Surface Integral of Vector Field
The discussion focuses on calculating the surface integral of the vector field F(x, y, z) = xi + x²j - yzk over the surface S defined by z=0 and the bounds 0 ≤ x ≤ 1, 0 ≤ y ≤ 1. The parametrization of the surface is established as x = u, y = v, z = 0. The key equations used include the transformation equations for the surface and the integral formula, specifically \int\int_{\Phi} F dS = \int\int_{D} F * (T_u \times T_v) du dv. The orientation of the normal vector is discussed, although it is noted that it does not affect the outcome of this particular integral.
  • Understanding of surface integrals in vector calculus
  • Familiarity with parametrization of surfaces
  • Knowledge of vector fields and their operations
  • Proficiency in using the cross product in three-dimensional space
  • Study the concept of surface integrals in vector calculus
  • Learn about parametrization techniques for various surfaces
  • Explore the properties of vector fields and their integrals
  • Review the application of the cross product in calculating normal vectors
Students and professionals in mathematics, particularly those studying vector calculus, as well as engineers and physicists working with surface integrals and vector fields.
ma3088
Find [tex]\int\int_{S}[/tex] F dS where S is determined by z=0, 0[tex]\leq[/tex]x[tex]\leq[/tex]1, 0[tex]\leq[/tex]y[tex]\leq[/tex]1 and F (x,y,z) = xi+x2j-yzk.
Tu=[tex]\frac{\partial(x)}{\partial(u)}[/tex](u,v)i+[tex]\frac{\partial(y)}{\partial(u)}[/tex](u,v)j+[tex]\frac{\partial(z)}{\partial(u)}[/tex](u,v)k
Tv=[tex]\frac{\partial(x)}{\partial(v)}[/tex](u,v)i+[tex]\frac{\partial(y)}{\partial(v)}[/tex](u,v)j+[tex]\frac{\partial(z)}{\partial(v)}[/tex](u,v)k
[tex]\int\int_{\Phi}[/tex] F dS = [tex]\int\int_{D}[/tex] F * (TuxTv) du dv
To start off, I'm not sure how to parametrize the surface S. Any help is appreciated.
Since you are just talking about a portion of the xy-plane, x= u, y= v, z= 0. Oh, and the order of multiplication in [itex]T_u\times T_v[/itex] is important. What is the orientation of the surface? (Which way is the normal vector pointing?)
(Actually that last point doesn't matter because this integral is so trivial.)
