A dark part of special relativity(at least for me)
  • Context: Graduate
  • Thread starter Thread starter ShayanJ
The discussion revolves around the implications of special relativity, particularly the concept that the speed of light is the maximum speed achievable by any object. Participants explore the mathematical reasoning behind this assertion, the behavior of massless particles like photons, and the energy requirements for accelerating objects with mass to the speed of light.
  • One participant suggests that if an object reaches the speed of light, it cannot change its speed, implying that light speed is not only a maximum but a constant state for such objects.
  • Another participant asserts that it is impossible for objects with non-zero rest mass to reach the speed of light, stating that the concept of "what happens at c" is irrelevant for these objects.
  • There is discussion about the mathematical reasoning behind the assertion that infinite energy would be required to accelerate an object with mass to the speed of light.
  • Participants discuss the momentum and energy equations for massless particles, noting that for photons, the energy is related to frequency and momentum is defined differently than for massive particles.
  • Some participants express confusion about the implications of mass and acceleration in the context of relativity, particularly regarding the infinite energy requirement and the behavior of massless particles.
  • There is a correction regarding the application of the force equation in relativistic contexts, emphasizing that the classical form F = ma is not valid at relativistic speeds.
Participants generally agree that objects with non-zero rest mass cannot reach the speed of light, but there is disagreement and confusion about the implications of this, particularly regarding energy requirements and the behavior of massless particles. The discussion remains unresolved on several technical points.
Limitations include assumptions about the definitions of mass and energy in relativistic contexts, the divergence of certain equations as velocity approaches the speed of light, and the applicability of classical mechanics in relativistic scenarios.
ShayanJ
Insights Author
Hi
For some days I was looking for the reason that relativity said the speed of light is the maximum speed.At last after a lot of thinking I have noticed the equations below:
limv[tex]\rightarrow[/tex]c[tex]\frac{M_{0}}{\sqrt{1-\frac{v<sup>2</sup>}{c<sup>2</sup>}}}[/tex]=[tex]\infty[/tex]
lim m[tex]\rightarrow[/tex][tex]\infty[/tex] [tex]\frac{F}{m}[/tex]=0
So if sth moved with the speed of light,It couldn't change its speed.It means that not only the speed of light is the maximum speed but also When sth reaches this speed if will move with the speed of light for ever.because acceleration that means the change in velocity is 0 so that thing can't increase nor decrease its speed.
Is my reasoning right and if yes,have you noticed about it?
And don't you have sth easier and faster than this latex?
It took me ten minutes to write this post!
Shyan said:
Hi
Yes, well done. It a feature of relativity that anything which moves less than light speed will always move less than light speed; and anything which moves at light speed can never move at any other speed. Another point is... particles will non-zero rest mass move less than light speed. Particles with zero rest mass move at light speed.
LaTeX is designed to allow writing production quality typesetting of mathematics. It takes a bit of getting used to, but once you know it, it's the best there is for this task. You should put the whole formulae in LaTeX; not just bits of it.
If you don't know LaTeX, you can try just writing ascii. But in the meantime, just to help, here are your formulae rewritten a bit. (Note that a superscript in LaTeX is written x^2.) Click on the formula to see the LaTeX code.
[tex]\begin{align*}<br /> & \lim_{v \to c} \frac{M_0}{\sqrt{1-\frac{v^2}{c^2}}} = \infty \\<br /> & \lim_{m \to \infty} \frac{F}{m} = 0<br /> \end{align*}[/tex]​
Well, that happens when you don't know Latex! Practice, practice, practice!
[tex]\lim_{v\to c}\frac{M_{0}}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
[tex]\lim_{m\to\infty} \frac{F}{m}= 0[/tex]
That took me only a few seconds.
Your only error is in thinking that it is possible to an object with non-zero mass to accelerate to c! Since nothing with mass can ever get to c so "what happens at c" is not relevant. It is true that light itself, which has mass 0, can neither accelerate nor decelerate and always moves at "c".
Darn! Sylas got in while I was typing!
does it have a mathematical reason that nothing with non zero rest mass can accelerate to c?
Yes. You can't give something infinite energy.
And I have a problem with photons too.I read that they're rest mass is 0.So we have:
[tex]\lim_{m \rightarrow 0} a \ = \ \lim_{m \rightarrow 0} \frac{F}{m} \ = \ \infty[/tex]
but Light has a constant speed.
any way.I downloaded the Latex reference.With having that read,It got easier.
[tex]\lim_{m \rightarrow 0} \frac{F}{m}=\infty[/tex]
The equation for energy of a particle is
[tex]E^2 = (pc)^2 + (mc^2)^2[/tex]​
The E is total energy, and p is momentum, and m is rest mass. A photon has no rest mass, so it reduces to
[tex]E = pc[/tex]​
The fundamental quantities are energy and momentum. You are much better to think in terms of these than in terms of mass.
Cheers -- sylas
I still don't understand.because for getting to c you don't need an impossible acceleration.the same goes for force.so how does the energy gets infinite?
The momentum of a particle with non-zero rest mass m and velocity v is
[tex]\frac{mv}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]​
The total energy is
[tex]\frac{mc^2}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]​
As you show in your first post, this diverges to infinite values as v approaches c.
