Hall Voltage Effect: Calculating Potential Difference
  • Thread starter Thread starter zigga15
    Voltage
The discussion focuses on calculating the Hall voltage across the diameter of an artery containing flowing blood, which acts as a charged particle medium. The artery has a diameter of 0.85 cm and a blood flow speed of 0.6 m/s, situated in a magnetic field of 0.4 T. The Hall voltage formula, V = (IB)/ned, is referenced, but the user lacks sufficient information about the number of charge carriers (n) to complete the calculation. The need for additional data on charge carriers is emphasized as critical for solving the problem.
  • Understanding of Hall voltage and its formula, V = (IB)/ned
  • Knowledge of magnetic fields and their effects on charged particles
  • Familiarity with the concept of charge carriers in a fluid
  • Basic principles of fluid dynamics related to blood flow
  • Research the concept of charge carriers in biological fluids
  • Learn how to calculate Hall voltage in different scenarios
  • Study the effects of magnetic fields on moving charged particles
  • Explore fluid dynamics principles relevant to blood flow in arteries
Students in physics or biomedical engineering, researchers studying blood flow dynamics, and professionals interested in the applications of the Hall effect in biological systems.
zigga15
Hey I am having trouble with the following question.
Because blood contains charged ions moving blood develops a Hall voltage across the diameter of an artery. The blood in a large artery with a diameter of 0.85 cm has a flow speed of 0.6 m/s. If a section of this artery is in a magnetic field of 0.4T, what is the potential diference across the diameter of the artery?
I have an idea of what is going on in the question, but it seems i havn't been given enough information to solve it. I know that hall voltage is given by:
V = (IB)/ned and i know that F = qvB if i assumed the field was perpendicular to the artery I could use that for something - maybe. But really I am stumped, any help, or even a formula i have over looked would be great thanks.
~Daniel
~Daniel
You have to know how many charge carriers flow past a given point per unit time. You don't have enough information to find that.
AM
  • · Replies 0 ·
  • · Replies 0 ·
