Electromagnetic waves waves review
The discussion centers on the analysis of a plane electromagnetic wave with a wavelength of 56.0 m and an electric field amplitude of 20.0 V/m. The frequency of the wave is calculated to be 5.35 x 106 Hz using the formula f = c / λ, where c is the speed of light (299,609,581 m/s). The maximum electric field (Emax) is confirmed to be 20.0 V/m, and the magnetic field expression is derived using the equations B = Bmax cos(kx - ωt) with k and ω calculated as k = 0.1121 m-1 and ω = 33,615,041 s-1.
  • Understanding of electromagnetic wave properties
  • Familiarity with wave equations and their components
  • Knowledge of the speed of light and its calculation
  • Ability to manipulate trigonometric functions in physics equations
  • Learn about the relationship between electric and magnetic fields in electromagnetic waves
  • Study the derivation of wave equations in different mediums
  • Explore the implications of wave frequency and wavelength on energy
  • Investigate applications of electromagnetic waves in technology
Students studying physics, particularly those focusing on electromagnetism, as well as educators and professionals seeking to reinforce their understanding of wave properties and calculations.
Color_of_Cyan
The figure below shows a plane electromagnetic sinusoidal wave propagating in the x direction. Suppose the wavelength is 56.0 m and the electric field vibrates in the xy plane with an amplitude of 20.0 V/m.
(a) Calculate the frequency of the wave.
(b) Calculate the magnetic field when the electric field has its maximum value in the negative y direction.
(c) Write an expression for with the correct unit vector, with numerical values for Bmax, k, and ω, and with its magnitude in the form
B = Bmax cos (kx − ωt).
(Assume B is measured in nT, x is measured in m and t in s.)
c = 1/(μ0ε0)1/2
c = 299609581 m/s
f = c / λ
E = Emax cos(kx - ωt)
E max / B max = E / B = ck = 2π/λ
ω = 2πf
I only found the frequency, which is 5.35 x 106 HzI would like some hints how to find E max then I can just use the third equation listed.I'm thinking that E = Emax cos(kx - wt) and I think
E = (20V/m) cos[(0.1121)(x) - (33615041)(t)]
where 0.1121 is k (k=2pi / λ)
and where 33615041 is ω (ω = 2πf)
What would I do with regards to x and t in the equation?
The amplitude of the wave is given to you, and that is the magnitude of the electric field when it is maximal, isn't it?
Edit: wait, why are you asking about [itex]E_\text{max}[/itex] when you already observed it's [itex]20 \; \text{V/m}[/itex]
I didn't really see that... thanks
I got the rest of the problem as well.