Note that F = ma is only true at sub-relativistic velocity. But [itex]F = \frac{dp}{dt}[/itex] is always true. As you apply arbitrarily large forces, you can get momentum as large as you like... but never infinite.
In saying
[tex]\frac{F}{0}= \infty[/tex]
you are assuming that F is not 0. What force are you assuming is acting on light?
Are you talking about light? No one here has said that light has infinite energy.
If you are talking about a particle with non-zero mass, then you can't get to c! That's what we have been saying. So the energy of a non-zero mass particle does not "get infinite".
I may seem stupid but as I know [tex]p=\gamma m_{0} v[/tex] and [tex]m_{0}[/tex] is the rest mass.if it is,so pc must become 0,too.Hey its really confusing!
You can't use that formula for a massless particle, because γ is undefined. (It diverges to infinite.) So you are multiplying a zero by an undefined infinite value.
For a massless particle, the velocity is c, and the momentum is just E/c, where E is its energy.
Is it the Planck momentum?
The equation
[tex]F = ma[/tex]​
isn't valid in relativity. The correct version is
[tex]F = \frac{dp}{dt} = \frac{d}{dt}\left( \frac{mv}{\sqrt{1 - v^2/c^2}} \right)[/tex]​
where m is non-zero rest mass.
Unless I've made a mistake, this works out to be
[tex]F = \frac {ma} {(1 - v^2/c^2)^{3/2}}[/tex]​
So, if m and a are constant, the force really does diverge to infinity. (In practice, it's more likely F and m would be constant, so a would converge to zero.)
I'm not familiar with that term... but the energy of a photon is hf and its momentum is hf/c, where f is the frequency.
Shyan said:
Ah. Thank you. That is a unit of momentum in the Planck system of units. It's like an alternative to metric for ubernerds.
I'm not presuming any particular system of units; just giving the general laws which apply, regardless of what units you like.
DrGreg said:
The equation
[tex]F = ma[/tex]​
Slight correction:
[tex] F=\frac{d}{dt}(\gamma m v)=\gamma m a +m v \frac{d \gamma}{dt}=\left(\frac{v^2}{c^2}\frac{1}{(1-\frac{v^2}{c^2})^{3/2}}+\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}\right)m a[/tex]
Either way the conclusion remains the same.
Cyosis said:
Slight correction:
Actually
[tex] \frac{v^2/c^2}{1-v^2/c^2} + 1 = \frac{1}{1-v^2/c^2}[/tex]​
so we are in agreement!:smile:
(l left out the intermediate steps in my calculation and just gave the final answer.)
Cyosis said:
Slight correction:
Keep going.
[tex]\begin{align*}<br /> \frac{v^2}{c^2}\frac{1}{(1-\frac{v^2}{c^2})^{3/2}}+\frac{1}{\sqrt{1-\frac{v^2}{c^2}}} &=<br /> \frac{\frac{v^2}{c^2}}{(1-\frac{v^2}{c^2})^{3/2}}+\frac{1-\frac{v^2}{c^2}}{(1-\frac{v^2}{c^2})^{3/2}} \\<br /> &= \frac{1}{(1-\frac{v^2}{c^2})^{3/2}}<br /> \end{align*}[/tex]​
PS. By the way, I believe the quantity
[tex]\frac{a}{(1-\frac{v^2}{c^2})^{3/2}} = \gamma^3 a[/tex]​
is called proper acceleration, and is an invariant... corresponding the acceleration experienced by the moving body in its accelerated reference frame.
Ugh, it looks like I am particular sharp tonight!
I understood that, but I thought you had forgotten to apply the product rule, silly me. Anyway it's good we agree in the end!
You know,I just read it in wikipedia and I haven't noticed that its a unit.
(As a minor aside, I actually worked it out by doing the substitution [itex]v = c \tanh \phi[/itex], which might ring a bell with you from another thread!)
Please note that you guys are treating a vector equation like a scalar, and in general the coordinate acceleration isn't even in the same direction as the force. Let's see if I can get this right...
[tex]\begin{align*}<br /> \vec F &=& \frac{d\gamma m \vec v}{dt} \\<br /> &=& \frac{d\gamma}{dt}m\vec v + \gamma m \vec a \\<br /> &=& \frac{v}{(1-v^2)^{(3/2)}}\dot v m \vec v + \gamma m \vec a \\<br /> &=& \frac{\vec v\cdot \vec a}{(1-v^2)^{(3/2)}} m \vec v+ \gamma m \vec a \\<br /> \vec F &=& \gamma^3 (\vec v \cdot \vec a) m\vec v+ \gamma m \vec a \\<br /> \end{align*}[/tex]
Yes we calculated the x component of the force.
No, you calculated the v component. ;) But ok.
You are right. We are considering the special case of motion in a straight line, where the force is parallel to the velocity. I think that's sufficient for the questioner.
  • · Replies 26 ·
  • · Replies 17 ·
  • · Replies 57 ·
  • · Replies 25 ·
  • · Replies 27 ·
  • · Replies 20 ·
  • · Replies 26 ·
