Integration of an inverse sqrt composite function
The problem involves calculating the time it takes for a transverse wave to travel up a rope when a box is pushed from the bottom of a cave. The scenario includes parameters such as the mass of the box, the mass of the rope, and the gravitational acceleration, with a focus on deriving an expression for wave speed as a function of distance along the rope.
  • Participants discuss the correct formulation of the mass density of the rope and its implications for the wave speed equation. There are attempts to integrate the expression for travel time, with some participants questioning the integration steps and variable substitutions used.
There is ongoing dialogue about the integration process and the correct interpretation of variables. Some participants have offered guidance on using substitution for integration, while others are still clarifying their understanding of the setup and the equations involved.
Participants note that the variable used for mass density needs to be constant rather than variable, which affects the integration approach. There is also mention of confusion regarding the integration of composite functions and the need for a clearer understanding of integration techniques.
Hendrick
“Geologist A” at the bottom of a cave signals to his colleague “Geologist B” at the surface by pushing a 11.0 kg box of samples from side to side. This causes a transverse wave to propagate up the 77.0 m rope. The total mass of the rope is 14.0 kg. Take g = 9.8 m/s².
How long does it take for the wave to travel from the bottom of the cave to the surface?[Hint: Find an analytic expression v(z) for the wave speed as a function of distance. Then use the fact that at any given point on the rope the time dt taken to travel a small distance dz is given by: dt=dz/v(z). Then integrate to obtain the total travel time. ]
http://oasis.phy.auckland.ac.nz/oasis/a/question/187416/image.gif
u = mR/z
T(z) = u.z.g + mB.g
v(z) = (T(z)/u)^(1/2)
dt=dz/v(z)
z = the length of the rope = L (used for integrating)
v(z) = ((mR/z).z.g + mB.g/(mR/z))^(1/2)
v(z) = ((mR.g + mB.g)/(mR/z))^(1/2)
v(z) = ([(mR.g)/(mR/z)] + [(mB.g)/(mR/z)])^(1/2)
v(z) = ([(mR.g.z)/mR] + [(mB.g.z)/mR])^(1/2)
v(z) = ([mR.g.z] + [(mB.g.z)/mR])^(1/2)
dt=dz/v(z)
dt=dz/([mR.g.z] + [(mB.g.z)/mR])^(1/2)
Integration:
...f L
t= | (1/([mR.g.z] + [(mB.g.z)/mR])^(1/2)).dz
...j 0
...f L
t= | 2.([mR.g.z^2/2] + [(mB.g.z^2)/mR.2])^(1/2).dz
...j 0
I think I integrated it properly but when substituted the values
mB = mass of box
mR = mass of rope
g = 9.8 ms^2
z = 77.0 m
I didn't get the correct answer of t = 2.52s
'u' in your solution is supposed to be the mass density of the rope. It's not mR/z. The rope doesn't have a variable density, it's mR/(total length of rope), a constant. Nice problem presentation, by the way.
Dick said:
'u' in your solution is supposed to be the mass density of the rope. It's not mR/z. The rope doesn't have a variable density, it's mR/(length of rope). Nice problem presentation, by the way.
Hi Dick, z is the length of the rope (77.0m as in the problem) it was just the letter they used in the formula sheet so I carried it forth.
How was my integration? I don't think I know how to integrate nested functions (I assume it's something like the reverse of the chain-rule?).
z in your problem is the variable indicating length along the rope. I mean that u=14 kg/(77 m). It doesn't have the variable of integration in it. Until that gets fixed there isn't any point in discussing the integral.
In your notation u=mR/L not mR/z.
Oh, ok. Thanks for pointing that out :)
So:-
u = mR/L = mR/77
T(z) = u.z.g + mB.g
dt=dz/v(z)
v(z) = ((u.z.g + mB.g)/u)^(1/2)
v(z) = ([(u.z.g)/u] + [(mB.g)/u])^(1/2)
v(z) = ([g.z] + [(mB.g)/u])^(1/2)
dt=dz/v(z)
dt=dz/([g.z] + [(mB.g)/u])^(1/2)
Integration:
...f L
t= | (1/(([g.z] + [(mB.g)/u])^(1/2)).dz
...j 0
...f L
t= | 2.([g.z] + [(mB.g)/u])^(1/2).(g.z^2)/2
...j 0
Where:
mB = mass of box
mR = mass of rope
g = 9.8 ms^2
z = 77.0 m
Is this correct?
Your first integral looks just fine. I don't know how you got from there to the second one. The usual way to do an integration like this is to do a change of variable. Let v=gz+mBg/u.
Ok, I was trying to use the chain rule lol ><
So:-
Integration:
...f L
...j 0
...f L
t= | 2.([(g.z^2)/2] + [(mB.g.z)/u] + C)^(1/2)
...j 0
Where:
mB = mass of box
mR = mass of rope
g = 9.8 ms^2
z = 77.0 m
How am I doing? :smile:
Not too good. You're coming up with some pretty bizarre integration rules which aren't in the book. You have to do the change of variable thing. Eg to integrate 1/(a+bz)^(1/2) I would say v=(a+bz), so dv=b*dz. This turns the integral into 1/v^(1/2)*dv*(1/b). Now it's just integrating v^(-1/2). Does that sound familiar?
Unfortunately not very familiar at all. I haven't really dealt with composite integrals. But I'll try:
a = g.z
b = (mB.g)/u
1/(a+bz)^(1/2)
Integrating v^(-1/2).So:-
Integration:
...f L
...j 0
...f L
t= | (1/(([g.z] + [(mB.g)/u])^(1/2)).[(mB.g)/u]dz.(1/[(mB.g)/u])
...j 0
...f L
t= | 2.(([g.z] + [(mB.g)/u])^(1/2)).[(mB.g)/u].(1/[(mB.g)/u])
...j 0
Where:
mB = mass of box
mR = mass of rope
g = 9.8 ms^2
z = 77.0 m
Take a break and clear your head. While your at it look back at integration by substitution in a calc text. I can roughly see what you are trying to do - but you still seem to be trying to do some kind of a chain rule. And the (1/b) factor in the example becomes (1/g) in the problem, right? Do you see where it's coming from? And after the integration is done and the dz is gone you should also drop the integral sign - it looks pretty confusing otherwise.
  • · Replies 26 ·
  • · Replies 40 ·
