How to maintain CPT invariance in Kaon oscillations
The discussion centers around the topic of neutral Kaon oscillations and the implications for CPT invariance. Participants explore the quantum mechanics involved in the oscillation between K^0 and \overline{K^0}, the role of mass differences, and the effects of CP violation on these states.
  • One participant notes that neutral Kaons can oscillate between K^0 and \overline{K^0}, suggesting that this oscillation is linked to a mass difference represented by a \cos(\Delta m t) term.
  • Another participant states that K^0 and \overline{K^0} are not mass eigenstates, implying a need for further clarification on the nature of these states.
  • A participant discusses the Hamiltonian for K^0 and K^0-bar states, indicating that while CPT requires equal masses, weak interactions introduce perturbations that lead to mass differences.
  • There is a question about whether \Delta m refers to the mass difference of modified states due to weak interactions, with a subsequent response affirming this idea.
  • One participant clarifies that the mass eigenstates are K1 and K2, and without CP violation, these would have the same mass, suggesting no kaon oscillations would occur.
  • Another participant asserts that even without CP violation, the mass eigenstates would still be mixtures of weak eigenstates, indicating a complex relationship between these states.
  • A participant raises a point about the definition of eigenstates having definite mass values and lifetimes, questioning the characterization of KS and KL as eigenstates in the presence of CP violation.
  • One participant corrects their earlier statement, detailing the composition of K^0 and its antiparticle as strong eigenstates, and explains the implications of CP violation on the lifetimes and decay modes of KS and KL.
Participants express differing views on the nature of mass eigenstates and the implications of CP violation. There is no consensus on how these factors interact to maintain CPT invariance in the context of Kaon oscillations.
The discussion includes complex interactions between weak and mass eigenstates, the role of CP violation, and the definitions of eigenstates, which may depend on specific assumptions and interpretations that are not fully resolved.
SteDolan
Hey,
I'm trying to get my head around neutral Kaon oscillations. As far as I understand it neutral Kaons can change between [itex]K^0[/itex] and [itex]\overline{K^0}[/itex] as they propagate. Going through the quantum mechanics of this implies that this oscillation must be facilitated by a mass difference between the [itex]K^0[/itex] and [itex]\overline{K^0}[/itex] in a [itex]\cos(\Delta m t)[/itex] term.
But I thought a mass difference between any particle and its antiparticle implies CPT violation.
As far as I know CPT is not known to be violated so my question is: How do Kaon Oscillations maintain CPT invariance?
Thanks in advance for any help :D
The K0 and K0bar are not mass eigenstates.
Consider the Hamiltonian across the K0 and K0-bar states. CPT says the masses of these states are equal:
[tex]\left(\begin{array}{cc}M&0\\0&M\end{array}\right)[/tex]
But the weak interaction adds a perturbation that turns K0 into K0-bar:
[tex]\left(\begin{array}{cc}M&ε\\ε&M\end{array}\right)[/tex]
As V50 says, K0 and K0-bar are no longer the eigenstates, and the originally degenerate mass eigenvalues have been split into two unequal eigenvalues.
Thanks! That makes sense.
So I guess the [itex]\Delta m[/itex] refers to the difference in mass of the modified states coupling to the weak interaction (a superposition of K0 and K0-bar)?
No, those "particles" are the weak eigenstates. The mass eigenstates are called K1 and K2. Neglecting CP violation, K1 is the short-living KS and K2 is the "long"-living KL.
CP violation introduces another, but small mixing in this system - KS has some small component of K2 and KL has a small component of K1.
Thanks. I think I understand that. Am I right in thinking that if there was no CP violation the mass eigenstates would have the same mass and therefore there would be no kaon oscillations?
Without CP violation, the mass eigenstates would be identical to K_S and K_L, but those would remain a mixture of the weak eigenstates.
The mass eigenstates are called K1 and K2. Neglecting CP violation, K1 is the short-living KS and K2 is the "long"-living KL. CP violation introduces another, but small mixing in this system - KS has some small component of K2 and KL has a small component of K1.
:confused: Isn't it true that, regardless of CP violation, eigenstates have definite mass values and lifetimes. So KS and KL must be by definition the eigenstates, even though they won't be exact eigenstates of CP.
Wait, I messed it up.
##K^0 = d\bar{s}## (and its antiparticle) is a strong eigenstate.
Without CP violation, ##K_1 = K_S = \frac{1}{\sqrt{2}} (d\bar{s} + \bar{d}s## and ##K_2 = K_L = \frac{1}{\sqrt{2}} (d\bar{s} - \bar{d}s## are weak and mass eigenstates. The first one has CP=+1, the latter one has CP=-1. This explains their lifetime difference, ##K_L## has to decay to three pions while ##K_S## can decay to two.
With CP violation, but conserved CPT,
##K_S = \frac{1}{1+\epsilon^2}(K_1 + \epsilon K_2)## and ##K_L = \frac{1}{1+\epsilon^2}(K_2 + \epsilon K_1)##
##K_S## and ##K_L## are weak (and mass?) eigenstates, giving them their different lifetime. The small CP violation allows (rare) decays of a ##K_L## to two pions and decays of a ##K_S## to three pions.
The real part of ϵ is about 1.6 permille.
