Find the equation to a parabola problem
  • Thread starter Thread starter srujana_09
    Parabola
The discussion focuses on deriving the equation of a parabola given two points on it, specifically when both points lie on the same side of the axis of symmetry and the time of travel between them is known. The standard form of the parabola is expressed as y = ax² + bx + c, requiring three equations to solve for the coefficients a, b, and c. The two equations are formed using the coordinates of the given points (x₁, y₁) and (x₂, y₂). The third equation is derived from the arc-length formula of the parabola, equating it to the distance calculated from the time of travel divided by the uniform velocity.
  • Understanding of quadratic equations and their standard form (y = ax² + bx + c)
  • Knowledge of arc-length calculation for curves
  • Familiarity with uniform velocity concepts in physics
  • Basic algebra skills for solving systems of equations
  • Study the derivation of the arc-length formula for parabolic curves
  • Learn how to solve systems of equations involving quadratic functions
  • Explore applications of uniform motion in physics
  • Investigate the properties of parabolas and their geometric interpretations
Students studying algebra and calculus, particularly those tackling problems involving parabolas and motion, as well as educators seeking to enhance their teaching methods in these areas.
srujana_09
Can we find the equation to a parabola when two points on it are given,both lying on the same side of the axis of symmetry and also the time of travel between them is given.It is also given that the point travels with uniform velocity along the whole length of the parabola.
Are you assuming that the axis is vertical? If so then any such parabola can be written as [itex]y= ax^2+ bx+ c[/itex] and you need three equations to solve for the three coefficients, a, b, c. You are given two points, [itex](x_1,y_1)[/itex] and [itex](x_2,y_2)[/itex] on the parabola so [itex]y1= ax_1^2+ bx_1+ c[/itex] and [itex]y2= ax_2^2+ bx_2+ c[/itex]. Those are two of the equations. You also know the "length" of the parabola between [itex]x_1[/itex] and [itex]x_2[/itex]- it's the "time of travel" divided by the uniform velocity (I assume you know that velocity- otherwise you do not have enough information to determine the parabola). Write out the equation for the arc-length of [itex]y= ax^2+ bx+ c[/itex] and set it equal to that length. That gives you a third equation for a, b, and c.
