Explanation about air flows in tubes
  • Context: Undergrad
  • Thread starter Thread starter Ibraim
    Air Explanation
The discussion focuses on the dynamics of air flow through a small hole in a recipient during gas expansion and compression. It establishes that during expansion, gas exits the recipient with greater intensity due to momentum, while during compression, air is drawn in from multiple directions, resulting in a weaker flow. The asymmetry in these processes is attributed to the differing driving forces: pressure difference for entry and momentum for exit. The conversation references the IYPT 2013 problem, the Helmholtz Carousel, as a context for understanding these principles.
  • Understanding of basic gas laws and pressure differentials
  • Familiarity with fluid dynamics concepts
  • Knowledge of momentum and its effects on gas flow
  • Basic principles of thermodynamics
  • Research the principles of fluid dynamics, focusing on Bernoulli's equation
  • Study the effects of pressure differentials on gas behavior
  • Explore the Helmholtz Carousel problem in detail for practical applications
  • Investigate the concept of momentum in gas flows and its implications
Students and researchers in physics, particularly those interested in fluid dynamics, gas behavior, and problem-solving in competitive science contexts like the IYPT.
Ibraim
Hi people, I'm new here, so, if there's anything wrong with my post, please tell-me =)
So, if we have a recipient, with a cavity and a small hole, and imagine that we have a sudden expansion of the gas inside the recipient(we assume the volume increase was ΔV, and the duration of the expansion is negligible (Δt→0)). We will have an air flow through the hole. If we put our hands from a distance "d" in front of the hole, we'll feel the air flow.
Now, imagine again the recipient in the initial condition. This time, we'll have a compression in stead of an expansion. In the compression, we have the same variation of the volume(ΔV), with the same duration(Δt→0). We put our hand in front of the hole, from the same distance("d"), but, we don't feel the same intensity of the first flow. I mean, the same mass of gas that was expelled from the recipient in the first experiment, was sucked in the second one. If both occurred with the same conditions, why the first flow, leaving the recipient, is stronger than the second flow in the same distance from the hole, which get into the recipient?
I thing it's because in the expansion, the gas hurled in only one direction, and in the suction we have air from all directions getting into the recipient by the hole... but, if it's correct, why does this occur?
A superficial explanation is enough, or even a source where I can read about it(I've already looked for, but with no success.).
Sorry if i wasn't clear. And, it's not a homework, but a personal question.
Thank you for any answer!
Your explanation is right, but I don't know how to answer why it occurs other than to ask why not? What bothers you about it? Do you see it as asymmetric? The underlying asymmetry is that entry to the hole is driven by a pressure difference, whereas exit from the hole is driven by momentum (overcoming an opposing pressure difference).
First of all, thanks for the answer! I'm investigating this because I'm solving one of the IYPT problems for 2013, the Helmholtz Carousel, and I think it is an important thing to think about. I'm looking for the answer following your suggestion about the symmetry, and it seems to be the right way!
I'll keep looking! Thanks!
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 21 ·
