Requirements for Magnetic Plasma-ization?
  • Context: Graduate
  • Thread starter Thread starter dbmorpher
    Magnetic
The discussion revolves around the potential effects of a powerful electromagnet, specifically one with a strength of 45 Tesla, on the electrons in metallic bonds. Participants explore whether such a magnetic field could effectively "pull" electrons from these bonds and the conditions under which this might occur.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant inquires if a 45 Tesla electromagnet is sufficient to remove electrons from metallic bonds.
  • Another participant suggests that while magnetic fields can influence energy levels, they do not directly "pull" electrons unless there is some form of movement involved.
  • A further claim posits that if the energy level is sufficiently high, electrons could disperse, leaving only the nucleus behind.
  • It is noted that electrons in metallic bonds are not bound to individual atoms, which may affect their response to magnetic fields.
  • A calculation is presented indicating that electrons would need to reach approximately 0.07c to experience a force of ~1eV/nm in a 45 Tesla field, suggesting that this force is relatively small compared to the electric fields present in atoms.
Participants express differing views on the ability of a magnetic field to remove electrons from metallic bonds, with some suggesting that it is possible under certain conditions while others clarify the limitations of magnetic influence on electron behavior.
The discussion includes assumptions about the behavior of electrons in magnetic fields and the specific conditions required for any effects to occur, which remain unresolved.
Individuals interested in electromagnetism, materials science, or the behavior of electrons in magnetic fields may find this discussion relevant.
dbmorpher
Hi,
I live near the world's most powerful electromagnet. I was wondering if the magnet would be powerful enough to pull the electrons from a metallic bond? The magnet can reach a power level of 45 Tesla. I would like to know if this is powerful enough to do this and if not what is.
Magnetic fields can influence the energy levels, but they do not "pull" electrons unless you move them in some way.
So if the energy level is high enough the electrons could disperse themselves and leave just the nucleus, right?
Electrons in metallic bonds are not bound to any atom.
Just to get a rough order of magnitude of any effects: Electrons need ~0.07c to get a force of ~1eV/nm in a field of 45 Tesla (calculation). 1eV/nm is small compared to electric fields in atoms, and 0.07c is quick.
Thank you very much
  • · Replies 21 ·
  • · Replies 0 ·
13K
