How to calculate the carrier concentration
myousuf
Can any please help me in solving the following two questions
Q1
A Si sample is doped with 10^16 per cm cube boron atoms and a certain
number of shallow donors. The fermi level (Ef) is 0.36 eV above Ei
(intrinsic energy level) at 300K. What is the donor concentration Nd?
For Si at 300K ni(intrinsic carrier concentration) = 1.5 x 10^10 per
cm cube
Q2
A Si sample contains 10^16 per cm cube In(indium) acceptor atoms and
a certain number of shallow donors. The In (indium) acceptor level is
0.16 eV above Ev(Valence band edge), and Ef is 0.26eV above Ev at
300K. How many in atoms in cm per cube are unionized (i.e. neutral)?
cm cube
There is no additional information available. Please state the
question number when answering and indicate any formulas used.
The following equations may prove useful
n(o) x p(o) = ni^2
n(o) = ni x e((Ef-Ei))/KT)
p(o) = ni x e((Ei-Ef)/KT)
What have you done so far? If you want help, than you should say what you think and what you have tried.
Is there any more relations that you know of? How about "carge neutralisty condition of doped semi conductor" ? And Law of mass action?
This is what I have came up with so far for question number 1
using the relation n(o) = ni x e((Ef-Ei))/KT)
with Ef-Ei=0.36 x 1.6 x 10^-19 , ni=1.5 x 10^10, T=300k , K=1.38 x 10^-23
we get n(o) = 1.654 x 10^16 per cm cube
However there are 10^16 B atoms to neutralize these charges
Hence Nd = 1.654 x 10^16 - 10^16 = 6.5 x 10^15 per cm cube
For question number 2
unionized atoms are left at the acceptor level
Ef-Ev=0.26eV
Ea-Ev=0.16eV
Ea-Ef=0.16-0.26= -0.10eV
Using fermi-driac statistics f(E)=1/(1+e((E-Ef)/KT)))
for E=Ea,T=300 and substituting all the constants
f(E)=1/(1+e((Ea-Ef)/KT))), gives = 0.9794
However fermi driac statistics give the probablity of occupance of an electron in an Energy state E. hence 0.9794 is the probablity of occupance of an electron.
hole probablity of occupance=1-electron probablity of occupancy
hole probablity of occupance of the energy state Ea = 1-0.9794 = 0.02053
unionized atoms are left at the acceptor level(Ea)
Hence, number of IN(indium) atoms left unionized = hole probabilty of occupancy of Energy state Ea x number of In acceptor atoms
=0.02053 x 10^16
=2.05 x 10^14
Anyway there are still questions that remain unanswered
For instance, what role does shallow donor impurities have to play in question number 2.
Any suggestions to the proposed solution above will be highly appreciated
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
