Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Introductory Physics Homework (http://www.physicsforums.com/forumdisplay.php?f=153)
-   -   Not sure which formula to use! Deals with work and position (http://www.physicsforums.com/showthread.php?t=585363)
iJamJL Mar9-12 01:18 PM
A one-dimensional force acts on a particle of mass m = 6.26 kg in such a way that its position is given by:
x = 0.484t3 - 33.6t
Find W, the work done by this force during the first 1.49 s.
2. Relevant equations
F=mg
F=ma
W=F*distance
3. The attempt at a solution
To find the distance, I plugged in 1.49 into the formula they gave, and I got (-48.5). I know that to find work, the formula is W=F*s, so in order to find the force, I'm not sure which formula to use.
I think I should be using F=ma, and to find the acceleration, I can take the second derivative of the given formula. However, I forget whether that is allowed in one-dimension. If not, then do I use F=mg? If I use F=mg, then the answer for work will come out positive. If I use F=ma, then the work comes out negative.
Here are my results:
W=Fs
W=ma*s
W=6.26*18.18*(-48.5)
W=(-5519.6)J
W=Fs
W=mg*s
W=6.26*(-9.81)*(-48.5)
W=2978.4 J
Delphi51 Mar9-12 01:38 PM
Re: Not sure which formula to use! Deals with work and position
Yes! Do that and you will find that the acceleration varies with time so you can't use W=Fs; instead you have to integrate F*ds.
Gravity is not involved in this. It would cause a constant acceleration and a distance formula of s = Vi*t + .5*a*t rather than the cubic formula of this problem.
tiny-tim Mar9-12 01:39 PM
hi iJamJL! :smile:
Quote:
Quote by iJamJL (Post 3806716)
if you need to find the force, then yes you use F = ma
and yes the acceleration is the second derviative, even in three dimensions! :smile:
(what is worrying you about that? :confused:)
yes, that does give you the total distance
but W = F*s only works if F is constant
here, F isn't constant, so you would have to use W = ∫ F.ds
however it might be simpler to use the work-energy theorem, and calculate the difference in kinetic energy :wink:
iJamJL Mar9-12 01:57 PM
Thanks for the replies!
Quote:
Quote by tiny-tim (Post 3806738)
I didn't realize that until you pointed it out! I tried it out, but I think I made a mistake somewhere. Here's what I did:
To find the final velocity, which for this case is at 1.49s, we take the first derivative at 1.49:
x = 0.484t3 - 33.6t
dx/dt= 2*(.484)t^2 - 33.6
v= (-30.38)m/s
W=ΔKE
W= 1/2*m(v-final^2) - 1/2*m(v-initial^2)
**v-initial is 0 because t=0, x=0**
W=1/2*6.26*(-30.38)^2
W=2888.8 J
I tried entering that into my online homework system and it came out wrong. The system doesn't really care for the form that the answer is, as long as there are 3 significant digits. That means that I solved for this incorrectly! :cry:
tiny-tim Mar9-12 02:03 PM
Quote:
Quote by iJamJL (Post 3806770)
x = 0.484t3 - 33.6t
erm :redface: 3*t2 :wink:
iJamJL Mar9-12 02:26 PM
Quote:
Quote by tiny-tim (Post 3806784)
lol I wrote that on my scrap paper, but typed and calculated it incorrectly!
My end result came to:
v=(.484)*3*(1.49^2) - 33.6
=(-30.4)m/s
W=1/2*m*v^2
W=1/2*6.26*(-30.4^2)
W=2892.6 J
That's still coming out as incorrect.
tiny-tim Mar9-12 03:07 PM
Quote:
Quote by iJamJL (Post 3806820)
W=1/2*m*v^2
no, W = 1/2*m*v22 - 1/2*m*v12 :rolleyes:
gneill Mar9-12 03:18 PM
x = 0.484t3 - 33.6t
v= (-30.38)m/s
W=ΔKE
Just because t=0 and x=0, that does not imply that v(0) = 0. Plug t=0 into your velocity formula.
iJamJL Mar9-12 03:19 PM
Quote:
Quote by tiny-tim (Post 3806888)
Wow, I'm bad at this. I initially thought that v-initial would be 0, but then I looked back and realized it's not. *facepalm*
v(0)=(-33.6)m/s
v(1.49)=(-30.4)m/s
W=1/2*m*(v2^2) - 1/2*m*(v1^2)
W=1/2*6.26(-30.4^2) - 1/2*6.26*(-33.6^2)
W=2892.6 - 3533.6
W=(-641) J
Did I finally get the correct answer? :approve:
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
