get it after I post that I don't understand
The number "1" has "polar form" r= 1 and [itex]\theta= 0[/itex] because the number 1= 1+ 0i is represented by the point (1, 0) which is at distance 1 from (0, 0) and angle 0 with the positive x-axis. Alternatively, x= 1+ 0i= 1(cos(0)+ i sin(0)).
Now, cosine and sign are periodic with period [itex]2\pi[/itex]. So the x-axis, in addition to being "[itex]\theta= 0[/itex]" is also "[itex]\theta= 2\pi[/itex]" and "[itex]\theta= 4\pi[/itex]".
(As well as "[itex]6\pi[/itex]" or "[itex]9\pi[/itex]" or even "[itex]-2\pi[/itex]", etc. but those are not important. Do you see why?)
Because it is really the same position right? 2pi=4pi in terms of position on the circle?
Daaniyaal said:
2pi!
True. But we are mainly interested in values of θ between 0 and 2π. The others are really just 'copies'. If you put θ=2π you get the same z value as θ=0. I was hoping you'd say 2π/3. Do you see why that works and is more interesting?
