What is the Meaning of Vectorlike Fermion in Particle Physics?
  • Context: Graduate
  • Thread starter Thread starter wphysics
    Fermion
The discussion revolves around the concept of vectorlike fermions in particle physics, particularly in the context of the Standard Model and their interactions with gauge fields. Participants seek to clarify the meaning and implications of vectorlike fermions, exploring their properties and how they differ from standard fermions.
  • One participant requests an explanation of the term "vectorlike fermion" and expresses difficulty in understanding its meaning.
  • Another participant suggests providing references for better context and shares a specific paper that may clarify the concept.
  • A participant explains that in the Standard Model, left-handed fermions form isospin doublets while right-handed ones are isospin singlets, and notes that vectorlike fermions have left- and right-handed components transforming the same way, allowing for mass terms to be gauge invariant without the Higgs field.
  • One participant questions why these fermions are referred to as "vector-like," linking the term to the properties of currents that couple to gauge fields.
  • A participant discusses the interactions of normal fermions with the W and Z bosons, raising questions about the assumptions made regarding vectorlike fermions and their isospin properties.
  • Another participant clarifies that vector-like couplings to the Z boson do not involve the \gamma^5 term and notes that the weak isospin for new particles may allow for different coupling scenarios.
The discussion contains multiple viewpoints and questions regarding the definition and implications of vectorlike fermions, with no consensus reached on certain aspects, particularly concerning their interactions and isospin properties.
Participants express uncertainty about the specific definitions and implications of vectorlike fermions, particularly in relation to their coupling mechanisms and isospin characteristics. There are unresolved questions about the assumptions made in various references.
wphysics
In many papers about hep theory, I can find the concept, vectorlike fermion.
But, I cannot get the exact meaning of vectorlike fermion.
I would like you guys to explain vectorlike fermion.
Thank you.
It would help if you give some references where they talk about this. Without context it is hard to answer your question.
If I do the googling for you, I come across this paper,
http://deepblue.lib.umich.edu/bitstream/2027.42/28619/1/0000431.pdf
where they seem to explain the term in the introduction very clearly. If you still don't grasp the idea, you should be a bit more specific :)
The definition is clear enough. In the Standard Model, the left-handed fermions form isospin doublets, while the right-handed ones form isospin singlets. So the usual mass term, being a product of the two, requires the help of the Higgs field to be gauge invariant. But for these vectorlike fermions, the left- and right-handed components are supposed to transform the same way, making the mass term invariant independently of the Higgs.
The question I have is, why do they refer to them as vector-like.
The notion of vector-like originates in the property of the current that couples to the gauge field in question. With a Dirac fermion [itex]\Psi[/itex], the current [itex]\bar{\Psi}\gamma^\mu\Psi[/itex] is a vector, while [itex]\bar{\Psi}\gamma^\mu\gamma^5\Psi[/itex] is an axial vector. The left-chiral current of the weak interaction is [itex]\bar{\Psi}\gamma^\mu(1-\gamma^5)\Psi[/itex], hence the name of the "V-A theory."
Ok, for a normal fermion, the interaction with the W is V-A. They make no mention of that. But the interaction with the Z, which they do discuss, is a different mixture,
cVγμ - cAγμγ5
where cV = T3 - 2 sin2θW Q and cA = T3.
For the vector-like fermion are they assuming it's an isosinglet?? (So that T3 = 0.) The intro only said the left- and right-handed components were supposed to transform the same way.
If by "they," you mean del Aguila et al, the vector-like couplings are listed in Table 1. A vector-like coupling to the Z does not include the [itex]\gamma^5[/itex] term. There's no connection between [itex]c_A[/itex] and [itex]T^3[/itex], as the former is identically zero for the new particles. They also allow for the possibility of weak isospin doublet, in which case the W couples to a charged vector current like [itex]\bar{N}\gamma^\mu E[/itex].
  • · Replies 0 ·
  • · Replies 49 ·
