Expert Tips for Zip Line Anchoring | How to Secure Your Backyard Zip Line
  • Thread starter Thread starter Eeman0201
    Line
When constructing a backyard zip line, proper anchoring is crucial for safety. A suggested method involves using a sturdy ground anchor, such as a buried plywood block, but it's essential to consider soil type and depth for effectiveness. An 'A' frame design for the wire support is recommended to prevent sideways falls and ensure stability. It's advised to avoid wood in soil to prevent rot and sudden failure, and to consult a qualified engineer for a safe design. Additionally, informing your homeowner's insurance about the zip line can provide further safety recommendations.
Eeman0201
So I'm making an ~200ft long zip line with the top being anchored to a tall tree in my backyard. My problem is I need an anchor for the bottom. Can I use a 6"x6"x12' plywood buried 4 feet in the ground with a guy wire anchored to a 4"x4"x4' 2.5 feet into the ground? What would you say I should use to anchor th zip line about 4-7 feet off of the ground? Note: I can't find any used telephone poles near me so you have to come up with something else besides a telephone poll.
Isn't a telephone poll when someone calls you up and asks you what you think about how well the mayor is doing?
Considering that this is safety-related, I would hire an actual engineer and not go looking for what a bunch of folks on the internet say.
Likes XZ923, anorlunda and jim mcnamara
Eeman0201.
Welcome to PF. Thanks for the question. Sorry about the reception you received.
I had never heard of it being called a zip line before so I had to look it up.
Anyhow, the folks here at PF are highly averse to doing anything that might come back at them if someone got hurt. There are other sites, frequented by members who have less competency that will happily help you solve the problem of providing a good solid anchor.
The wire support should be an 'A' frame so it does not fall sideways, but more importantly, if someone goes to far they do not hit the post.
A good design would be to keep wood away from the soil. Over time, wood will rot in soil. You will not be able to inspect a buried anchor so when it fails, it will fail suddenly without warning.
The ground anchor will come down to a number of things. What is the soil type? How deep is the soil, does it have many rocks?
The strength of the anchor must be enough to handle the maximum tension in the wire. Sag will be very important because it reduces the wire tension, but the tension in the wire will always be more than the rider. The straighter the wire the more tension will be produced by the weight of a rider as is demonstrated by the “Triangle of forces”. https://en.wikipedia.org/wiki/Lami's_theorem
Agreed. Please try to find a competent local person who can help you with this. And be sure to let your homeowner's insurance company know about the new toy and who-all will be using it. They may have some suggestions about how to make it as safe as possible. Keep in mind that entertainment companies who operate Zip Lines carry liability insurance.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
10K
22K
  • · Replies 16 ·
